Size of oil drain plug? - Diesel Forum - TheDieselStop.com
Old 09-09-2006, 01:20 PM   #1 (permalink)
Helm is out of the 2006 F350 factory shop manual, I have it on back order. Until it arrives does anyone have the wrench size for the oil drain plug and if possible the torque spec?
Thanks in advance.
2006 F350 PSD XL Supercab, Torqueshift Job #2
1992 F150 4.9L, 230,000 miles
1989 HD Low Rider Sport, 23,000
blinky is offline
Old 09-09-2006, 02:40 PM   #2 (permalink)
Re: Size of oil drain plug?
3/4", torque...snug!
Steve
2006 F250 Lariat CC FX4 6.0 PSD Torqshift, Line X, Viper 791XV, IssPro Pyro. Engine Build June 6, 2005. Truck Build June 16, 2005
skroesen is offline
Old 09-09-2006, 06:40 PM   #3 (permalink)
19mm on the drain plug, Torque...I agree on "Snug" for the drain plug and factory spec for the Oil Filter cover is 18 ft/lbs (36mm for the oil filter cover)
But I highly suggest getting a Fumoto drain valve and then you only have to think about "wrenching" on the oil drain and threads once [img]/ubbthreads/images/graemlins/smile.gif[/img]
Mntsnow
04 F250, Lariat, CC, SB, SRW, 6.0L, TorqShift, FX4, 6-way Power Heated Leather, 3.73 LS, ESOF,Tow w/15K hitch, H & L TT mirrors, Adj pedals, Reverse sensors, Privacy glass, Cab steps, Sliding rear glass, Overhead console, Advanced Security group, Medium Wedgewood Blue Metalic w/Arizona Beige Accent paint. 325/70/17 Toyo Open Country AT's, Pro-Comp 6.5" All spring lift, 4" Cat-back exhaust, Fumoto Valve, Harpooned, Zoodad, Steveracer, $5 High-Idle mods, Pioneer DEH-P7500MP, CS8A5 Bazooka Tube, X-Monitor Digital Gauges, Viper 5900 Responder SST remote start security system and more to come!
Truck Build Date 8/03, Engine build date 8/20/03, Bought 11/09/03
Mntsnow is offline
