Slick 50 oil treatment - Diesel Forum - TheDieselStop.com
Closed Thread
post #1 of 24 (permalink) Old 12-08-2006, 07:41 PM Thread Starter
Would anyone have experience using the diesel Slick 50 oil treatment in the PSD? May be a good idea for cold starts etc...Any thoughts? Thanks!
2006 F350 Lariat Crew Cab 4x4
350Blue is offline
post #2 of 24 (permalink) Old 12-08-2006, 08:13 PM
olddieseldude's Avatar
My Photos: (16)
Re: Slick 50 oil treatment
I would not do it. What will PTFE or what ever it is do when pressurized by the HPOP and passes through the injectors?
Edited:
Or what will it do when exposed to the heat of the turbo?
RickN
(mods listed in comments under photo in above link)
olddieseldude is offline
post #3 of 24 (permalink) Old 12-08-2006, 08:25 PM
Banned
[/ QUOTE ]You are better off buying a lottery ticket than wasting your money on that crap!
sicaj is offline
post #4 of 24 (permalink) Old 12-08-2006, 09:33 PM
RatherBNtheWoods's Avatar
Oh I dunno. That stuff is pretty thick and tacky. I would think it would make the cold start romping worse than it already is with these engines.
Maybe some 6.0's are as picky as mine, I dunno. I tried Mobil1's(which I think is one of the best synthetics around) SUV/Turbo diesel synthetic, and thought I was gonna have to chain my truck down to keep it from rolling over 'cause it romped so hard. I stick to straight synthetic Rotella or motorcraft oil now, with no additives.
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear, Built May05. 4" turbo back, 55 gal aux fuel tank. A real pig from a stop, give me 15' and she'll slowly come to life, then watch out!
165K miles, 12 injectors, EGR cooler, Fuel pump, 8 glow plugs, GPCM, FICM rebuilt FoMoCo engine at 150K under 7/200 warranty.
RatherBNtheWoods is offline
post #5 of 24 (permalink) Old 12-08-2006, 09:34 PM
Ditto. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] and you may end up buying some new injectors in the future also. [img]/ubbthreads/images/graemlins/smile.gif[/img]
2004 F-350 Lariat, Supercab 4X4 FX4, DRW
Dark Toreador Red/Silver, 6.0L, Torqueshift Auto, ESOF, 4.10 LS, Camper Package, Dual Alternators. Build Date 6-8-04, Eng 5-28-04, Lance 9.5 Ft Camper.
Past 2002 F-350 Lariat, Supercab 4X4, Toreador
Red, 7.3L, Auto, DRW, Fully Loaded.
Past 94.5 F-250 Lariat, Supercab 4X4, 5 spd 7.3L PSD.
DRJ48 is offline
post #6 of 24 (permalink) Old 12-08-2006, 09:42 PM
I tryed it once on my new IROC ( way back then)your suppost to drive for about 50 miles so it pregnates to the cylinder walls. While I was doing it the engine blew. Thank god Chevy put a new motor in for only 100$ dedutable. I wouldnt do it.
2001 white F250 sc xlt psd," DI regulator kit, DI BIG fuel system, DI Mine-Me injectors, DI ATS BB Turbo, DP Chip,DI Valve Pressure Release,DI-adjustable IDM mod ",Terminator 2 HPOP R-IPR, APR studs, 910 valve springs, BTS Trans&Converter,6.0 Intercooler, AFE Stage 2 with zoodad,Power Elbow, Bully Dog full 4" exhaust with 5" tip,Fluidampr, hx mod,203t-stat, CCV mod, Fumoto Oil Valve,Cool-Max Trans Cooler, Autometer Phantom Gauges,Bilstein shocks, Rancho5406 stablizer, Edge 4" lift kit, Rear RoadMasters active suspension, EGR Slotted & Crossed Drilled Rotors with Carbon/Kelvar brake pads, Welds Cheyenne 8s, Roll & Lock bed cover, Sylvania SilverStar 9007& 9005s, Chrome Billet Grill, 2003 Clear Headlights, APC Clear corners, APC Euro rear lens, APC gas & brake peddles, Acetone Badges, Chrome Door & Tail Gate Handles, Oakley Seat Covers, Viper alarm, Cyclops Fuel Cut-off alarm.
joediesle is offline
post #7 of 24 (permalink) Old 12-08-2006, 10:16 PM
S N A K E ERRRRRRLLLL. Dont put this CRAP in your engine Oil.
07,F-250 4X4 6.0 Torqshift, Lariat, Highline package, S/C LWB.
grounder is offline
post #8 of 24 (permalink) Old 12-08-2006, 11:02 PM
Do not use it. That also applies to K&N filters - they do flow better, they have larger pores that also flow more dirt than a stock paper filter. For proof, feel the grit on the inside of your clean air tube if you run one. The filter oil will also mess up the heated MAF element.
Try synthetic oil instead. Change your filters at the recommended intervals. Drain the water from the HFCM every month. These are all things that will make a difference!
Synthetic oil will help cold starts. If you don't tow, use 10W30 when it's below 90F outside.
Tec80 is offline
post #9 of 24 (permalink) Old 12-09-2006, 03:32 AM
FamilyRide's Avatar
Google it and make your own decision. [img]/ubbthreads/images/graemlins/wink.gif[/img]
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, bubba lights and newly added so called bullet proofing, including PMax turbo.
FamilyRide is offline
post #10 of 24 (permalink) Old 12-09-2006, 06:02 AM
I have a buddy that deals in Prolong additives. (Flame suit on) I use it in all of my vehicles. I won't go into a long-winded story, but that stuff saved the $7K engine in my '73 Torino, and it sold me. I don't use it on every oil change, just once or twice a year. This stuff is not thick like Slick 50 is, and I noticed less noisy cold starts when I used it, especially with my '02 7.3L
Please do not bother with the "snake oil" speeches. I am not an idiot, and I wouldn't use Prolong if it did not yield me results. Most folks with critisism on this product have not, nor will they ever actually try it, and I didn't, either, until I witnessed results from someone else's truck.
Red 2002 F-350 XLT SRW 4x4 7.3L reg. cab 6-speed rubber floors traded at 50K for:
Red 2005 F-350 XLT SRW 4x4 6.0L reg. cab 6-speed rubber floors BFG 12.5x35 mud-terrains, no lift traded for:
Red 2008 F-350 XLT SRW 4x4 6.4 reg. cab 6-speed. Got carpet this time- audiophile stereo deletes rubber floors. BFG 12.5x35 mud terrains, no lift.
Traded at 45K for: Red 2011 F-350 XLT SRW 4x4 6.7L reg cab BFG 12.5x35 mud terrains, no lift. "optioned" out of- stick shift, rubber floors, audiophile stereo, fog lights, chrome step bars GRRRRR!
torino73 is offline
post #11 of 24 (permalink) Old 12-09-2006, 01:04 PM
ha, good old Solong.
had a buddy that put it in his 400 pontiac and it spit a rod.
put it in you engine and say So-Long. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
BigBadF350 is offline
post #12 of 24 (permalink) Old 12-09-2006, 02:48 PM
OT
OT's Avatar
I have no experience using slick 50 in a diesel. Even so, wouldn't use it in mine.
FWIW..I did use in my old 88 460cid. Don't recall any early on problem, but I dumped oil not long after. Why, cause found out later it could crud up internal parts. Another product (not related) at the time "STP" turned out to be no more than a $$$ oil thickener.
T73...I used "prolong" in my old hi mi. chevy V6. It did decrease oil consumption. Will be using soon in my Buick V6. If it works same, I'll continue to use. Dont know on diesel?
03 F250 XLT SC/SB 4X4 6L (stock) TqS. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
post #13 of 24 (permalink) Old 12-09-2006, 03:52 PM
In my 1983 Chevy S-10 (my first vehicle) I used to use a product called Motor Honey. I can't say as it helped anything, but I was 17 years old and thought it helped the 2.8L engine run better. That truck had 118K miles when I got it and it had nearly 200K when I sold it. I miss that truck.
FWIW, I'm not adding anything to the motor oil in this truck. IIRC, I believe the owner's manual even warns against adding stuff to the oil.
2005 Arizona Beige F350 XLT FX4 6.0 CC shortbed, 3.73 ls rear, 18" wheels, Tow Command. Additions: Vent Visors, bug guard, Fumoto Valve, Timbrens. Traded for...
Current Truck -- 2008 Black F350 XLT 4x4, 6.8 V10, CC Long Bed, 4.10 rear, 18" wheels, IBC. Additions: Chrome Step Bars, Chrome door handles, Silver barbed-wire pin stripe, B&W Turnover GN ball
barrelhorses is offline
post #14 of 24 (permalink) Old 12-09-2006, 04:34 PM
I thought these guys had been scared off years ago for misleading advertising. Bottom line: the temperatures within the engine are nowhere near what would be required to bond PTFE to anything, even if it were so inclined. With the good oil filters we run, I wouldn't be surprised if most of the powdered PTFE ended up right there on the first pass anyway. Hope so, I sure wouldn't want that stuff or the wrong-for-our-engines oil that it comes in anywhere near the injectors.
'05 F-350 PSD 4x4 CC SB SRW Manual
PineKnot is offline
post #15 of 24 (permalink) Old 12-09-2006, 05:05 PM
Slick 50 states nothing about C-I4 rated. Greased Lightning is C-I4 rated!! I've used it in my all my trucks every 50,000 miles!! Don't know if it helps but it can't hurt!!
05 White XL 6.0 Reg Cab 4X4 170,500 miles!!
---07 Shelby GT500--- Performance White Vert-- Mods-- JLT Intake, 2.6" upper & 10% IW Lower Pulleys, AFCO Duel Pass Heat Ext., American Racing Long Tube Headders, Full 3" Magnaflow Exhaust, Evolution Stage 4 Tune, BMR Carbon Fiber Drive Shaft, Steeda UCA & LCAs Currie 9" 1:3:75s True-Trac locker, Proglass Cold Air Hood, 36,500 miles---11.491 1/4 mile! 592RWHP
mobeydick is offline
Closed Thread
