slow to start - Diesel Forum - TheDieselStop.com
Old 05-16-2008, 03:26 PM   #1 (permalink)
My Photos: (5)
slow to start
Ok my 2006 6.0 is cranking loonger than usual to start, the batteries are up and I do the same thing all the time but it cranks over and does not fire, if I let is rest for a couple of seconds it will fire. I do the same routine, turn the ignition on wait for the heater light to go off wait an additional couple of seconds and then crank it. When it was cold out it never missed a beat now the temperature does not seeem to have any bearing on it.
So what could it be?
'06 Ford F-350 4X4 6.0 Bone stock, crew cab
Sold'01 Ford F-350 4X4 extended cab,
Banks Otto mind chip +90hp(?),
4" Red Deer exhaust,
Banks Transcommand.
Tymar Intake
Pillar mount Auto Meter gages: (EGT/trans-temp/boost)
'08 32' Wildcat QBBS '5er
buelligan is offline
Old 05-16-2008, 05:33 PM   #2 (permalink)
Sic4fitty's Avatar
I'm actually having the same issue with my 06. I was reading last night about turning your key to the on position and back off a couple of times to let the fuel bowl fill up. I did that today and it worked. Don't know what the problem is yet though.I'll keep you posted.
Sic4fitty is offline
Old 05-16-2008, 06:26 PM   #3 (permalink)
well first u nd to get a scan tool hooked up so that u can see if you are building enough icp(injection control pressure)...the pcm needs to c 600 psi to start. may be a high pressure oil problem or a fuel problem. gotta find which system to start in. good luck
dsltek is offline
Old 05-16-2008, 08:34 PM   #4 (permalink)
My Photos: (5)
OK here is an update, the truck died, flat lined, I was haulin' my 5th wheel and family to Mass. on I84, and that was it. The way it died leads me to believe it is an electricl issue if it was fuel wouldn't you think it would have bucked, back fire or farted? I think something was failing and now it has failed.
also checked all the fuses, dont know how to check a relay...
Banks Transcommand.
Tymar Intake
Old 05-17-2008, 06:41 AM   #5 (permalink)
Parts Jimmy's Avatar
Watch movie in my signature. Oil filters are a reason for prolonged cranking.
2000 F350 SRW Supercab 7.3 PSD
4" MBRP Exhaust with Donaldson M085171 Muffler,
SCT X3 w/DP-Tuner 60T-80T-80E ,
Transgo Equipped 4R100, Autometer Guages,
Donaldson/Motorcraft Air Induction System,
Ford AIC, Northstar 8.5 Adventurer,
Timbren Overloads, Code L Front Springs,
Bilstein Shocks, BFG Commercial TA Rubber,
Hella 700FF Driving Lights
6.0-6.4 PSD Motorcraft Filter Comparison Video
Fuel Quality Video
Parts Jimmy is offline
Old 05-20-2008, 04:56 PM   #6 (permalink)
My Photos: (5)
update:
dealer fixed the infamous connector at the HPOP, this one of ford's better ideas? I get sick of these ban-aids.
good news covered under 100k warr,
Banks Transcommand.
Tymar Intake
Old 05-20-2008, 05:21 PM   #7 (permalink)
ddduallyfan's Avatar
I'd know this cheezy movie anywhere...seems like I was watching this "next door". parts guy?
ddduallyfan is offline
Old 05-21-2008, 12:59 PM   #8 (permalink)
Mine is having same issue, however yesterday it went to starting and dieing immediately. Its at Bell Ford in Phoenix, AZ.
2005 4x4 f350 lariat dually 6.0
4" superlift, MBRP 409 cool duals, autometer phantom ii gauges, riderite air bags w/on board compressor,amp research auto steps, S&B intake for pulling a 2004 Weekend Warrior SLC3705 5th wheel
rampinator is offline
Old 05-22-2008, 10:37 AM   #9 (permalink)
They will install new one piece connector and all will be right with the world.
