slow take-off - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 07-04-2006, 12:44 PM Thread Starter
slow take-off
I have a new 2006 f350 dully. When I take off from a stop i have to push peddle half way down before it will take off is this normal or is there an ajustment I can make. Almost got hit taking off from a stop sighn on my way to work today
BIRD1964 is offline
post #2 of 11 (permalink) Old 07-04-2006, 05:07 PM
FamilyRide's Avatar
Re: slow take-off
Is it your first diesel? If so, you'll need to adapt to how a turbo diesel responds. If it's not a first, since it's new, the delaer may need to take a look at it, or you could have one that's just got a little more lag that normal.
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, bubba lights and newly added so called bullet proofing, including PMax turbo.
FamilyRide is offline
post #3 of 11 (permalink) Old 07-04-2006, 09:55 PM
Re: slow take-off
This is pretty much normal. Turbo lag - takes about 1-2 seconds before you have really good power to move the 8K lb machine. We as users can't do any adjustments on the engine unless you have the computer hookup to do it.
93 F350 7.3
04 F250 6.0 4x4 auto crew cab sb all the goodies
bigredtruckmi is offline
post #4 of 11 (permalink) Old 07-06-2006, 12:43 PM
Re: slow take-off
This truck definitely seems to have more than my '01 7.3. It's also very bad for the first couple of minutes until the engine gets warmed up. Just be aware of it and don't pull out into traffic in a bad spot. You can also combat it by holding the brake and giving it a little gas to spool up the turbo before you're ready to take off.
Rob Ellis
'04 Eddie Bauer PSD Excursion
'94 5.8L Bronco
'68 5.0L Bronco
robellis77 is offline
post #5 of 11 (permalink) Old 07-06-2006, 12:57 PM
thesavant's Avatar
Re: slow take-off
I was having this problem and it was my EGR valve stuck- does it blow a lot of black smoke when taking off?
2004 6.0 PS SC 4X4
3.73 gears,Automatic,1.5" Donahoe level kit 305X70X16 on Moto Metal
Bone Stock
thesavant is offline
post #6 of 11 (permalink) Old 07-06-2006, 12:57 PM
Re: slow take-off
Mine is the same way. It is really sluggish when it is cold and when it warms up it takes about 1 second to really get spooled up good. I thought there was something wrong also, but this is my first diesel and it is weird to not have it as responsive as my gasser, but I wouldn't trade back for anything. I will never own another gasser!!
And that's all I have to say about that.
2004 Platinum Edition F-350 PSD, 6.0L, 2005 Front End W/ Harley Davidson Grille & Smoked Headlights, Crew Cab, Long Bed, Sun Roof, 165 HP TS Chip, AFE Stage II Intake, MBRP Cool Duals W/ 6" Tips, Autometer Guages (boost, tranny temp& EGT's), 8" Tough Country Suspension Lift, 20" Ion Wheels wrapped in 38x15.5 Toyo MT's.
BadStroke is offline
post #7 of 11 (permalink) Old 07-06-2006, 01:19 PM
Re: slow take-off
Take it to the dealer.... It will be EGR and or injector related IMO.
awayne is offline
post #8 of 11 (permalink) Old 07-07-2006, 12:19 PM
Re: slow take-off
My truck has been like this since it was delivered. I did have a recall back around 15k miles and they replaced the EGR and something else. Absolutely no change.
Rob Ellis
'94 5.8L Bronco
'68 5.0L Bronco
post #9 of 11 (permalink) Old 07-07-2006, 02:42 PM
Re: slow take-off
Same with my '05 excursion...way more noticeable than with either of the 2000 model pickups with 7.3 powerstrokes. Add me to the list of satisfied people who have sold their 6.0 liter powered vehicles before they got t-boned.
arfmel is offline
post #10 of 11 (permalink) Old 07-07-2006, 03:47 PM
Re: slow take-off
Is it because it's a 350 or dually? My 05 250 doesn't seem to have any lag. The throttle is so touchy that I usually have to feather it 2 or 3 times to start off on a dirt road to get the tires to stay gripped.
2005 F250 XLT Sport CrewCab 2WD
Black Ext. Black/Grey/Carbon Fiber Int.
SuperChips
4" MBRP Off-Road Turbo back exhaust
Average 700 miles/week
KnapperBud is offline
post #11 of 11 (permalink) Old 07-09-2006, 11:21 AM
Re: slow take-off
Answer: Stick shift. Use the granny gear on take-off, tach it up to at least 3K before shifting, and you'll never know what turbo lag is.
Red 2002 F-350 XLT SRW 4x4 7.3L reg. cab 6-speed rubber floors traded at 50K for:
Red 2005 F-350 XLT SRW 4x4 6.0L reg. cab 6-speed rubber floors BFG 12.5x35 mud-terrains, no lift traded for:
Red 2008 F-350 XLT SRW 4x4 6.4 reg. cab 6-speed. Got carpet this time- audiophile stereo deletes rubber floors. BFG 12.5x35 mud terrains, no lift.
Traded at 45K for: Red 2011 F-350 XLT SRW 4x4 6.7L reg cab BFG 12.5x35 mud terrains, no lift. "optioned" out of- stick shift, rubber floors, audiophile stereo, fog lights, chrome step bars GRRRRR!
torino73 is offline
