Slow Turbo Spool - Diesel Forum - TheDieselStop.com
Old 08-17-2007, 08:58 PM   #1 (permalink)
Slow Turbo Spool
I need some help from you guys. Here is my situation:
I have a 2005 Ford 6.0
I installed a rebuilt Turbo on my vehicle. The rebuilt Turbo is a real dog off the line. Right at the top of first gear it finally spools up and the truck starts moving. I am running an SCT so I went back to the stock setting. Same problem. I did the KAM reset and VGT Relearn and had the same problem. I guess I felt like wasting $250 because I went out and purchased a Turbo Actuator and did the Kam Reset and VGT Relearn again. Same problem. I get plenty of Turbo Boost once kicks in it just takes a while. I am not getting any codes.
Any advice from the professionals?
Also, I have access to a Snap On Diagnostic Tool with the CAN adapter. Does anyone know what readings I should be getting form the turbo?
Thanks in advance for your help.
Josh
2005 Ford F250 Crew Cab, Banks 4" Exhaust, SCT Tuner From Spartan, Quadzilla Commander
1968 Ford 3/4 Ton with a 428 .60 over
jambroson is offline
Old 08-23-2007, 10:55 PM   #2 (permalink)
Re: Slow Turbo Spool
I'd be curious about this one. I just had a turbo replaced on my 05 350. Old turbo was really slow to spool. They said there was rust on the vanes.
The new (remanufactured) turbo doesn't reach 20psi until 2200-2500 RPM.
hacklemana is offline
Old 08-23-2007, 11:07 PM   #3 (permalink)
weasel79's Avatar
Josh
Sounds like the problem is elsewhere. Maybe a ebp sensor or egr sticking/slow reacting.
Is there any smoke? Anything else that is out of the ordinary? Or just slow spool.
When was the last time you changed your fuel filters? Air filter?
Any lights?(check engine)
2003 F-250SD XLT X-Cab short box March 03 6.0L Torque shift, manual 4x4 superwinch hubs, 121,000 miles,315/75/16 BF Goodrich mud terrains, autometer boost/fuel psi/tranny temp, AFE 4" straight pipe, tire clearance and guage photos
weasel79 is offline
Old 08-24-2007, 08:36 PM   #4 (permalink)
I would also like to know an answer to this question.
As for the EBP sensor, didn't one of the latest flashes disable it? Can it still cause issues??
2005 F350 6.0L CC Lariat
ciscofreak is offline
Old 08-24-2007, 09:49 PM   #5 (permalink)
weasel79's Avatar
I believe it was disabled on the 03 and early 04 models. Correct me if Im wrong. On an 05 they still use it.
weasel79 is offline
Old 08-24-2007, 09:56 PM   #6 (permalink)
you may have a exhaust leak at the y pipe to the turbo weasel79 is right it's only on the 2003 and early 04 ebp is programed out of the calibration and low fuel pressure and only 2003 and early 04 need vgt relearn
jpb620 is offline
Old 08-24-2007, 10:18 PM   #7 (permalink)
Ok, I was under the understanding that it was disabled on the 05s too.
Good to know....
Old 08-24-2007, 10:51 PM   #8 (permalink)
only the trucks with the icp sensor in the back of the engine 03 to early 04
jpb620 is offline
Old 08-25-2007, 12:44 AM   #9 (permalink)
Same problem mine experienced when the EBP went south. No low end boost until I got on it, then plenty. When I scanned my EBP sensor, Key On Engine Off, it was reading about 10psi higher than baro and map (they should be within .5 of each other).
Mark
2004 White F350 XLT, CC, SB, 4x4, 6.0L Auto, 3.73LS, Camper Pkg, Skid Pkg, Edge 2" Mini Spring Pack, Bilsteins, MBRP Exhaust, FluidAmpr, Elite Regulated Return (55 psi), Airdog, Weld Evo Velociti & LT285/75-16
Built: 11/03/03
4x4Mark is offline
Old 08-25-2007, 12:38 PM   #10 (permalink)
Mark
Hey mark how do you scan you EBP sensor? I think I need to do this on my truck as well. How much was it to replace that sensor? What part of Colorado do you live?
2005 F-250 6.0 Blue CC.,DVD,Kicker 500.2,2-10 P3's Boston Components..
jbgarner12@msn.com
Had to sell my baby..
2001 White F-250 CC 4 inch lift 325/60/17 MKW
BTS tranny,Hypermax stage 2 injectors,H2E Quick spool turbo,Dp-tuner chip,4:30 gears,AFE stage 2 intake,ITP fuel system,4 inch straight exhaust,Machined and ported heads,Forged rods,Beans Headstuds and other mods too many to name!!!((Sold)))
bagstroke is offline
Old 08-26-2007, 01:20 AM   #11 (permalink)
I use the Autoenguity software - lets you read quite a bit. Colorado Springs.
Mark
Built: 11/03/03
4x4Mark is offline
