Smog check - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 04-20-2017, 10:40 PM Thread Starter
Big Mac's Avatar
Smog check
Hi all. I live in Calif. where smog checks are required and have had several checks over the years with no problems. Today I took it in and everything was fine except I had a "computer/ PCM not ready". I was told that it had to "relearn" the driving parameters by driving it, which I did about 40 miles or so. I brought it back and still no go. What is the process of "relearning" ? I can't remember disconnecting the batteries recently and the only other thing I can think of that may have caused this is that it has been sitting for awhile,but the batteries are on a constant trickle charge from the solar panels I have on my camper unit and have not been even low as I had gone out and checked it. The truck runs great and has always been kept stock.
thanks for any help
97 F-250 ex-cab autotrans,downpipe,3gauge,pillerpod,aux. tran.cooler and filter,air bags. SOLD
New ride:2005 F-350 Lariat Ex-cab 4x4,Auto meter gauges ,In-dash Pioneer Nav.,Coolant filter,Timbrins,and Rancho 9000xl shocks. Supresprings,ScangaugeII,Seat heater mod,Heated mirror mod,aux. back-up lights,Daylighter driving lights
Big Mac is offline
post #2 of 18 (permalink) Old 04-21-2017, 09:20 AM
Phil G.'s Avatar
I'm not sure what all conditions the PCM needs to see to ready all systems but 40 miles might not do it especially if you just went for a 40 mile drive. It likely needs to see several restarts, cold starts, warm starts, WOT conditions, etc. If your in a hurry, the Ford dealer might be able to simulate all of this and get the systems ready with the IDS scan tool. Some vehicles, this can be done but IDK if the 6.0L is one of them.
2007 F350 SRW 6.0L Auto, 3.73LS, 172"WB 4x4. Viper Alarm/RS, WD pillar Guages,AutoEnginuity, 100gal polished alum fuel tank.
All Sold: 99.5, early03 , 2004 - all were 172" wb 4x4 lariat's.
My Worklog:
Phil G. is offline
post #3 of 18 (permalink) Old 04-22-2017, 12:39 AM Thread Starter
Big Mac's Avatar
Thanks Phil G. that is what I figured and have been driving the crap out if it and over the last few days have put over 100 mi. on it with both hot and cold restarts. Today I did a "WOT" wide open throttle which I do not do that often as there is a camper in the bed and I am getting a little up there in years( I also figured that I would save that for when I get a Mustang GT ..hope hope . I was hoping some one may know the factory what the recommended for this. I am just trying to avoid paying $60+ for another failed test. Thanks again for the advice.
Big Mac is offline
post #4 of 18 (permalink) Old 04-22-2017, 07:02 AM
ford_doctor's Avatar
thanks for any help
There are drive cycles that can be performed intended to help induce the proper conditions and driving modes to allow the OBD Monitors to run and complete which once done should clear the P1000 code indicating the system is ready. Then you should pass the smog test provided there are no codes in the system related to emissions. Here is the drive cycle you need from the 2007 WSM for the 6.0L PSD.
On-Board Diagnostic (OBD) Drive Cycle
Description
NOTICE:
Strict observance of posted speed limits and attention to driving conditions are mandatory when proceeding through the drive cycle.
Note:
Vehicles equipped with power take-off (PTO) or auxiliary idle control must have that system disengaged before the OBD drive cycle is initiated.
The primary intention of the OBD drive cycle is to clear the DTC P1000 and to satisfy the specifications for the Society of Automotive Engineers (SAE) specification J1979. Each OBD monitor must run during the drive cycle.
If the drive cycle is completed and P1000 is not cleared, repeat the entire drive cycle. If a particular step is interrupted, simply repeat the drive mode. If the drive cycle is interrupted with a key-off, only drive modes that were incomplete must be run.
Rough road conditions may prevent certain steady state conditions and steady accelerations from validating the transmission and load-related monitors.
Drive Cycle Procedure:
  1. Key ON. Do not crank until the WAIT TO START light cycles, or at least 10 seconds, whichever occurs first.
  2. Start the engine. Idle in PARK or NEUTRAL for 40 seconds.
  3. Before continuing, engine oil temperature (EOT) must exceed 60C (140F).
  4. The following outlines the appropriate conditions for running certain OBD monitors that require the engine to be under load:
    1. Accelerate steadily to third gear (M/T use fourth gear) and hold at 1,500 RPM for 3 seconds. Accelerate steadily from 56 km/h (35 mph) to 105 km/h (65 mph) over approximately 15 seconds (M/T 11 seconds minimum).
    2. Repeat Step 4.a. three times while maintaining the conditions in Step 4.a.
    3. Before proceeding, turn all accessories off and disengage tow/haul/overdrive cancel.
  5. Idle the vehicle for 20 seconds in PARK or NEUTRAL.
  6. Key OFF.
  7. Start the engine. Idle in PARK or NEUTRAL for 40 seconds.
  8. Repeat the Quick Test.
Note: If P1000 is present after running the drive cycle:
  • Repeat Step 4.a., being certain to maintain a minimum mass fuel desired (MFDES) of 35 mg/stroke above 2,000 RPM for 11 seconds. Also, maintain a minimum MFDES of 30 mg/stroke above 2,800 RPM for at least 6 seconds.
  • Repeat Step 8. MFDES must remain below 12 mg/stroke for 11 consecutive seconds.
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is online now
post #5 of 18 (permalink) Old 04-22-2017, 09:47 AM
Phil G.'s Avatar
That's what I was looking for. I have it for GM but could not find it for the 6.0L. To get my older GM gassers with evap issues to pass, I have to clear the codes on a cold day, run them through the drive cycle procedure then rush them into the drive clean center for a test. The Evap system will show not ready but we are allowed to have 1 system not ready and still pass in our area.
My Worklog:
Phil G. is offline
post #6 of 18 (permalink) Old 04-22-2017, 10:21 AM
chuckster57's Avatar
Calif isn't that lenient. ALL readiness tests have to be completed. I have to tell my customers NOT to run to the smog shop right after a repair and code clearing.
chuckster57 is online now
post #7 of 18 (permalink) Old 04-22-2017, 11:25 AM
Phil G.'s Avatar
It gets even better. I have a 2000 Explorer (only 60K miles) and it has to be smogged but it also only requires an OBD test and 2 systems can be not ready due to it's age...it probably only has about 4 systems monitored by OBD. Talk about a cash grab!
My Worklog:
Phil G. is offline
post #8 of 18 (permalink) Old 04-22-2017, 04:11 PM Thread Starter
Big Mac's Avatar
This is what I was looking for I want to thank you!!!
Big Mac is offline
post #9 of 18 (permalink) Old 04-23-2017, 09:29 PM
I have an 03 6.0. I live 33 miles one way from work. Do at least 66 miles a day. I go through Atlanta stop and go traffic, highway speeds, and typical city traffic at about 45 mph. I have found it takes me 3 days to passs all readiness parameters. Not sure what all the triggers are, but it takes a couple days/couple hundred miles for me.
GlennL is online now
post #10 of 18 (permalink) Old 04-25-2017, 09:27 PM Thread Starter
Big Mac's Avatar
Well I tried the drive cycle procedure several times with no success. I have put over 100 miles on it so far,this is a real pain. I took it to the Ford dealer out of frustration and was told they could not help that I had to drive it some more and that it could take several 100 miles. I am glad that I have till the end of next month before it is due. Is there anything else that causes this other than disconnecting the batteries?As I can't remember when it was that I last did that.
Big Mac is offline
post #11 of 18 (permalink) Old 05-16-2017, 09:59 PM Thread Starter
Big Mac's Avatar
I hate to bring this thread up again but I still cannot get my trucks computer to "relearn". I have driven about 575 miles since I started this post and my code reader still says 2 of 3 sensors (my term) have been read etc.
Is there anything that anyone can think of as to what else can be done?
Big Mac is offline
post #12 of 18 (permalink) Old 05-19-2017, 08:56 PM Thread Starter
Big Mac's Avatar
Well after talking with a rep. of CARB it was determined that the problem is most likely a build-up of carbon in the EGR passageways and that to remedy this should add cetane boost and "drive it like I stole it" to clear some of the carbon. The "interesting" question that he asked about the truck was "is it a Federal vehicle or a Calif. one" as the Federal one don't have to pass 3 monitors only 2? I know CARB sucks but is that right?
Anyway I will post the results when I get them.
Big Mac is offline
post #13 of 18 (permalink) Old 05-20-2017, 07:09 AM
It would be helpful to know WHICH monitor(s) are not completing. I recall from experience here in NJ if a vehicle fails an emissions scan the fault is provided on the printout. Assuming we are still talking about a 2005 6.0L your F350 in California is required to meet OBD-2 regulations if the GVWR is 14,000 lbs or under. The monitors include:
  • Misfire Monitor
  • EGR Monitor
  • Glow Plug Monitor
  • Comprehensive Component Monitor
  • MIL Control
  • Communication Protocol and Data Link Communication
Component monitors check engine/PCM inputs and outputs for circuit faults, rationality and function. If you knew which of these have not completed and cleared it would be easier to find out why. I would think that if a particular monitor just won't pass then there has to be a malfunction and likely a code set at some point. I have a problem with a CARB representative telling you to add cetane boost and drive it like you stole it. If there is a blockage or malfunction affecting EGR flow it should eventually set a code. If by chance it is a blocked passage which is rare, the blockage is not likely going to clear on its own and must be physically cleaned or the clogged part be replaced to restore flow. THEN you need to diagnose how and why it clogged and remedy the root cause. If you do have an EGR problem you do need to see someone with a good understanding of the 6.0L engine and the engine emission control as EGR is closely reliant on the turbocharger operation being in good shape too along with all of your air management pressure senors and the MAF sensor.
post #14 of 18 (permalink) Old 05-20-2017, 03:44 PM Thread Starter
Big Mac's Avatar
Upon checking with my code reader it says the EGR system is not ready. I have not thrown any codes and have not even had a P1000 code. The report I got from the smog station states "OBDII not ready" and lists EGR and/or VVT system. There are no driving issues and the truck runs great. To my knowledge it has never been modified,chipped etc.. I bought it used from a Ford Dealer,I don't know if any of that is important. I had no problem passing 2 years ago. I have a 3500lb. camper on the back so this is not my daily driver and I don't drive it hard. I do know that I disconnected the batteries at some time since my last test 2years ago.
I can't think of anything more to add at this point.
Big Mac is offline
post #15 of 18 (permalink) Old 05-20-2017, 04:08 PM
GOOD! Easy things to do are to pull the EGR valve out to inspect for excessive carbon build up and pay attention to the color of the carbon that is there. It should be black obviously but if you see any gray streaks or chunks that is a sign that the EGR cooler has a slow leak. That will cause the EGR passage between the EGR cooler and the EGR valve to clog with hard crusty carbon and dry coolant. Also, you could remove the IAT-2 sensor on the intake manifold and clean the carbon from it. It is located to the right of the secondary fuel filter housing as you are facing the engine you will find it easier to access if you remove the rubber intake tube. And lastly, while you have the air filter and intake tube off, clean the MAF sensor in the air filter cover with CRC MAF Sensor Cleaner. Do not use harsh chemicals or like carb cleaner or Brakleen as they will harm the sensor. Both the IAT-2 and MAF sensors are critical for determining EGR flow. The low flow/restricted EGR codes do not set easily and usually never do when there is a restriction.
