somebody explain this puking thing to a 7.3 guy..... - Diesel Forum - TheDieselStop.com
Old 05-19-2005, 12:28 AM   #1 (permalink)
just curious...what is causing it? my brother has an 04 and was wondering... [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2000 f 350 dually crewcab....DP
80 hp performance flash....autometer z- series gauges ....walker BTM..... If it should move and doesn't, use WD-40. If it moves and it shouldn't, use Duct Tape.
nodoubt1 is offline
Old 05-19-2005, 12:32 AM   #2 (permalink)
Re: somebody explain this puking thing to a 7.3 guy.....
Build up about 35psi boost, slightly lifting the heads off the block because of piss poor design, lose boost into waterjacket passages, exit out of overflow res. (PUKING) [img]/ubbthreads/images/graemlins/vomit.gif[/img]
loi1000 is offline
Old 05-19-2005, 12:33 AM   #3 (permalink)
Then again...you may not understand...it's a 6.0L thing. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
loi1000 is offline
Old 05-19-2005, 12:37 AM   #4 (permalink)
are they doing it stock or just with heavy mods??
nodoubt1 is offline
Old 05-19-2005, 12:43 AM   #5 (permalink)
Both, from what I understand.
loi1000 is offline
Old 05-19-2005, 08:57 AM   #6 (permalink)
unreal.........
nodoubt1 is offline
Old 05-21-2005, 08:02 AM   #7 (permalink)
My Photos: (5)
Rick M on this thread has a theory.
Scroll down to his post. I have no idea how this turns out.
Have a Nice Day.
kude
kude is offline
Old 05-21-2005, 11:33 PM   #8 (permalink)
Well, according to the tech doing the work the truck is getting a new crate engine which is the final resolution to this particular episode. I am still trying to find out the details and don't know if the truck ultimately had a sudden failure or what symptoms were exhibited before they decided to pull the motor, but the tech said the long duration of the slow leak at the failed solder joint in the EGR/COOLANT heat exchanger caused pitting inside the cylinder walls due to chronic water ingestion. That statement made me think about the coolant leak issue.
GOD BLESS OUR TROOPS!! - GOD BLESS AMERICA!!
Rick M is online now
