Someone figure this one out? - Diesel Forum - TheDieselStop.com
Old 07-10-2009, 08:13 PM   #1 (permalink)
Olehaggard's Avatar
will turn over want crank problem
It Had the p2285 code so i replaced icp sensor and ipr code is gone
Had bad wireing to boost sensor repair that and replaced boost sensor
The owner before me replaced cam senor it was bent so i replaced that
then i replaced the crank sensor still no luck
then last thing i thought it could be is the idm replaced that
other checks i did i checked the fuel for contaminents fuels good and pressure good
checked oil pressure put a gauge will 400 psi it tached out
had a battery charger on it eliminates the battery problem
took air filter out elimnates a bad air filter
no fault codes anymore
fuel in the top fuel filter
what else can i do to it
Steven Carroll
If you could give me a call 205-299-1911
Steven Carroll
Mikes Truck Repair
CAT,Cummins,Ford,Detroit
24 hour rd service
19706 hwy 11 Woodstock,AL 35188
205-938-1706
Olehaggard is offline
Old 07-10-2009, 08:17 PM   #2 (permalink)
ICP needs to see 500 psig minimum (oil) to attempt to fire the injectors.
Mark
bismic is offline
Old 07-10-2009, 08:22 PM   #3 (permalink)
Olehaggard's Avatar
wheres the best place to check it
Steven Carroll
Mikes Truck Repair
24 hour rd service
205-938-1706
Old 07-10-2009, 08:46 PM   #4 (permalink)
Mine did something similar and it ended up being the FICM. It did this twice (my fault) and both times it was the FICM and at least 3 injectors. Turn the key on and if you don't hear the injectors cycling then it is probably the FICM.
snakeyezzz is offline
Old 07-10-2009, 08:50 PM   #5 (permalink)
Olehaggard's Avatar
ya i replaced the ficm, i call it a idm thats the old name for it but they changed names and i forgot the new one haha
Steven Carroll
Mikes Truck Repair
24 hour rd service
205-938-1706
Old 07-10-2009, 09:01 PM   #6 (permalink)
Olehaggard's Avatar
and getting 500 psi oil pressure
Steven Carroll
Mikes Truck Repair
24 hour rd service
205-938-1706
Old 07-10-2009, 09:47 PM   #7 (permalink)
Well, I guess there is always the emergency fuel cut-off switch ...... or maybe wire chaffing.
How do you know you are getting 500 psig oil pressure? Where did you choose to get the pressure reading?
What year model truck and are there any mods?
Was the ICP wiring harness oil soaked?
Mark
bismic is offline
Old 07-10-2009, 11:54 PM   #8 (permalink)
Did you check your fuses? You said that you replaced the FICM. New one? If so, how did you get it programmed? New ones are unprogrammed.
misterc is offline
Old 07-11-2009, 12:06 AM   #9 (permalink)
Good questions .......... the answer is in the details.
Mark
bismic is offline
Old 07-11-2009, 01:52 AM   #10 (permalink)
Olehaggard's Avatar
i checked my pressure in th icp port, the year model is a 2004, and it really wasnt soaked and to the other question about the ficm i had it programmed and ive checked my fuses i think im going to pull the icp fuse out tommorrow and try and crank it but im lost as hell now i never had any problem like this
Steven Carroll
Mikes Truck Repair
24 hour rd service
205-938-1706
Old 07-11-2009, 04:07 AM   #11 (permalink)
Try throwing some more parts on it. Try a turbo, then an EGR valve, then a EP sensor, then another crank sensor, then an engine harness, then an oil cooler. That outta fix it. Hopefully you aren't some kind of mechanic working on a customer's truck.
I'm a mod friendly Ford Diesel Technician located in Sacramento California area.
Gofaster23 is offline
Old 07-11-2009, 04:08 AM   #12 (permalink)
There isn't an aftermarket security system installed is there (like a Ravelco that has a wired in security plug)?
Glow plugs or GPCM - check amperage to both banks?
Bad PCM?
Mark
bismic is offline
Old 07-11-2009, 10:30 AM   #13 (permalink)
dikkstarr's Avatar
Someone put gas in it.
The 6.0l motor has surpassed Hot Chicks as the greatest Money reducing Agent known to Mankind.
2004 F-250 Lariat late build 4X4 CC/LB auto,fully loaded with sunroof, power slider and backup sensors , White with 12" ICON lift, 6 superduty valved bilsteins, flip steering, 38" MTZs on 20x12 chrome Fuel Hostage wheels, stock gears, superlift truspeed, fumoto, high idle mod, large case high amp alternator, floating traction bars, airraid intake with elbow, 4" turbo back, studded, powerslots with hawk pads, billet grill, 55 watt HIDs 6000k heads and fogs, clear corners, 7" Eclipse AVN6620BT NAV w/ back up camera, massive JL stereo 300/4 and 500/1, 2 12s behind back seat, amp research steps, sirius, '08 diff cover, redhead steering box,, coolant filter kit, hush panels and door seal mod, quad pod with boost, EGT, water temp, and fuel pressure gauges
dikkstarr is offline
Old 07-11-2009, 02:34 PM   #14 (permalink)
OT
OT's Avatar
S..Im not a tec. just curious. IIRC..recently icp talked about. Said eng. would run with it unplugged..but..will it start unplugged? As mentioned...
Are glow plugs etc ok? PCM could be bad? Anyway to get one from another 04 or ? New one's aren't programmed. Do a simple plug/play & see what happen's? Update if u can.
IPR valve is involved with ICP but u say icp psi ok which may mean IPR valve is ok, but I'm sort of guessing? You might consider reinspect what you've already done..unless already done. Good luck!
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
Old 07-15-2009, 10:46 AM   #15 (permalink)
I have a 2005 power stroke that has been having problems with no power. When I start it it has a real bad idle. When I press the excelorator to the floor there still is know power. If it starts it runs rough.
Paully1958 is offline
