Is this sound bad? - Diesel Forum - TheDieselStop.com
Old 08-24-2006, 02:16 PM   #1 (permalink)
Is this sound bad?
Diesel's when you shut them off that make a high pitches sqeak. Almost as if the engine stops immediately and the belt keeps going causing the noise.
Is it bad? Can it be controlled? I hear it on Doges and Fords so what's the deal?
My 6.0 does this ever now and then. My 7.3 never did it.
2006 F250 (April 06), 4x4, Lariat, SuperChips 1706, Auto-Meter Guages, AUX-Box (PIE), 13,000 miles.
J_Calhoun is offline
Old 08-24-2006, 02:37 PM   #2 (permalink)
My Photos: (19)
Re: Is this sound bad?
My truck does the same thing and it seems to do it more when it's hot. Not sure why but I don't think that it is bad.
[b]2006 F-250 4x4 CREW Dark Shadow Gray <font color="#FFFUUUU">
6.0L Power Stroke Diesel</font> w/ TorqShift
4.5 Tuff Country Lift
35/12.50/18 Toyo Open Country M/T
18" MKW series 19 Wheels
4" SS HOG Exhaust
Stage 2 AFE Pro Guard 7 Intake
Superchip Flash Paq
<ul type="square">[*]2003 F-250 CC FX4 7.3L w/ 6-Spd Gray (SOLD)[*]2004 F-250 CC 4x4 6.0L w/ TorqShift Blue (SOLD)[*]2005 F-250 CC FX4 6.0L w/ TorqShift Black (SOLD)[*]2005 F-250 CC FX4 6.0L w/ TorqShift Dark Stone (SOLD)[/list]
DieselDocFX4 is offline
Old 08-24-2006, 03:00 PM   #3 (permalink)
General consensus on the 6.0 is that the noise is the turbo spooling down. Yes I know it sounds like it has bad bearings or whatever but my '06 has done it from day 1and there have been numerous posts over the years from others who hear the same noise.
'05 F350 Lariat DRW 4X4 6L Auto, stock.
Above replaced '91 F350 XLT Lariat DRW 2X4 7.3L 5 speed man.
jbdawson is offline
Old 08-24-2006, 03:03 PM   #4 (permalink)
Mine is a 06 and it has been doing it since day one as well. Just curious if there is something that I can do to avoid it.
Old 08-24-2006, 03:15 PM   #5 (permalink)
My '04 did it all the time, my '06 does it once in a while. With their high compression, I think the engine does come to a fast halt, and all the other spinning accessories cause a "chirp" on the belt. I'd consider it normal....
Terry
2006 F-350 Lariat SRW CC LWB 6.0, Torq-Shift, 4X4, Dark Stone with Arizona Beige, Captain's chairs, manual transfer case and hubs, Line-X. Perfect for 39,000 miles.
BigCreek is offline
Old 08-24-2006, 03:29 PM   #6 (permalink)
AllOutFirefighter13's Avatar
As BigCreek said, the high compression of this engine (and I think the 6.0s compression is actually lower than the 7.3s - someone correct me if I'm wrong) can sometimes cause a sudden stop of the crankshaft, while the inertia of the belt and accessories tries to keep the belt going. Basically it's a little slip of the belt across the crankshaft pulley. It's nothing to worry about, however, it would be wise sense to have a spare NEW belt on hand when you get some miles on your ride. If it's gonna break, it will do it when you're in the middle of BFE, and that could be one heck of a towing bill!!!
Also, as jbd said, there will also be this rattling sound coming from under the hood (and at the tail-pipe) that sounds like the turbo is just bouncing off of the housing. This is supposed to be considered normal, but I too would like to know why it actually does this. Just drive with no worries!!!
Joey
* '04 F250 XCab LWB 4X4 w/ FX4 *
* TorqShift *
* Manual 4WD *
* Carpet Delete *
* No. 2 ONLY *
* High-Idle Mod *
* Fumoto Valve *
AllOutFirefighter13 is offline
Old 08-24-2006, 06:06 PM   #7 (permalink)
From what I've heard about changing that belt, you won't be doing it on the side of the road!
Red 2002 F-350 XLT SRW 4x4 7.3L reg. cab 6-speed rubber floors traded at 50K for:
Red 2005 F-350 XLT SRW 4x4 6.0L reg. cab 6-speed rubber floors BFG 12.5x35 mud-terrains, no lift traded for:
Red 2008 F-350 XLT SRW 4x4 6.4 reg. cab 6-speed. Got carpet this time- audiophile stereo deletes rubber floors. BFG 12.5x35 mud terrains, no lift.
Traded at 45K for: Red 2011 F-350 XLT SRW 4x4 6.7L reg cab BFG 12.5x35 mud terrains, no lift. "optioned" out of- stick shift, rubber floors, audiophile stereo, fog lights, chrome step bars GRRRRR!
torino73 is offline
Old 08-24-2006, 06:54 PM   #8 (permalink)
I have an 04 6.0....when mine was new I had the belt chirp...Ford replaced the belts twice before Ford came out with an updated belt....mine no longer chirps....check with Ford they may have information on it....mine has the dual alternators.... [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
'04 F-250 Lariat CC LWB 2wd 6.0 Torqshift Dark Satin Green/Arizona Beige TRADED
07 F-250 Lariat CC LWB 4x4 6.0..Dark Stone/Arizona Biege Built 11/27 here on 12/06/06 picked up on 12/07/06...love the truck.....pictures soon...
http://community.webshots.com/user/khitch710
khitch710 is offline
Old 08-24-2006, 10:50 PM   #9 (permalink)
Goodyear Gatorback belt on mine...it used to squeak every time I killed it...hasn't done it once since the swap
...coming soon...
2004 Twin Turbo 5.9 F250
Hellmann Performance
Direct Injection Performance
TS Performance
DI Performance
Greg Hogue
Grand Rock Exhaust
Dynomite Diesel
DC Customs
UNBROKEN is offline
Old 08-25-2006, 09:46 AM   #10 (permalink)
just oil the belt real good and it won't make a sound. [img]/ubbthreads/images/graemlins/phoney.gif[/img] [img]/ubbthreads/images/graemlins/phoney.gif[/img] [img]/ubbthreads/images/graemlins/phoney.gif[/img]
No don't oil your belt, i was joshing you. my old 6.2 did the same thing and that belt lasted my 50000 miles.
STROKER
josh5708 is offline
Old 08-25-2006, 04:07 PM   #11 (permalink)
My Photos: (19)
If you put some liquid dish soap on your belts it helps also. It is also way better than any belt dressing and you probably will never change a belt again. Just put some in your hand and rub it on the belt no need to worry done it a million time on a million different vehicle and I have also never change a belt on any vehicle.
Diesel DOc
4" SS HOG Exhaust
Superchip Flash Paq
Old 08-25-2006, 09:11 PM   #12 (permalink)
you may be hearing the belt tensioner kicking back to the rest position. they tend to move a little more than the 7.3L's if you watch it while someone revs it up.
certified ford dealer 7.3L,6.0L & 6.4L diesel tech & foreman
dvtech is offline
