Speedo And Abs Question
Ok here is the deal. My truck ( 2007 Ford F250 diesel 4X4 / with edge attitude) started acting funny. The speedo goes to about 5 miles an hour and the jumps to 90. The Odometer is also going fast. I replaced all 3 sensors. One in the diff and 2 in the tranny nothing worked. Then I put a new cluster in from a friends truck to try that out, still nothing. So I began to diagnose a bit more. I left the front two sensors plugged in and unplugged the rear diff. sensor. I believe this has to do with the ABS. When I unplugged it everything goes back to working fine. Only difference is ABS light comes on because it is unplugged. I thought it might be the new sensor was bad as well. Ford gave me another and it did not work either. So now I am at a loss and have no idea what it could be. I am not getting any codes either. I also checked the pigtail to the diff and it is getting power as well. Please send me some help. Ford wants to just keep throwing parts at thousands of dollars. HELP HELP HELP
