start procedure after head gaskets help??? - Diesel Forum - TheDieselStop.com
Old 10-28-2009, 08:54 AM   #1 (permalink)
rcornwel's Avatar
morning all
i have 7.3 in my truck so i'm not up on some of the things with the 6.0. i need a little help if you would. to make a long story i work at an automotive garage, we have an 05 f350 that we just did head gaskets, oil cooler and egr cooler on. the truck should be ready to fire today and i wanted see what we need to do to prime the oil system. i know of the 7.3 we would need fill the hpop resevoir etc. keeping in mind what we did to this truck can any of you help me make sure we do this right? thanks for all the help
Rich
2001 Oxford White F-350 Lariet Super cab 4x4 automatic, powerstroke, X code springs, DPPI duels, pillar gauges, edge evolution
rcornwel is offline
Old 10-28-2009, 09:25 AM   #2 (permalink)
fill the oil thruogh the oil filter housing this will fill the hp oil resvor and it will start after a few second
outlawpony is offline
Old 10-28-2009, 09:33 AM   #3 (permalink)
rcornwel's Avatar
you mean just fill all of the oil for the engine through the filter housing or just a couple of qrts. just want to be clear.. thanks for the help
rcornwel is offline
Old 10-28-2009, 09:41 AM   #4 (permalink)
I add around 2 quarts into the resivour with the oil cooler off. Either way, youre not going to hurt anything, there is no priming procedure. It can take up to a minute of cranking, it'll start, run like crap for a couple seconds. Hold it at 2,000 rpms for 30 seconds or a minute and then drive the crap out of it get the air out of the oil/fuel.
I'm a mod friendly Ford Diesel Technician located in Sacramento California area.
Gofaster23 is offline
Old 10-28-2009, 09:47 AM   #5 (permalink)
rcornwel's Avatar
thanks for all the help. hopefully my tech witll be done with her in a few hours. heads are back on now.
rcornwel is offline
Old 11-02-2009, 05:33 PM   #6 (permalink)
rcornwel's Avatar
hello all
i have an update. truck is running but it is acting very sick.. she is billowing white/ grey smoke and will not rev over about 1000 to 1100 rpms. it is not throwing a code so i'm not sure when to start. running very rough like it is missing 4 of the 8 holes. if anyone has an ideas please throw it out there. i need to get this thing out of the shop!!
rcornwel is offline
Old 11-03-2009, 08:19 AM   #7 (permalink)
rcornwel's Avatar
help please!!!!
rcornwel is offline
Old 11-03-2009, 08:41 AM   #8 (permalink)
check the icp to see if it has enough if recheck ficm connectors and fuel pressure should show 50 psi of fuel
Old 11-03-2009, 08:49 AM   #9 (permalink)
rcornwel's Avatar
sorry for being an idiot but what is icp and check it for what? i can have him check fuel pressure. other thing is when running we seem to be getting a ton of blow by out the valve covers.. both of them. could that be an injector o ring?
rcornwel is offline
Old 11-03-2009, 01:41 PM   #10 (permalink)
yes can be oring check all injectors on that bank it will force the fuel out of the rail by allowing compression in to the fuel system also did he put new orings and coper rings on the tip of the injector that goes into the cup after tighten down the injector you will feel the ring compress if done with hand tools if replace orings and coper rings
Old 11-03-2009, 01:51 PM   #11 (permalink)
rcornwel's Avatar
no he reused the o rings etc. he did lube the rings etc. i have him pulling valve covers now
rcornwel is offline
Old 11-03-2009, 01:56 PM   #12 (permalink)
69cj's Avatar
New O rings and crush washers everytime. The washers also have a top and bottom side if I remember correctly and must be torqued.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident(SOLD)
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 11-03-2009, 02:08 PM   #13 (permalink)
rcornwel's Avatar
somthing tells me this is going to be an expensive learing process. just found a bent push rod..
rcornwel is offline
Old 11-03-2009, 02:15 PM   #14 (permalink)
69cj's Avatar
Just a tip that I have read on other sites. When you 1st turn the engine over, do it by hand with the glow plugs out. If anytrhing is bound or interfering you will find it without bending or damaging components. Sticking valves, froze lifters etc.
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
