Starting Easier and Why? - Diesel Forum - TheDieselStop.com
Old 12-08-2006, 08:03 AM   #1 (permalink)
compman72's Avatar
My Photos: (9)
My truck 2005 F250 seems to start easier when it is colder in the mornings. This morning it was 15 F. I turn the key and let everything cycle and then start. It lights right up. In the summertime when the mornings are warmer - it seems to take a few a little bit extra to start. I still let it cycle and everything in the summer as well. Nothing different is done.
2008 F250 XL Crew cab, manual 4x4, 6.4L, Job 3, TorqueShift, w/ Decor group, Camper Pkg, Off Road Pkg, LWB, Power Equipment Group, Tow Command, Knapheide Utility Bed with sliding top. Built 2/5/2008 & Purchased 9-1-08
08B07 Flash 1-16-09
Firestone Ride Rite Air Springs 3-20-09
Radiator (end cap leak) @ 34,100 miles 11-19-09
11B23 PCM Recalibration 4-11-11
Hydroboost Replacement (leaking Power Steering Fluid) @ 82,866 miles 7/25/11
Upper & Lower Hoses (new design) @ 90,000 miles 11/10/11
compman72 is offline
Old 12-08-2006, 09:56 AM   #2 (permalink)
Re: Starting Easier and Why?
My '06 seems to do the same thing. I really don't know why, but thought it might have something to do with the oil since the injectors are dependent on oil pressure, or so I have read. At least you are not alone.. It may just be the nature of the beast..Bob <><
2006 F250 Crew Cab, Wonderful wife, grown kids and sorry dog.
burninfilm is offline
Old 12-08-2006, 11:10 PM   #3 (permalink)
Ditto here.
2011 F-350 Lariat, SRW, C.C., LWB, 4x4, Dark blue pearl metallic
2010 Montana Mountaineer 345 DBQ (5th)
PerryB is offline
Old 12-08-2006, 11:30 PM   #4 (permalink)
ICP has to be at a certain minimum pressure before fueling is enabled. When the oil is thick, it hits that pressure faster (assuming everything is primed).
Where the engine stops can also affect the next start, a little bit - depending on where the cam pin is in relation to the sensor.
Tec80 is offline
Old 12-08-2006, 11:40 PM   #5 (permalink)
PoneyXpres's Avatar
The same happens for me. Best guess, cold temp strategy programming has something to do with it. More fuel maybe...
PoneyXpres is offline
