starts fine cold - Diesel Forum - TheDieselStop.com
post #1 of 16 (permalink) Old 12-13-2012, 05:23 PM Thread Starter
starts fine cold
2003 6.0 146000 miles,as it warms up misses and eventually dies,then have to wait till it cools to restart.what should i check and test?
markgyver is offline
post #2 of 16 (permalink) Old 12-13-2012, 05:35 PM
Welcome... Do you have a way to pull codes/ or have Scangage2 or Edge Insight etc to post icp / ipr readings?... What oil filter/oil maint. history/ miles on the oil?... See bismic's no start sticky first...b
03 F-250 CC LB XLT 3:73 rear/ almost stock/ early build/ 78,000 miles...03 F-250 ext cab Lariat Fx4 SB 3:73's /stock/187,000 all original injectors...FICM by Ed @FICM.COM / ScanGuage 2 monitoring the vitals...
03powerstrokeuser is offline
post #3 of 16 (permalink) Old 12-13-2012, 06:13 PM Thread Starter
no scanner as of yet,ive had it about a year,changed oil every 5000,changed fuel filters today.
post #4 of 16 (permalink) Old 12-13-2012, 06:47 PM
See if you can get hold of a code reader/friend or chain auto store to pull basic codes? Without these you will need to take it to the Ford guys to get it diagnosed. Did you use oem/racor filters= all important?...b
post #5 of 16 (permalink) Old 12-13-2012, 09:29 PM Thread Starter
yes ,motorcraft filters
post #6 of 16 (permalink) Old 12-18-2012, 01:43 PM Thread Starter
Redid the bubble in fuel bowl test,sure enough,bubbles were flowing,unhooked pass side fuel line at head,rechecked no bubbles.so what do ya think an inj oring or injector itself/ thanks for the help.
post #7 of 16 (permalink) Old 12-27-2012, 06:08 PM Thread Starter
So today i replaced 2 injectors( had already replaced the other 2 a year ago).still getting the air bubbles back into the fuel cup.truck starts good cold runs smooth as glass for 5 minutes or so.so i guess i have to replace the 2 injectors that i replaced a year ago.
added scan guage hpop is 800-900, fuel pressure is about 48. ficm varies i seen as low as 44.5 for a second but mostly 47-48
post #8 of 16 (permalink) Old 12-27-2012, 06:33 PM
IMO that fuel pressure is too low and your FICM is on the way out.
Mark
bismic is offline
post #9 of 16 (permalink) Old 12-27-2012, 06:41 PM Thread Starter
so i need the blue spring update and a ficm,but neither one of these accounts for the air bubbles in the fuel bowl or would it affect an injecter sticking?
post #10 of 16 (permalink) Old 12-27-2012, 07:44 PM
No, it seems you have multiple issues unfortunately. Ed at FICMrepair.com can get your FICM issues addressed for $250 - $350 (better than new).
IIRC Ford states that it is common to end up changing out the entire bank if one injector has allowed combustion gasses to back pressure into the fuel.
Mark
bismic is offline
post #11 of 16 (permalink) Old 12-27-2012, 08:45 PM Thread Starter
Thank you for the reply's. i thought i may have to replace the 4 injectors but i was trying to cheap out, just got laid off a week ago so cash is tight.will replace the other 2 injectors tomorrow. and ficm asap.
post #12 of 16 (permalink) Old 12-28-2012, 09:28 AM Thread Starter
UPDATE.......... When you do the bubble test make sure you block off fuel line from other side.bubbles will go right through fuel bowl and down fuel line to the head and out.giving false impression that you have located which bank has the leak. I've been working on the wrong side. until i took lines off at bowl and blocked with finger did i see what was happening.
post #13 of 16 (permalink) Old 12-28-2012, 11:50 AM Thread Starter
This is what I found
so i had 3 injector orings blown or sucked out,
post #14 of 16 (permalink) Old 12-28-2012, 12:38 PM
Paul H's Avatar
My Photos: (10)
Looks like 7.3 injectors to me
Paul H
OWNER
2004 Ford F350 6.0L Dualie 273.000 miles with Edge Insight, Early Build 8/03 with 03 engine 20 mpg running empty EGR delete running ELC all stock
1996 Ford F350 7.3L Dualie 343,000 Tony Wildman custom burn,5 inch stacks, good ole girl(in Avatar)
1995 Ford F250 7.3L Regular Cab 255,000 miles Sled Puller
Paul H is offline
post #15 of 16 (permalink) Old 12-28-2012, 12:48 PM
klhansen's Avatar
My Photos: (180)
Close but not quite. The 7.3 injectors don't have that screened port.
), AIS,
regulated return,
klhansen is offline
