Starts runs 1 sec then dies, then tries to start 3-4 times then starts - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 03-12-2011, 03:15 AM Thread Starter
Wasnt sure how to list my problem....anyhow in the morning or first start of the day it starts and runs perfect for maybe one second then dies. Then when you try to start it the next 3-4 times its tries to start but doesnt. Then after trying to start it a few times it starts perfectly.
Its almost like a gasser that has just a little bit of gas inthe carb to start it for a second then you have to crank it several times to get gas back up to the carb so it will start and stay running. After the first start of the day it seems to start fine until it sits overnight. Plugging in makes no difference. Any ideas?
DENALIAKITAS is offline
post #2 of 15 (permalink) Old 03-12-2011, 06:35 AM
I've had vehicles with similar problem in the past. I would check FICM voltage with a scan tool. Also recommend testing glow plug system.
2005 "F350", 6.0, Auto, CCSB, leveled on 35's. Powermax, 4" straight pipe, fuel cross-over, blue spring, SCT with tunes from Innovative, FICM with Hercules tune, rebuilt+ trans, blah blah blah.
junior426 is offline
post #3 of 15 (permalink) Old 03-12-2011, 08:01 AM
paintingman's Avatar
What year is that truck?
_________________________
2004 F250 6.0 PSD every day work truck
Jotto desk / laptop / printer for giving estimates
3000 watt inverter keeps drill batteries charged
4" tubo back MBRP cool duals
CFM+ intake elbow / Airaid cold air intake
SCT X3 from innovative diesel
Coolant Filter / Amsoil by-pass system
ATS Intercooler
Fluidampr / 200 amp alternator
ARP head bolts / Black onyx head gaskets
185cc Injectors 70hp+ / stock turbo
stage 1 fuel lines / cross over with fixed orifice
58 volt FIMC mod from swamps diesel
Airdog 2 with in tank fuel module upgrade Mag-Hytec Diff. and trans. covers
Aluminum degas tank
paintingman is offline
post #4 of 15 (permalink) Old 03-12-2011, 09:12 AM
rock_doctor's Avatar
When it starts then dies stop there and open the cap to the upper fuel filter. See if the filter is empty. It may be time for new fuel filters. When the FICM starts to go you get a rolling start, like trying to start a car with a flooded carburetor i.e. you have to keep the starter turning after it has starts to catch. A test would be to plug in the block heater and let it run over night. If it starts normally the next day then it could be the FICM (you already said this has no effect). Bad glow plugs will give also give you a rolling start but tons of white smoke plus the glow plug system on the 6.0 has been very dependable. I suspect a fuel issue. Either filters or a soon to be bad lift pump. As said we need to know the year of the truck. The FICM problems are seen in 2005 and newer trucks. I would change the fuel filters asap. Low fuel pressure will take out a set of injectors faster then asap....
rock_doctor is offline
post #5 of 15 (permalink) Old 03-12-2011, 11:08 PM Thread Starter
Its a 2003 and it has about 200 miles on both filters. I replaced them when i replaced the engine. Is there any fuel related anti drainback check valves anywhere that might be sticking?
post #6 of 15 (permalink) Old 03-13-2011, 09:00 AM
I believe there is in the top fuel filter. Ford recommends OEM filters only some aftermarket filters are shorter and won't close the valve all the way.
ATS Intercooler
Aluminum degas tank
post #7 of 15 (permalink) Old 03-13-2011, 10:19 AM
I found this on anther post
ATS Intercooler
Aluminum degas tank
post #8 of 15 (permalink) Old 03-13-2011, 11:47 AM
That was a good catch Paintingman. I was figuring it was a fuel issue but it could be a oil issue. These trucks run on oil pressure. No oil pressure and it will not start. If you do not have an oem filter with an oem cap that will absolutely cause the problem you are complaining about. It happens all of the time. I would make sure you have a motorcraft, fram or racor oil filter with the oem cap. If you do then put in a mechanical oil pressure gauge and watch the gauge when it starts. I bet you have no oil pressure until the 2nd or third start try. I would also, while you are at it, install a real oil pressure gauge in the cab. The one on the dash is nothing more then an idiot light that goes to the gauge center once you hit 7psi. So you could be chugging down the road with the gauge showing center scale but you only have 7psi...
post #9 of 15 (permalink) Old 03-13-2011, 07:22 PM Thread Starter
It does have a motorcraft oil filter but has napa fuel filters.
post #10 of 15 (permalink) Old 03-13-2011, 07:25 PM
Banned
NAPA fuel filters is a great suspect to start with.
Gearloose1 is offline
post #11 of 15 (permalink) Old 03-13-2011, 09:40 PM
see the post rough idle by tcob...ps all the best...the guys posting above won't steer you wrong either...b
03 F-250 CC LB XLT 3:73 rear/ almost stock/ early build/ 78,000 miles...03 F-250 ext cab Lariat Fx4 SB 3:73's /stock/187,000 all original injectors...FICM by Ed @FICM.COM / ScanGuage 2 monitoring the vitals...
03powerstrokeuser is offline
post #12 of 15 (permalink) Old 03-14-2011, 10:12 AM
I just fixed same issue with my truck. Check the fuel pump on the frame rail. That is what went out on mine. Changed the ICP, EGR Delete, check FCIM, ended up being the fuel pump.
2003 Excursion limited 4x4 6.0L
Paul919 is offline
post #13 of 15 (permalink) Old 03-20-2017, 07:42 PM
aggravated
will the check valve top broke off in the upper fuel filter cause a 6.0 not to start
aggravated is offline
post #14 of 15 (permalink) Old 03-23-2017, 10:45 PM
johnnygibs2's Avatar
Sounds like ur maf sensor went
johnnygibs2 is offline
post #15 of 15 (permalink) Old 03-24-2017, 06:04 AM
It is possible. Breaking things inside the filter bowl can happen from using aftermarket filters. If you are using them, it would be wise to switch back to the motorcraft filters.
If your problem continues, you should start a new thread. This one is fairly old!
Mark
bismic is offline
