Old 07-17-2009, 02:48 AM   #1 (permalink)
Steering Not Returning!!!!!!!!!
Ive gonna thur alot of troubleshooting and wasting money and the problem is still there.
4 moog ball joints (upper and lower)
brand new steering gear box installed
truck alined (0.1 +/-)
4 nitto grapplers (@ 70 psi all Around)
now what , what can be holding the steering from returning??
Please help im going nuts and driving my truck with a cast on my right wrist is bad just imagine not returning its like driving a boat around miami.
PiRiPi is offline
Old 07-17-2009, 02:52 AM   #2 (permalink)
Had the same issue. Had steering box replaced. Fixed. That was the 3rd one in 6 months.
04 X, 4x4, 6.0
Tony2Co is offline
Old 07-17-2009, 02:55 AM   #3 (permalink)
where did u get it at the dealer??? ordid u get a rebuilt one?
PiRiPi is offline
Old 07-17-2009, 11:58 AM   #4 (permalink)
What year is your truck..fill out your sig!
caryt is offline
Old 07-17-2009, 12:03 PM   #5 (permalink)
2005 2x4 6.0
PiRiPi is offline
Old 07-18-2009, 11:14 PM   #6 (permalink)
All dealer replaced under warranty as well as most all the front end in between all 3 steering boxes.
They said this last time the internals failed in the box. It sounded like I was really lucky it did not seize up driving down the road from the way they acted and what they said/did not say if you know what I mean...
04 X, 4x4, 6.0
Tony2Co is offline
Old 07-18-2009, 11:58 PM   #7 (permalink)
Supporting Member
PowerstrokeConverters's Avatar
My Photos: (23)
Send a message via MSN to PowerstrokeConverters Send a message via Skype™ to PowerstrokeConverters
Did you go to GAW yet? or dealer worked on it?
2000 F-350 7.3 PS ,4R100 Lariat Dually
http://i829.photobucket.com/albums/z...DSC02732-1.jpg
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
Wicked Wheel
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using SCT 100hp Performance tune.
Wastegate disconnected for now...
2005 front clip.
Train horns.
Zoodad mod.
CFM-plus
CCV rerouted
S&B CAI
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Camera,DVD,Nav.,Satelite Music.
Jason smooth topper.
Here but not installed: 4'' Ported Housing,ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.,TRU Cool tranny cooler (no time )
Pictures:http://photobucket.com/2000_F350
PowerstrokeConverters is offline
Old 07-20-2009, 01:11 AM   #8 (permalink)
ill go to the dealer i heard gaw is super expensive
PiRiPi is offline
Old 07-20-2009, 11:58 PM   #9 (permalink)
Asking the obvious here but want to check anyway. When they checked alignment it included caster, not just toe? I don't know if your truck is lifted or not but I've seen plenty of lifted trucks with messed up caster from trying to get the right driveshaft angle that had zero return to center.
I've had alot of steering box problems in other vehicles (sector shafts stripping, seal problems, top of the box blowing off) but have never had a steering box that caused return to center problems. Not saying it can't, just in my experience I haven't had it.
Reading it again now I see you are 2wd and all my experience is 4wd so probably not the issue but I'll post it anyway.
wrangler12 is offline
