Steering Play to left - Diesel Forum - TheDieselStop.com
Old 07-21-2009, 01:21 PM   #1 (permalink)
OK so my steering dampener went out and i didnt really notice untill it was out for about 1k, replaced the damper but the play in the left side of the steering hasnt went away, i have turned the screw ontop of the steering box and that helped for about 1 week then it returns to have the play in the left of the steering wheel, do i need to replace the steering box? i have looked at the ball jonts they all look good (maybe i dont know what i am looking for) can any one help ? when i drive down the road i have to make constent steering corections it fealls like the wheels turn left to right on there own it is ANNOYING !
06 Lariet FX4 6.0 Disel Fully Loaded Captins chairs Long Bed CREW Cab
tytrophen is offline
Old 07-22-2009, 02:19 AM   #2 (permalink)
Jack up the front and grab the top and bottom of the tire and try to rock it back and forth. Also check panhard rod, drag link for wear. If your truck is lifted or leveled you might have to adjust the drag link to center the wheel.
04 GMC 3500 4x4 dually LB7 duramax 04/04 F250 12/20/03 build date, XLT Supercab longbed 6.0l, 4X4, 3.73lsd, FX4 pkg, torqueshift, ESOF, silver/med. flint, 6cd, back up sensors, rear slider, camper pkg, big mirrors w/ heated/pwr glass, Sold
04/04 F350 Crew Cab long bed 6.0L lariat FX4 46K Sold
1998.5 Dodge 3500 4x4 dually 24valve cummins 160K (sold)
2005 Lance 835 Cabover Camper
1999 Sanger DXII ski boat
1975 Dodge RamCharger (sold)
1990 Sanger DX ski boat
1991 Dodge W350 Cummins SRW (sold)
pwrstrokn2004 is offline
Old 07-22-2009, 02:55 AM   #3 (permalink)
biofumes's Avatar
I'm having a similar problem, so I jacked up my truck, tried to rock the wheel and the entire wheel with rotor has play in it, so much the rotor is rubbing on the brake clips that hold the brake pads in place and its eating away at my rotor. I did not see any play on the ball joints, and there is no vibrating or noises, just the visual rotor damage. I have a 4x4, Do I have to replace the entire hub assembly?
"I refuse to tip toe through life only to arrive safely to death"
37 Toyos on 22 Rims
4.56 Gears
Fox Shocks
8' Fabtech Lift
Triple disk torque converter
billet oversized trans pan
25K Husky Hitch
biofumes is offline
Old 07-24-2009, 12:29 AM   #4 (permalink)
Ok Help me out here, my truck is 4x4 i had someone rock the steering wheel left to right gently with the truck off as i looked at all the ball joints the Drivers wheel moves left to right with no problem when i went over to the passenger side i looked at the rod that comes down to the top of the wheel and the rod that links the drivers and passengers wheel together i noticed that they were both moving back and forth but the passengers wheel wasn't moving, is it the ball joints on that side or the wheel hub? are the uper and lower rods connected together or do they both connect to the passengers wheel hub? ?
Old 07-24-2009, 01:18 PM   #5 (permalink)
HELP HELP
Old 07-24-2009, 10:04 PM   #6 (permalink)
The ball joints are the two connecting points between the axle and hub area. That is what allows the wheels to pivot. The tie rod ends are what is connected to each wheel and the pitman arm. If you can wiggle the steering wheel and you see the rods moving but the wheels don't attempt to move then you need tie rod ends. The ball joints are bad if you jack the front end up, place a bar under the tire and lift up and watch the two pivot points and if you see any play, replace them. If you jack it up and lift the wheel with the bar, there is no movement in the ball joints but the wheel still moves up and down like it is loose, then you have to replace the hub assemblies. The bearings are bad and are not servicable themselves, you have to replace the whole hub assembly.
2005 F250 LARIAT CC 4X4 6.0L PARROT CK3200 bluetooth car kit, Shaker 500 system, nice set of train horns, twin viair compressors and 5gal tank, 5" MBRP turbo back, AFE stage II intake, SCT tuner.
1996 F350 AT, IDM and switched ICP mod
1995 F250 SC AT, IDM and switched ICP mod, 6" susp 2" body lifts.
1994.5 F250 SC 5spd 4x4 IDM and ICP mod
bondsman is offline
Old 07-25-2009, 11:44 AM   #7 (permalink)
Yes i have determined it is the two tie rod ends on the truck, any one know the part numbers for them? Should i buy after market moog or ford ??
