Sterling 10.5" 3 Pinion OE Differential / try rebuild/fix before buying a TrueTrac - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By nuclrslug
post #1 of 7 (permalink) Old 07-26-2011, 04:34 PM Thread Starter
The impetus for this project was the addition of the OE aluminum cover and a fluid change. While I was in there I decided to see if I could actually get the OE "limited slip" function to work as it has never satisfactorily performed from day one.
The truck is a 2007 F-350 Crew Cab, 6.0 with 74,000 miles so I have the three pinion setup. On a 2 pinion I'm not sure how you'd get away with running as much preload as I did because you don't have the advantage of the 2 piece case. On a three pinion you can use the two case halves to compress the Belleville washers instead of trying to force the 2 pinions in the opening and getting the pin to line up. Anyway, this is about the 3 pinion setup:
I'm not going to get into removing axles, part numbers, tricks to keep the cover from falling into to drain pan, keeping track of your shims, torque specs etc. as that has been covered elsewhere. The one thing I will say is be ready to catch the diff once you get it clear of the housing as it is HEAVY! I'm going to focus on the bench rebuild of the differential itself and subsequent driving impressions.
I picked up the new Ford replacement rebuild kit. It contains: 3, 4 ounce bottles of friction modifier, 10 clutches, 10 steels and two each of shims .030", .035", .040", .045", .050", .055" and .060". It also contains an instruction sheet with all of the torque specs you'll need (except for the differential bearing caps).
I soaked the clutches in my 75-140 synthetic gear lube (Wal-Mart house brand) for over a day but a half hour should suffice.
After removing the 6 case half bolts and splitting the diff the stock clutches were in good shape, no galling on the steels, plenty of clutch material left on the clutches etc.
One thing to note was the original clutches had clutch material on the whole face of the steel backer while on the new replacement clutches the clutch material was variegated in an almost mosaic pattern. I'm not sure why, maybe it helps to evacuate oil and aid in lockup when pressure is applied to the clutch pack. To put it more clearly, the factory clutch material is a solid disc with no grooves or channels and bonded to the steel backer. The replacements are little triangular pieces of friction material in an alternating pattern each bonded separately to the steel backer. The original clutches and steels were arranged correctly. Clutch-steel-clutch-steel etc. It wasn't "wussafied" from the factory with two clutches or two steels stacked together.
The average measurement of each of the used original packs with 5 clutches and 5 steels only was .830" (one was about .827" and the other was about .832"). This is as they were removed from the carrier. The factory used a .050" shim on both sides and of course the Belleville washer that provides the tension. This gives me (.830"+.050")=.880" plus the Belleville washer for the stack height.
The new stacks were about .880" with the steels and clutches. I used the .030" shims (you'll see why below) so my total stack height was about .910". I didn't follow the Ford directions which utilizes a special measuring tool so you can devise the correct shim to use based on the carrier and clutch/steel characteristics. They already did that once at the factory and it didn't work.
Prepare to gasp and flame me on how my rear end will self destruct but the only "enhancement" I did was to use the original Belleville washer IN ADDITION to the new replacement.
So, the stock arrangement was
(Belleville-.050" shim-c-s-c-s-c-s-c-s-c-s-axle gear).
The "new and improved" arrangement is
(old Belleville-new Belleville-.030" shim-c-s-c-s-c-s-c-s-c-s-axle gear)
On my case this left just enough room to physically fit everything in the cavity with zero room to spare when the case halves were torqued back together - no gaps - no room - no "spring" on the Bellevilles, everything collapsed and tight. Just FYI, the Belleville washers are about .060" when flattened so my total compressed stack height would be about an inch.
I tried adding one of my old clutches to the new stack for an arrangement of:
(Belleville-.050" shim-c-s-c-s-c-s-c-s-c-s-C-axle gear).
But this was way too much as the old clutches were just shy of a tenth of an inch. This also pushed the last steel away far enough so it was about half on and half off the splines of the axle gear. It doesn't do any good to add a steel, they just act as shims at that point. If you tried to add a steel towards the outside of the stack such as this:
(Belleville-.050" shim-S-c-s-c-s-c-s-c-s-c-s-axle gear)
it would be totally disengaged from the axle gear splines and acting like another shim.
So, once again, as assembled is:
I put everything back together with my shiny new Ford aluminum OE cover and filled with 75-140 synthetic with NO FRICTION MODIFIER.
With both back tires off the ground I could only get the diff to unlock by violently shaking one tire back and forth several times. I put a wrench on a lugnut (tightened to 150 ft-lbs) and the nut kept getting tighter and tighter until I wasn't sure if I was going to break a wheel stud but the diff didn't spin.
On the first drive and first turn it was noisy and jumpy. I should have noted earlier that the replacement steels ship with a black oxide coating to either keep them from rusting or to aid in "break-in" or for some other reason, I don't know. Anyway, this coating is rather rough and I suspect that once some of it wore off it would settle down which it did.
After several circles in both directions, backwards and forwards it smoothed out considerably. I thought I was going to have to add the friction modifier but I don't, it's settled down that much.
Now, on a turn with no throttle applied the rear end will make almost a frog like "ribbet-ribbet" noise and you can feel the slightest shudder. If you apply a little throttle it will lock up and scrub the inner tire regardless of which direction I turn. I'm running 36" tires and I tried the same thing on a hard packed dirt road. It will still release (mostly) on a turn but the inner tire does leave a little scrub mark.
Long story short - the darn things works like I want it to now. To the naysayers, I understand that this little trick isn't for the faint of heart but I took a $160 gamble that I could get the factory unit to perform. If it blows up or self destructs - so what? It wasn't working before! If I couldn't get it to work I was going to buy a TrueTrac anyway so the outcome is equal. The most I lost is $160 on a rebuild kit but I potentially gained hundreds and hundreds by not having to purchase a TrueTrac, a bearing kit, set it up etc.
Total estimated time for a shade tree with air tools and half a clue like me; about 2 & 1/2 hours.
Hopefully someone will find this information useful.
UPDATE:
The rebuild is still functioning just fine but I decided to add the limited slip additive that came with the rebuild kit. I had the truck up on the lift for brakes all the way around so I decided to add 2 of the 3 additive bottles to the rear. Like I said, it was/is working fine but I got tired of people telling me that there was something wrong with my truck when i went around a corner. After I added the fluid and let it work in it cut the chatter down to be almost inaudible and you can occasionally feel just a little shimmy, not the make-and-break clunks like it was before. It still seems to function almost as well as before effectiveness wise.
So far I've got about 78,000 miles on the truck, 4,000 on the rebuild.
2016 F-350 Lariat crew long box Diesel. 1" leveling with snow plow prep, 295-65-20 Toyo AT's on stock rims, added factory roll bar, put on Bilstein shocks.
Old Truck
07' F-350 Crew, long box Lariat. 4" BDS lift, 20X9 MKW rims, 35x12.5x20 Toyo Open Country, stereo, Winch from old truck, Magnaflow exhaust etc. No tuner on this one. New Addition! - 2012 Mustang GT, 6 spd.
Old Truck
04 F-350 Lariat 4X4 Crew Cab 6.0, literally everything but moon roof and PTO. Good stuff: 4" lift w/35" BFG muds, Intake, exhaust, Edge-Juice/Attitude, AIC, Warn 12k Winch, stereo work etc, etc.
(Latest pics at the end of others)
nuclrslug is offline
post #2 of 7 (permalink) Old 01-20-2013, 04:08 AM
How's it holding up?
CADiesel is offline
post #3 of 7 (permalink) Old 09-18-2013, 10:42 AM Thread Starter
I've been meaning to update this for a while........
So far the truck has 108,000 miles and everything is still working just fine. After I added the friction modifier it took much of the chatter out like I said earlier. At 108k it will still grab and let loose around a corner but it still works like it's supposed to. On rare occasions I'll get someone in a parking lot that says "your rear end is making noise, there's something wrong with your truck". I usually just give them on "Ok, thanks" because I really don't want to go into a long explanation. From my description the "clunk" or "click" sounds like a big deal but it's nothing compared to a Detroit Locker or some of the older Jeep factory limited slips.
Short story long, I saved a bunch of money, the thing works, it's still working and I would definitely do it again. If I ever wear these clutches out I'll put the same thing in again.
Old Truck
Old Truck
post #4 of 7 (permalink) Old 06-25-2014, 11:05 AM Thread Starter
Update:
About 120k miles on the truck now. No problems, still works like it did at my last update.
post #5 of 7 (permalink) Old 06-25-2014, 05:16 PM
I was wondering! Thanks for the update! This will really help others out.
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, Quick Start 200 amp large frame alternator, 2 batteries January 2010; GPCM replace October 2011; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors, replaced brake pads for 1st time 1/7/12 101K miles; GPCM, both subharnesses and all 8 glowplugs replaced 1/5/13 at 118,000 miles; 2 Ford batteries replaced under battery warranty twice, the latest 9/18/2015; FICM power supply board replaced with Dorman board 11/20/13. Coolant flushed and replaced with Prestone ELC 9/27/14. STC fitting 10/19/14; Dummy Plugs 11/8/14; Turbo rebuilt 11/29/14; cold side CAC tube and boots replaced with metal tube 1/24/15; replaced hot side boots 1/30/16.
Ford06 is offline
post #6 of 7 (permalink) Old 02-20-2016, 07:15 PM
Devilduck48's Avatar
I'm curious, is it still good and everything the same? Also did you get the clutch pack from ford or somewhere else?
Devilduck48 is offline
post #7 of 7 (permalink) Old 05-30-2016, 11:05 PM Thread Starter
Just traded the truck in a few weeks ago with about 134k miles on it, no problems with the diff. It did loosen up just a little bit but it was still fully functional the whole time. I bought a 2016 SD Lariat/crew etc. etc. with the electronic locking diff. At this point I kind of miss the one I rebuilt mentioned above, it was nice to have the limited slip all of the time. Now the rear is either locked like running a spool or open. I miss the functionality of the LS when accelerating in the rain or going around the corner under acceleration.
Also, I used all Ford products from the dealer parts counter.
Wish list: Limited slip rear end with a lock function.
Devilduck48 likes this.
Old Truck
Old Truck
