still having a sputtering problem - please help!!!!!!! - Diesel Forum - TheDieselStop.com
Old 07-30-2009, 11:12 AM   #1 (permalink)
JohnnyDiesel's Avatar
Send a message via AIM to JohnnyDiesel Send a message via Yahoo to JohnnyDiesel
Exclamation still having a sputtering problem - please help!!!!!!!
OK, as some of you know. I was having a sputtering problem under WOT.
I took it to my buddy @ Ford, who is a Diesel tech there.
He checked everything out.
I had 2 bad D-rings and had the injectors replaced.
He checked the ICP sensor, but said it checked out OK and didn't replace it.
he also installed head studs and replaced my head gaskets. So I held off on putting my tuner back into my truck for a week to make sure everything was seated properly before I put any type of added pwoer to the truck.
I re-installed my Diablo tuner in the truck just for sh*ts and grins to see how their new updated tunes work. they work fine, driveability is great. But now again, under WOT i'm getting that sputtering.
What do you guys think this could be????
It has to be fuel related. I know with the tuners, it demands more fuel. Do you think that the injectors are too small? or the ICP still could be bad and it's not showing without the tuner since it's not demenading as much fuel??? or possibly the fuel pump doing weak or bad???
Input guys. Thanks.
2006 Ford F-250 XLT 6.0L Turbo Diesel
2" Pro-Comp Leveling Kit
35" Pro-Comp Xtreme A/T Tires
ARP Head Studs
4" Turbo Back Flo-Pro Exhaust System w/ 6" Chrome Tip
AFE Stage 2-Type Si Cold Air Intake
SCT X3 Tuning Device - IDP Xtreme Race Tune
Autometer Pro-Comp Gauges
* Boost
* Trans. Temp
* Pyrometer
JohnnyDiesel is offline
Old 07-30-2009, 11:24 AM   #2 (permalink)
Have you changed your fuel filters? Maybe a little dirty and not letting fuel through.
onyx is offline
Old 07-30-2009, 11:54 AM   #3 (permalink)
Yeah, I just changed them maybe 2 months ago.
ARP Head Studs
* Boost
* Trans. Temp
* Pyrometer
Old 07-31-2009, 07:38 AM   #4 (permalink)
Anyone else have anything to add? Something I can try?
ARP Head Studs
* Boost
* Trans. Temp
* Pyrometer
Old 07-31-2009, 07:53 AM   #5 (permalink)
The most common reason (according to Ford) for injector problems is low fuel pressure. This can be from poor filter maintenance or from a weak pump or from restricted lines. Anyone running a tune should install a fuel pressure gauge IMO. You may have a a low fuel pressure issue that took out your injectors in the fisrt place and it may be on its way to doing it again now.
Mark
bismic is offline
Old 08-01-2009, 01:06 PM   #6 (permalink)
Thank you!
That is some great info. I'l do that today.
ARP Head Studs
* Boost
* Trans. Temp
* Pyrometer
Old 08-03-2009, 12:45 AM   #7 (permalink)
i see you have a SCT in your sig why are you running a diablo. the diablo is the most dangerous tuner to run on a 6.0.
halerazor is offline
Old 08-03-2009, 10:57 AM   #8 (permalink)
I let them revamp their tunes using my truck, so they gave it to me. I am putting my SCT back in as soon as I can find it. It's MIA right now
ARP Head Studs
* Boost
* Trans. Temp
* Pyrometer
Old 08-03-2009, 01:20 PM   #9 (permalink)
smokinporsche's Avatar
Originally Posted by JohnnyDiesel View Post
Thank you!
I have the SCT tune and mine had similar issues at start-up. I added the AirDog 150 and shazam! no more lack of fuel issues! Just a quieter, smoother running truck!
smokinporsche is offline
Old 08-03-2009, 06:38 PM   #10 (permalink)
I'll keep that in mind. I'm still trying to find my X3 so I can data log my fuel pressure.
ARP Head Studs
* Boost
* Trans. Temp
* Pyrometer
