Stripped HFCM Drain Plug - Diesel Forum - TheDieselStop.com
Old 07-15-2009, 03:54 PM   #1 (permalink)
Well, I finally succeded in stripping the HFCM drain plug. I have 65,000 miles and a 100K ESP. Should this repair be covered under my Extended Service Policy or am I stuck foooting the bill for the parts and repairing it myself?
Thanks!
PJ
Delivered: 29SEP05
2006 Black F-350 Lariat Crew Cab Long Box Single Rear Wheel FX4; 6.0L PSD w/ TorqShift; Tan Leather Captains Chairs (Heated); 6 Disc CD Player; Manual Locking Hubs; Engine Block Heater; Power Moon Roof; Power Rear Slider; FX4 Package
Camper Package; Snow Plow Prep Package; Tow Command System; Power/Heated Telescoping Trailer Tow Mirrors; Upfitter Switches; Roof Clearance Lights; Dual Alternators; Reverse Vehicle Aid Sensors
Add-on's: Line-X Bed Liner; Weather Guard Diamond Plate Cross Over Tool Box; SEIC; Cobra 29 Classic with Wilson Trucker 5000; Rechargeable Mag Light; Key in ignition dinger delete; Toyo Open Country M/T 35x12.5x18; KC Daylighters mounted on Trailer Tow Mirrors; Back Rack w/ 2 KC Flood Lights; Herculiner on rockers; Custom Extang Tonneau Cover; MBRP Turbo Back Exhaust; SCTX3 & IDP Tunes; ZooDad Mod
pkravetz is offline
Old 07-15-2009, 04:44 PM   #2 (permalink)
your ESP will still cost you the $100 deductible, I take it that it is still in the HFCM? you can buy one that extends outside the HFCM so that this will never happen again (you can use pliers if needed), get an extra 6 mm allen wrench, try to JB weld it inside the hole of the drain plug, use tape ect to hold it until it hardens, then after getting replacement plug, take defective one out and replace. main thing is to clean out the old plug before getting the allen wrench in there, make sure it gets in there all the way. I am not sure if the ESP will pay for this?? Good Luck.
2004 F-250 Crew Cab XLT, Auto, Short Bed, Arizona Beige, Fx4/Camper Pkg., 265's, Built 4/23/04, Delivered 4/27/04
Retrax Bed Cover,Crimestopper Alarm/ Keyless Entry/ Remote Start/ Skweeker Idle Up Mod/ Marinco Built in Heater Plug/ Dieselsite coolant filter
My Truck
2004/1997 Powerstroke Pics, Ford 9N Tractor,6.0 Bible
dwelch1 is offline
Old 07-15-2009, 06:35 PM   #3 (permalink)
Supporting Member
my03psd's Avatar
This is what you NEED trust me!....Diesel Technician Society
3/28/03 F250 6.0L PSD ,TORQSHIFT,CC,SB,FX4,LARIAT
Charcoal Gray/Black,
Tint,RhinoLined,Sirius,Roll&Lock,Strobes,
SCT X3 Custom Tuned by Innovative,
MBRP Stainless 4" Turbo Back,
ISSPRO Pyro,Boost, & Trans Gauges
Prodigy Brake Controller,Remote Start and Turbo Cooldown,
High Idle Mod., PM-13A on the Oil Pan,
HFCM Plug Upgrade,DieselSite Coolant Filter,
Energy Suspension Bushings,& Stanadyne every tank
my03psd is offline
Old 07-15-2009, 08:59 PM   #4 (permalink)
thats what I have on my truck, a much better set up!
My Truck
dwelch1 is offline
Old 07-15-2009, 09:17 PM   #5 (permalink)
OT
OT's Avatar
pj..under search..type in.."hfcm drain plug stripped." Dont know on warr.? Just thinking u might need a good convincing story? Good luck
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
