Stripped water/fuel seperator drain - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 12-30-2006, 06:43 AM Thread Starter
What am I going to have to do now to drain this thing? Remove the HCFM and slot the plug?
2003 Excursion Limited 4WD 6.0L PSD|SCT tuned by Innovative Diesel|MBRP 4 Inch Turbo Back, No Muffler|Mac Performance Intake|Bully Dog Outlook Monitor
MMor101 is offline
post #2 of 8 (permalink) Old 12-30-2006, 06:48 AM
Re: Stripped water/fuel seperator drain
If you're still under the 5 year/100K mile warranty, take it to the dealer and let them fix it. They'll likely replace the entire little manifold on the side of the HFCM (the part that has the drain plug in its cover), especially since you have a 2003 truck which was covered by a TSB to replace that part when the water in fuel light would go off erroneously due to crud buildup.
The new part should come with a steel plug instead of brass, which will fix the problem permanently. You can live with that, or do what a lot of us have done and upgrade to the knurled-knob plug as used in the LCF trucks sold by Ford and International.
Duncan
The 1997 F250HD Crewcab:
The 2000 XLT Excursion <font color="red">(SOLD)</font>:
The 2003 F250 Crewcab 6.0L:
The 6.0L Bible:
The 6.4L Bible:
frobozz is offline
post #3 of 8 (permalink) Old 12-30-2006, 06:57 AM Thread Starter
oh sweet, thanks, ill make an appointment with the dealer right now.
MMor101 is offline
post #4 of 8 (permalink) Old 12-30-2006, 08:40 AM
also do a search....this has been covered numerous times.
2005 F250 Lariat FX4 Crew Cab. NO MODS = NO PROBLEMS. (Approx: 65k miles) Shaker 500!
FHAREN is offline
post #5 of 8 (permalink) Old 12-30-2006, 08:48 AM Thread Starter
The search on this forum is very innacurate, ive tried.
MMor101 is offline
post #6 of 8 (permalink) Old 12-30-2006, 09:02 AM
I haven't had this problem. But someone once recommended JB Welding the allen wrench to the stripped plug head to get it out. Of course you would want to have the replacement plug ready to put in. I'm not sure if this will work, but it's an idea worth considering anyhow. Good luck.
2005 Arizona Beige F350 XLT FX4 6.0 CC shortbed, 3.73 ls rear, 18" wheels, Tow Command. Additions: Vent Visors, bug guard, Fumoto Valve, Timbrens. Traded for...
Current Truck -- 2008 Black F350 XLT 4x4, 6.8 V10, CC Long Bed, 4.10 rear, 18" wheels, IBC. Additions: Chrome Step Bars, Chrome door handles, Silver barbed-wire pin stripe, B&W Turnover GN ball
barrelhorses is offline
post #7 of 8 (permalink) Old 12-30-2006, 11:03 AM
NickBeek's Avatar
If the dealer won't fix free, you can use a center punch and hammer to remove it. Put center punch near outer diameter and start hitting with the hammer. Once it starts to dig in angle the punch so that it will loosen the plug and continue hitting it until it breaks it loose.
You might also try using the ball end of a ball peen hammer to hit the hex on the plug, this will flare some metal back into the hole and tighten the hex back up, then put your allen wrench back in and hit the allen wrench while trying to turn it.
These are old machinist / mechanic tricks that have worked for me in similar situations.
2006 2500 SLT Mineral Grey, 6 speed, 4x4, Thunder Road Package, MBRP Muffler + 6" dual Stacks, Fast Idle Enabled. Silencer Ring MIA, CFM+ intake horn, Smarty POD, SB Con OFe.
Traded:2004 F250CC FX4 XLT Long Bed Torque Shift, $5.00 AIC.
NickBeek is offline
post #8 of 8 (permalink) Old 12-30-2006, 01:10 PM
ta152h0's Avatar
Of note here, after you get it fixed. The seal is accomplished by the o-ring, not torque. Just be really carefull when inserting the plug and only use mild force when torquing the wrench,
Wolf
Kentucky built 2004 Silver F-250 XL Reg Cab PSD, 4X2, bench cloth seat,air conditioning, 6 spd Manual, 3.73 LS,Line-X , FORD receiver, Prodigy brake controller,towing option,( put together on Monday, March 29, del April 9 2004) 62000 miles
ta152h0 is offline
