Stuck in 4x4 Low Range - Diesel Forum - TheDieselStop.com
Old 08-28-2006, 03:53 PM   #1 (permalink)
My 04 350 is stuck in 4x4 Low. It has the stupid little switch in the dash, not the more reasonable shift lever to engage 4x4. I only put it in low to slide it under my camper in the back yard and now it won't come out. Called the techs and they told me to drive it around the block and it should come out. It didn't. I kept one side on the gravel so it wasn't all 4 on dry pavement but no luck.
Has anybody else had this problem, is it common?
The thing is still under warranty so I can get them to tow it in and fix it but if it happened when I was in the boonies I wouldn't be very happy.
AcStark is offline
Old 08-28-2006, 03:58 PM   #2 (permalink)
Re: Stuck in 4x4 Low Range
Read the information in your manual, I made this mistake, cannot remember how I got it out but it was in the manual.
03 F-250 SD XLT Crew Cab, Long Bed 4wd 3.73 LSD 6.0 5sp auto
Adnshel is offline
Old 08-28-2006, 05:15 PM   #3 (permalink)
How are you trying? You have to shift into nuetral, press the brake pedal, and switch out of 4 low. Wait for the 4 low light to go out. It usually takes a second or 2 before releasing the brake. If you don't hold the brake down and have the tranny in neutral, it will never shift out.
2005 F-350 FX4 XLT 4x4 CC/LB Torqshift with Diamond Back ATV Truck Cover, Zoodad Mod
Banks Power PDA with Monster Exhaust and Accufab intake elbow from Innovative Diesel
35x12.5x18 Toyo MT with 2.5" leveling kit, 2005 Weekend Warrior FB2200 for the toys
tzurick is offline
Old 08-28-2006, 05:21 PM   #4 (permalink)
Take thetruck and shift it into drive, pull forward a little bit. Put the truck in to neutral, and then shift into revesre, and then shift into drive. If that does work take a rubber mallet and smack the crap out of the transfer case. Had this happen in my ranger and that would always work.
2007 Ford F-250 Lariat, Extended cab, Single SS 4" MBRP w/ Cat delete pipe, Triple Pillar, Boost, Pyro, Trans, and more to come!!!
honkey84 is offline
Old 08-28-2006, 06:22 PM   #5 (permalink)
1SickHarley's Avatar
My Photos: (15)
My 04 does this everyone once in awhile. Do the drive reverse thing, then neutral. When in neutral mash the brake pedal HARDER. Usually that does it for mine. The neutral safety switch or whatever it uses might not be reading the trucks in neutral. Works for mine everytime. Good luck.
Edit..... manke sure the A/C is off.
NEW TRUCK.... 2007 Jeep Grand Cherokee SRT8 Black, Magnaflow Exhaust, Volant Cold Air Intake, and a nice system....
GO GATORS!!! 2007 National Champs Baby!! Ummm... Football AND Basketball
04 Harley Edition Solid Black, 8" Fabtech shocks and hangers and ladder bars, Superlift Springs, 38x15.50x20 Toyo Open Country M/T's, Weld 20x12 Cheyanne 8 rims, Fabtech Ladder Bars, AFE Intake, straight exhaust, SCT with Extreme Street from Eric at Innovative, Full SunCoast setup, SPEARCO INTERCOOLER(Thanks BBunting), Mag Hytec Tranny Pan, GReddy Turbo Timer,Alpine IVAD300 Flip out DVD player, Alpine 5 channel amp, JL 6x8 Seperates, JL Audio 12W7 Sub., JL Audio 500.1 amp., ISSPRO triple guages, sunroof, diff covers powder coated comp. orange, 03 Turbo, and oh yeah... 2005 Harley Edition Headlights.
My truck pics... http://community.webshots.com/user/1SickHarley
1SickHarley is offline
Old 08-28-2006, 10:18 PM   #6 (permalink)
I had tried everything that has been suggested in earlier posts. What finally worked was beating in the transfer case shift motor with a plastic hammer. I guess I will have to add a nylon hammer to my F-Series tool kit.
Thanks to all who gave me suggestions. Tomorrow I go to the dealer to try to get the shift motor replaced.
AcStark is offline
Old 08-28-2006, 11:06 PM   #7 (permalink)
STG
My friends in California mocked me for getting manual hubs and a manual transfer case shift lever. My new Wyoming neighbors say, "It's too bad you can't get those on a Lariat!"
Stan
2005 F250 4X4 SD R/C Power Stroke / Torqshift
Oxford White, Medium Flint 40/20/40 Vinyl, Prefered Equip. Pkg. 600A , 3.73, Limited Slip, XL Decor Pkg., Jeweled Headlamps, Chrome Rear Step Bumper, 9600# GVWR Pkg., Engine Block Heater, Sliding Rear Window, Speed Control / Tilt Wheel, Camper Pkg., FX4 Pkg., Air Conditioning, Forged Aluminum Wheels-17", Tow Command, Telescoping TT Mirrors. Using this vehicle to produce an ambulance voids Ford warranty. Added: Ford factory upfitter switches, Go Industries Rancher Grill Guard (hammered powdercoat), Hella 4000 Rallye lighting (two Euro Beams), SnugTop Super Sport camper shell, Jotto Desk & Escort Redline Radar/Lidar Detector.
STG is offline
Old 08-29-2006, 12:01 PM   #8 (permalink)
LMAO!!!!!!!!! Dude that sounds right on the money. I was born and raised in Wyoming by the way... [img]/ubbthreads/images/graemlins/smokin.gif[/img]
'06 FORD F-250 FX4 CREW Dark Shadow Gray <font color="#FFFUUUU">
6.0L Power Stroke Diesel</font> w/ TorqShift
2.5" Daystar Level Kit & 4" Tuff Country Rear Blocks
7" In-dash Jensen DVD Player w/ Polk Audio Surround Sound
[b]<ul type="square">[*]1996 F-350 Singlecab 4x4 7.3L Diesel (SOLD)[*]2003 F-350 Supercab FX4 6.0L Diesel (SOLD)[*]2004 F-250 Supercab FX4 6.0L Diesel (SOLD)[*]2004 F-150 Supercab Lariat 5.4L 3V White (SOLD)[*]2004 F-150 Supercab Lariat 5.4L 3V Black (SOLD)[*]2004 F-150 SUPERCREW Lariat 5.4L 3V Black (SOLD)[/list]
jsoltis is offline
Old 08-29-2006, 12:26 PM   #9 (permalink)
Teebird's Avatar
I had a hell of a time getting my '78 Chevy Blazer in 4wd hi or lo with the NP203 xfr case converted, by me, to part time. Bought my 96 Chevy with the 'push button' 4wd and worked like a champ, after I performed the service bulletin on it. That's why I got the push button.
2003 F250 XLT 4x4 Sport Crew Cab,
Built May '03, Bright Red, 6.0 Auto, ESOF 4x4, 3.73LS, 4.5" Edge Lift, 315/75-16 BFG KO A/T's, Polished/Clear Powder Coated Diff Covers, Weld Cheyenne 8 Wheels, Line X, Overhead DVD, Torza Tonneau Cover, 30' Fleetwood Gearbox Travel Trailer
Teebird is offline
