stumbling/bucking - Diesel Forum - TheDieselStop.com
Old 12-22-2009, 05:52 PM   #1 (permalink)
stumbling/bucking
As the title says, my new to me '06 F350 6.0L 4x4 cc 6spd 146,000mi. is bucking/stumbling (more of a bucking, like a gasser with bad plug wires) and no smoke at highway speeds under med. load(climbing hills,maintaining speed uphill). I can power through it. I have searched the forums and done some tests.
I cleaned and unplugged the egr for test purposes with no change.
I don't think it's the TPS because it does it with the cruise on.
I don't think it's the VGT solenoid because the boost gauge doesn't fluctuate. I assume it would do that if the turbo vanes where changing enough to cause a surge/bucking.
I did notice today it only seems to do it above 1800rpm. If I drive at 60mph/1750rpm it does not seem to do it. If I drive 65/1850 or a little more it will do it.
Is it possible it could be a cam sensor?
His-'89 F350 Cummins dually ex.cab 5sp XLT 463,000+mi.,VDO Vison guages,F700 intercooler,4in.exh.,K&N,Onboard air
Hers-'06 F350 cc 4x4 6spd XLT 6.0L 147,000mi.
ZUNK is offline
Old 12-22-2009, 06:03 PM   #2 (permalink)
1954oldred's Avatar
I have been experiencing the "buck" or "stutter" also. I have spoken to some very knowledgeable folks on this and other sites. I have narrowed mine down to the most likely cause: Injector(s) or stiction of same. I have about 800 miles on my most recent oil change, I put some Hot Shots Secret into the oil and it seems to slowly be making a difference. I recently had my FICM reconditioned by swamps, I have cleaned EBP sensor & tube, EGR is deleted w/solid up=pipe, IATII has been cleaned, MAP tube is clean and no obstruction. The only other thing I wonder about is the ICP. I want to be clear, I'm not 100% on the HSS just yet, after 800 miles it seems to be helping, I think.
In the end we will remember not the words of our enemies but only the silence of our friends
2006 F350 C/C SRW S/B Lariat FX4, SCT X3 W/ID Custom tunes, Coolant Filter, CCV Mod, High Idle Mod, fog light mod, EGR Delete, 3.5" MBRP stainless Downpipe, 4" MBRP Stainless the rest of the way, Swamps FICM,Edge Insight Gauges,18" BFG'S, 120k
God, Country, The Citadel
1954oldred is offline
Old 12-22-2009, 06:09 PM   #3 (permalink)
Where is the EBP sensor at?
ZUNK is offline
Old 12-22-2009, 06:30 PM   #4 (permalink)
1954oldred's Avatar
On the 06 it is on the drivers side of the block just below the level of the valve cover and closer to the "front" of the block, about a third of the way. It is located on a small tube that comes out of the exhaust manifold you should be able to see the wires leading to the sensor and the EBP tube more readily if you take the air intake and elbow off going to the turbo.
Old 12-22-2009, 08:32 PM   #5 (permalink)
Thanks, I'll check that and the map tube tomorrow.
ZUNK is offline
Old 12-22-2009, 10:03 PM   #6 (permalink)
having the same trouble, here is a question , does it do this with the truck in tow/haul mode, mine does not do it in tow /haul above 2000rpms. also put in hot shot secrets today and will post the results ...
1996 psd f-250 xlt ---- sold
1999 psd f-250 lariet - sold
2002 psd f-350 lariet - sold
2004 psd f-250 lariet - sold
2006 psd f-250 lariet
mortbike is offline
Old 12-22-2009, 10:29 PM   #7 (permalink)
I have the manual trans. Is yours going away because tow mode down shifts and puts you above 2000rpms? Or just the tow mode that helps. Mine seems to go away after 2000rpm.
ZUNK is offline
Old 12-22-2009, 11:43 PM   #8 (permalink)
im thinking it is because im going above 2k rpms. i will be driving about 500 miles in the next two days, i hope to see results from the hot shot secrets, if not i will be patient and give it 2k miles...
mortbike is offline
Old 12-23-2009, 12:15 AM   #9 (permalink)
Excuse my ignorance, but what is hot shot secrets?
ZUNK is offline
Old 12-23-2009, 01:16 AM   #10 (permalink)
I have a f-250 superduty for a service truck. The first time it did that to me I almost turned around and went back to the shop. I pushed it through and it made it just fine. Felt almost like the lockup clutch was kicking in and out.
I am buying a 2005 f550 truck. Hope it doesn't have these problems. I'll keep watching and maybe find the answer to my service truck.
lanwickum is offline
Old 12-23-2009, 05:32 AM   #11 (permalink)
Hot Shot Secret is an oil additive that claims to clean the oil side of your injectors and anywhere the oil travels. It is supposed to get rid of stiction or the burnt oil residue that can gum up your injectors. At least that is how I understand it. I have it in my engine also because mine was getting very hard to start, but I ended up taking it in and it had codes for all 8 injectors ended up putting in a new FICM, works like new $1100.00 later. I am leaving the HSS in to clean whatever it cleans can't hurt
durantdiesel is offline
Old 12-23-2009, 05:59 AM   #12 (permalink)
mmterrill's Avatar
yeah guys post your findings on hss. mines really acting up and would love to know if hss is goin to save my injectors. thanks.
mike
2005 F250 Harley Edition Crew Cab
Black w/ red flames
mmterrill is offline
Old 12-23-2009, 08:13 AM   #13 (permalink)
Where can one get this Hot shot secret?
ZUNK is offline
Old 12-23-2009, 08:18 AM   #14 (permalink)
1954oldred's Avatar
seems to occur between 1300-1600 rpms @ 50-60 MPH, at least thats when it is most noticeable w/the Auto trans. I hope that some of the Ford techs who monitor this site will chime in at some point as well.
Old 12-23-2009, 12:12 PM   #15 (permalink)
prohydroracer's Avatar
Hot Shot's Secret
It worked for me
2004 F-250 Lariat Ex-Cab Long Box
  • ARP Stud's
  • MBRP 4" Turbo Back
  • Oil and Coolant Bypass Filters
  • SCT w/Custom Tunes
  • Fuel Pressure, HPOP Pressure, Boost and EGT on the A-Pillar
  • Edge Insight monitors EOT, ECT, Tranny Temp
  • Full Security with Remote Start
  • Anti Hi-Jack Device by GLOCK!
prohydroracer is offline
