Super Charger Under-Boost? - Diesel Forum - TheDieselStop.com
Old 05-17-2005, 05:47 PM   #1 (permalink)
The Truck is a 2004 F250 Power stroke w/ 35,000 miles. I do not have any mods on the truck.
I got a code from code reader. The code was p0299, T/ Super charger under-boost. Also got a p0603 code, ctrl mod kam error. The truck seems to be running fine, but I have noticed that the truck will about once a week sputter and blow white smoke for no more than 20 seconds. Also intermittently when decelerating at 15 mph it sounds like a shuttering sound in the turbo?
puncho is offline
Old 05-17-2005, 05:58 PM   #2 (permalink)
Re: Super Charger Under-Boost?
Disconnect the batteries lately? That will give you the 0603 code
2004 F-250 6.0 auto
nummit is offline
Old 05-17-2005, 07:12 PM   #3 (permalink)
I have not disconnected the batteries. Should I, does that reset everything?
puncho is offline
Old 05-17-2005, 07:36 PM   #4 (permalink)
does not reset anything,you maybe having the starting of an EGR problem.Do you cruise around or "baby" the truck?
If you do you need to take it out and run it hard to clear out the egr and vgt vanes of soot. This has fixed a number of problems.
As for the 603,you may have a pcm problem(doubt it). The 299 can be caused by a split second glitch,it will set a continuous code but not a hard fault to set the light,when an EGR sticks it will cause a low boost code,as can other things.
Real trucks rattle!!
Ford Diesel Master Tech
dzltech is offline
Old 05-17-2005, 08:15 PM   #5 (permalink)
What is a EGR problem? I drive it fast, but also baby it a lot more than run it hard. I am trying to make this truck last. How do I run it hard? High speed highway, quick starts off the line? Tow something heavy, what should I do? Should I get a superchip and use that to run it hard?
puncho is offline
Old 05-17-2005, 09:00 PM   #6 (permalink)
What is a EGR problem? I drive it fast, but also baby it a lot more than run it hard. I am trying to make this truck last. How do I run the sh.. out of it? High speed highway, quick starts off the line? Tow something heavy, what should I do? Should I get a superchip and use that to run the sh.. out of it?
[img]/ubbthreads/images/graemlins/shrug.gif[/img]
2004 F-250 6.0 auto
nummit is offline
Old 05-17-2005, 10:12 PM   #7 (permalink)
FamilyRide's Avatar
You may be having an EBP issue. Mine threw P0299 when I was. Ever notice it sounding like it's "cycling" while cruise steady? Going quiet, loud while cruising steady or idling?
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
FamilyRide is offline
Old 05-17-2005, 10:20 PM   #8 (permalink)
JW350's Avatar
My Photos: (29)
Mine threw that code when the EBP sensor failed. You're still under warrantee...
2004 F350, 6.0L TorqShift, SRW, CC, LB, Lariat, 4X4, Built Feb 2004
8" Lift, Fox Shox, 37x13.5x17 Toyo Open Country MT on Weld Evo Velociti XT, 4.88 Gears, MagnaFlow Exhaust, AMP Research PowerStep, Auto Meter Cobalt Gauges (EGT Boost Trans), ScanGaugeII, Firestone Air Bags/Compressor/Tank, BulletProofDiesel EGR Cooler, Valvoline lubricants, Final Charge Global ELC, DieselSite Coolant Filter
JW350 is offline
Old 05-18-2005, 01:27 PM   #9 (permalink)
Get a RV trailer or toy hauler (about 10k#) & take it out for a 500 - 600 mile round trip. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Or, get it on the highway, try & find some hills, and get the rpms up about 3200 & sustain that for 15 mins, rest for about 15 & do it again. Drive it like that for about an hour a month
OMCUSNR is offline
Old 05-18-2005, 01:56 PM   #10 (permalink)
that still won't solve the low voltage reading on the EBP sensor that he has.
He needs a new EBP sensor. They dealer will probably change the EGR valv e at the same time, but it's probably not bad. lol [img]/ubbthreads/images/graemlins/crazy.gif[/img]
<font color="red">A fly landed on my arm today. I smashed it with my hand. It's dead. I heard that flys land on poop and eat it. That doesn't sound like a good life, but I'm still glad he's dead. </font>
05superdutyTJ is offline
Old 05-18-2005, 04:59 PM   #11 (permalink)
Every time I take my truck on the freeway for more than an hour of straight cruising, my turbo acts funny. Last time, I got off of the freeway after an hour of driving and while sitting at a red light, my turbo was turning on and off. All of the sudden it would get real loud, then normal again. Anyone know whay this is, it doesn't throw codes.
2008 F350 CrewCab Longbed, Black on Black, 12 inch Modified Rize Lift, King Coilovers in Front, King Reservoirs Front and Back, 40 inch Nittos, Amp Steps, 4.88 Gears
Doctorsmack03 is offline
