Swapping gears - Diesel Forum - TheDieselStop.com
Old 11-17-2009, 09:29 AM   #1 (permalink)
Swapping gears
I found a set of 3:73 gears out of an 05 superduty, and was thinking of buying them and putting them in place of my 4:30 06 superduty dually.
Will I need anything else besides the gears? Anything I need to look out for?
thanks
Current:
06 F350 dually crew 4x4 lariat, tow boss, every single option available.
2000 F250 crew 4x4 lwb leather
SOLD:
07 Dodge 3500 Cummins 4x4 Larime with h2 wheels and 315-70-17 tires.
05 Dodge CTD/610 SLT/Quad Cab, Auto, 4x4, Loaded. 17"x9.5" Weld Cheyenne, 315-70-17 BFG AT/KO, Airaid intake, X to the Z illerator.
SOLD:
01 PSD Supercab XLT, manual 4x4, loaded, Fab-Tech 8" lift, high angle drive line (snapped the stocker towing 10k#), dual shocks, 37-12.5-16 SSR, 16x10 Eagle Alloy 589, Diablo stock/57/100, 4" exhaust, Open element/ZooDad, triple a-pillar, Sonnax/Tricum, Kodiak Sidewinder's, Wicked Wheel, A.R.E. Impulse shell, sp-exhaust brake.
http://f1.pg.photos.yahoo.com/ph/dmkhnr/my_photos
Dan_K is offline
Old 11-17-2009, 02:17 PM   #2 (permalink)
I just had my 3.73 swapped out for the 4.30 gears. Ford did it. One of the bearings fell apart when they pulled the gears out. Just make sure you have alternate transportaion available in case you need parts.
Paid $1800 for Ford dealer to buy parts (ring, pinion, bearing) and labor.
John
JohnHagen is offline
Old 11-18-2009, 01:21 AM   #3 (permalink)
The gears may be different if the 05 wasn't a dually. F350SRW used a 10.5 and a dually uses a Dana 80.
Good luck
05 F350 Lariet SC 4x4 6.0/auto lgbox Toyo AT's, bilsteins, on board air with airbags & air horns
gmoore is offline
Old 11-18-2009, 09:51 AM   #4 (permalink)
Good luck
Thats why I asked
Current:
SOLD:
SOLD:
Dan_K is offline
