Tachometer Problems
Hey guys, was towing home wood last night when i noticed the tach was messed up, i was doing 120km/h and it said i was sitting at 1000RPM. I knew this was not right. thought maby a computer glitch, when i got home turned the truck off, then restarted it, the tach worked properly.
So today when i was driving it was working like it should, i went to pass a car, when i looked down the tach didn't move, got like stuck, i took my foot off the accelerator pedal, it dropped like it should, when i stepped on it again it shot up like it should, works for a bit then starts acting up again.
I replaced my alternator a month or two ago as it was shot, donno if they still run the tach off the alternator anymore?
Any Help Appreciated!!! Thanks in advance!!!!
06 F-250 6.0L PSD SD Lariat Crew FX4 White
Winnipeg, Manitoba, Canada
Insight CS (ICP psi, RPM, Boost, VGT%, Trans. ECT, EOT, EGT)
Ipr egr dlt. w/stainless up pipe, new oem oil cooler
Updated stand pipes/dummy plugs
Stc fitting update
Blue spring mod
MBRP 4" tb cat. dlt. w/5" Tip
Coolant filter w/ elc coolant
HFCM Drain plug
Hydronic 5 Espar Heater,
High Idle Mod,
Rotella T6 5w40 year round,
Viper 5901
'11 Tailgate & Rear Bumper
Bushwacker Fender flares
