Tea Kettle Whistle, -03 6.0L - Diesel Forum - TheDieselStop.com
Old 11-14-2009, 12:21 PM   #1 (permalink)
Send a message via ICQ to clayman Send a message via Skype™ to clayman
Ok i have been using the search function trying to nail down every possible thread regarding -03 6.0's with whistle issues. Long story short, after i installed the full 4" turboback my truck has been whistling a lot, too much for me to be happy with it, i am trying to find the solution on making this go away. A few things that i am aware of:
* 2003 6.0's are more intended to whistle due to the turbo design. Question is if mine has another issue making it whistle even more? The noice is very annoying inside the cab during boost/rpm build up, once you dont spool the turbo/load the motor its fine.
* I have read about leaky Y-pipes, degas bottle caps, blown EGR gaskets that can cause increased whistling, i tried removing the degas cap completely and run the truck a short distance with no difference. I cannot see or hear any leaks from the Y-pipe, is there a good procedure on how to check this? EGR Y-pipe plate "thingy" was installed during the 4" exhaust installation and the kitty was not reinstalled as well.
It all comes down to that this started when the exhaust was installed and i am puzzled no matter to that this is normal 2003 open exhaust whistle or if its an unlucky combination of something failing/leaking/draining etc during the time it got installed.
Question is, where do i start? putting another muffler on to see if the whistle decreases? start looking for issues with leaky pipes etc? I need some input on this matter.
Sorry for the long thread but thank you if you have read it this far!!
2003 F350 6.0 TURBO DIESEL CREWCAB, EDGE JUICE W ATTITUDE, 4" TURBOBACK, AIRAID STAGE 1.
clayman is offline
Old 11-14-2009, 12:33 PM   #2 (permalink)
teamroper60's Avatar
Put the cat back on and see if that cures your problem.
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 11-14-2009, 12:53 PM   #3 (permalink)
I have heard the the cat is very restrictive and will cause high EGT's? Also, since it is not a muffler, will it change the sound much?
clayman is offline
Old 11-14-2009, 01:32 PM   #4 (permalink)
my guess is your boiling the water on the egr cooler and it's blowing out the cap..
Had that happen to me, it was a egr cooler and head gasket replacement..
05' F-350 6.0L Diesel Crew Cab Long bed sitting on Brentz Wheels Custom Billet Dually 22's, Kenwood Indash Nav, Sirrrus Sat, HD Radio, Nintendo game Cube, 2 - 7" Tv's in head rests, Dual MTX 10" Subs behind seat, Arp Studs, Innovative Diesel SCT tuned for Snow Performance Stage III Meth kit, Bully Dog 5" turbo back exhaust, AFE Stage II w/ProGuard 7 Cold Air Intake, Remote Start. 03 Turbo, dam the whistle is Insane! @ 38 PSI
http://www.youtube.com/watch?v=M2zEFb6bFLc - Video
8000K Bi-Xeon H.I.D Headlights, Recon Big Rig, White lighting tailgate light and 3rd LED Brake lights.
05Duallyon22s is offline
Old 11-14-2009, 03:18 PM   #5 (permalink)
It will have a big impact on sound. But high EGTs?? Not so much unless you call 25 degrees high.... That was the difference on mine....
pics
#43
Old 11-14-2009, 03:19 PM   #6 (permalink)
I thought that too at first but he said he ran it without the cap and there was no difference... If the noise was the cap venting, the whistle should have been gone without it.....
pics
#43
Old 11-16-2009, 05:30 PM   #7 (permalink)
Yes i drove it without the cap and there was no difference what so ever. Also, it is constant, cold engine, warm engine etc, i guess i will start looking for the conversion parts to get the cat back on if we are only talking 25 degree EGT's and try that out.
clayman is offline
Old 11-16-2009, 11:26 PM   #8 (permalink)
If it's like this whistle..
then it is what it is.. you'll have to put the cat back on..
YouTube - SSHPRacing.com F-350 PowerStroke 6.0 Dually with Loud Turbo
If it's a different whistle, then that's bad...
Old 11-17-2009, 09:00 PM   #9 (permalink)
Yupp, sounds very similar to the whistle i want to get rid of! How do you stand it in the long run!?
clayman is offline
Old 11-17-2009, 09:13 PM   #10 (permalink)
Simple...Not my daily driver...it's an 05 with 30K on the clock.
it's the 03 turbo only that does it...You can switch to any other year turbo and get rid of it...
I specifically switched my 05 turbo for an 03..
Old 11-18-2009, 12:30 AM   #11 (permalink)
That whistle is pure music to most of us but if you don't like it, putting the cat back on will solve your problem.....
pics
#43
Old 11-18-2009, 10:20 AM   #12 (permalink)
Do you still have your 05 Turbo? Want to get another 03 instead?
clayman is offline
Old 11-18-2009, 10:22 AM   #13 (permalink)
Dont get me wrong, i like turbo whistle. However when pulling something in the lower RPM range and you have people in the cab that cant hear a word in a conversation i gotta figure something out.
clayman is offline
Old 11-18-2009, 12:17 PM   #14 (permalink)
MelloMike's Avatar
My Photos: (13)
I have a leaky Y-pipe on my Excursion that is getting fixed today. My engine had an annoying hissing sound at all times. Do you have this symptom?
2003 Eddie Bauer Excursion (born 8 Apr 03), 6.0L PSD (Oxford White & Arizona Beige), 117k miles and going strong, C95 Fuel Injectors, 4x4, 5-spd Torqshift, 3.73 Rear, Heated two-tone leather seats, Hellwig Rear Sway Bar, Bilstein Shocks, PSD Badges, Tekonsha Prodigy Brake Controller. Engine Repairs: 2009-ICP and ICP Harness & Exhaust Y-Pipe. 1972 Airstream Sovereign Travel Trailer.
US Navy Retired
MelloMike is offline
Old 11-18-2009, 01:00 PM   #15 (permalink)
I do in fact with only 20K on it, how many miles on the 03?
PS you also need to change the pedistal it's on which i have..
