Hi guys,while i was out of town I had my truck in to have it flushed and the coolant replaced with ECL and I had a new thermostat to be installed. while on the road they called to say it was done and gave me the price. they were charging me for the coolant. I said to look at their work order. I was providing the coolant and they thermostat was to be replaced and I was providing that also. I got "OH". and that it would be ready a day later. Now I am having doubts as to whether they actually changed my thermostat, let alone the ELC. So can someone tell me what my water temps should look like. I have a scan guage. I think I should hit 190 degrees and pretty much stay at 190. if that is not true let me know.
thanks, alex
thanks, alex
OEM thermostat begins to open at 195f, and fully opens by 218f. If up to operating temp (EOT over 190f), you should not see ECTs below 188f to 190f. If the ECT is below 188f or so, your thermostat is weak and is likely allowing coolant to circulate, as they fail in the open position.
2006 CC SB 4x4 6.0L
Factory 20s
275/65/20 Toyo MTs
7,000LB Ford Coils
Quad rear overload springs
ICON 1" TEI Spacer
ICON Adjustable Track Bar
ICON Dual Steering Stabilizer
ICON Alignment Cams
Bilstein 5100s
Coolant Filter
EDGE Insight CTS with EGT
Delo 5W40 Synthetic
Powerslot Cyro Rotors
Hawk LTS Pads
Crown SS Brake Lines
Hellwig Rear Antisway Bar
Banks Monster Exhaust
Zerex ELC
Hmm so I take it mine may need to be replaced since the ECT was 182 and the EOT was 193 and pretty much stayed there for a 40 min ride at 65-70 MPH
2006 F350 6.0L Dually Edge CTS with EGT, Banks exhaust, rebuilt FICM from ED, STC fitting, EGR Delete, and Blue Spring kit so far.....next Studs
Yes yours may need to be replaced. These motors run better on the warm side than the cool side. Mine at 60mph ECT 192-194* EOT 196-198* flat groung pulling my 5er add 10* to each.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
Well I looked last night and there is a new thermostat in. However it is doing the same as the old one. The temps will slowly climb and get near 184 by the time I get to work ~1/2 hour and 17 miles. the same with the EOT. Outside air temp about 32. So now I wondering if I am looking at either the wrong points or if I have a different problem.
'05 Ford F250 6.0 CC LB 4x4
'10 BMW X5 Diesel
'08 BMW 535xi
'85 Porsche 911 Carrera
'66 Porcshe 911 long term project
'76 Jeep CJ7 current project
Good question, though not sure why it would. I believe the fan clutches fail in the "no fan" mode versus "full fan" mode. If it is stuck engaged that could help explain an overly-cool ECT.
My bet is the mechanic pulled the old thermostat to flush the system and then put it back on without replacing it. My truck used to run cool (low 180s) until I changed the thermostat.
2006 CC SB 4x4 6.0L
Factory 20s
275/65/20 Toyo MTs
7,000LB Ford Coils
ICON 1" TEI Spacer
ICON Alignment Cams
Bilstein 5100s
Coolant Filter
Delo 5W40 Synthetic
Hawk LTS Pads
Zerex ELC
No. I can't say if I've ever heard the fan running. And unless they shined yp the old thermo before putting it in, the new one is in. Maybe I'll verify the new one I have on the stove to see if it opens at 190 and the replace the one that is in there.
