thought icp was bad and its not need help!! - Diesel Forum - TheDieselStop.com
Old 04-01-2009, 01:43 AM   #1 (permalink)
ok my truck kinda had a loss of power from light accel from a stop every once in a while. no check engine lights. then one day i was driving and came to a stop and it started idling really rough and i was on my street so i drove it home. i found a blown fuse that goes to the check engine light i replaced it and low and behold p2285 icp low. i pulled the egr and cleaned it and replaced the icp and reset the computer. i went to drive it down the street today and it was still acting up and then it died like 8 houses from mine. i tried to restart it and it wouldnt. it wasnt even at operating temp the gauge was still all the way on C. so i tried to start it when i got home from work a minute ago and it still wont start. fuel filters were changed 7k-10k miles ago. anyone have any idea what it could be. thanks!
jnobles06 is offline
Old 04-01-2009, 01:54 AM   #2 (permalink)
When did you last change the fuel filters?
2004 6.0Powerstroke ExtraCab. Indigo Blue over Tan, Super Chip, AT's
2007 6.0Powerstroke CrewCab. Silver, Chrome package, SuperChip, MBRP Cool Duels Turboback
Burper/Puker
2 Degas Bottles, 3 Degas caps, 1 EGR Cooler, 1 Oil Cooler, 2 O-rings.....still puking.....
Also, two speed sensors, and about 13 damn tail light bulbs.....
StrokinTiger is offline
Old 04-01-2009, 02:10 AM   #3 (permalink)
7k-10k ago. would that throw a p2285 though?
Old 04-01-2009, 02:17 AM   #4 (permalink)
sorry man. Scanned right through the post and didnt see that dtc. Uhm.....have you checked the grounds and wiring for shorts?
Burper/Puker
Old 04-01-2009, 02:23 AM   #5 (permalink)
yeah i had the truck running and kinda shook all the harness i could see and checked them for any rubbing and what not. i found an injector harness that was rubbed but just the black insulation and that foil stuff was cut. the actual wires were fine with no cuts in their insulation. the problem seems like its getting progressively worse. i used to be able to start it and it would idle rough till i shut it off. then it would idle and die and restart and now it wont start at all.
Old 04-01-2009, 02:40 AM   #6 (permalink)
This is why I didnt first say electrical......bc it doesnt usually cause rough idle. The first thing I would try from this point is to clean the EGR Valve. You might even want to consider bypassing it all-together....
Burper/Puker
Old 04-01-2009, 02:43 AM   #7 (permalink)
i did stated in my first post i cleaned the egr.
Old 04-01-2009, 02:45 AM   #8 (permalink)
Holy shnickees! You did say that. Man I am sorry I am new to this site and I am bouncing around just reading all sorts of stuff and I think I am losing my head here.....let me get my brain in gear.......lol
Burper/Puker
Old 04-01-2009, 02:58 AM   #9 (permalink)
no worries man
Old 04-01-2009, 11:06 AM   #10 (permalink)
tvandyck7's Avatar
Did you change the ICP sensor harness too? You could have gotten a faulty replacement sensor. Unplug the EGR valve. Cleaning it doesn't always work, but it shouldn't cause your truck to die if it is bad. The ICP sensor definately will kill it.
2009 F-250 6.4L PSD CC SB Lariat Ultimate FX4, 3.73LS
Mod List:
-51 gal RDS direct fill auxillary fuel tank
-SEIC High Idle
-H&S Black Maxx Running the Hot Damn +300 Tune
-S&B Dry CAI
-Diamond Eye 5" Turbo Back Race Exhaust
-Custom 10" Sub Box Behind the Center Console
-Coastaltech SYNC-LP1 Lockpick
-Westin Bull Bar
-Westin Taillight Guards
-Recon LED Smoked Dodge Cab Marker/Clearance Lights
-Billet Fender Vent Inserts
-Zone Offroad 4" Lift
-20x10 BMF Novakane 8's
-35x12.50r20 Nitto Trail Grapplers
-'11 Super Duty Rear Seat Cargo Tray w/410W Power Inverter
tvandyck7 is offline
Old 04-01-2009, 02:40 PM   #11 (permalink)
i have the pig tail and havent replaced it yet. i am going to do that tonight. i read something about the balloon test that i am also going to try but i will proably do it tomorrow morning.
