Threaded plug on top of HPOP - Diesel Forum - TheDieselStop.com
Old 12-04-2012, 10:07 AM   #1 (permalink)
pwesseler's Avatar
My Photos: (5)
What is that plug for? Do you remove that and fill the pump with oil after having pulled the pump to help the start/crank time?
The STC fitting update kit includes a new one plug, just wondering
2007 F250 XLT 6.0L PSD 4x4
pwesseler is offline   Reply With Quote
Old 12-04-2012, 06:06 PM   #2 (permalink)
I was told it was to check for high pressure oil leaks at least that 1 of the places you can check it at.....but when i installed my oil pump I didnt put oil in there i was just told to install it and start it up!
Little John is offline   Reply With Quote
Old 12-06-2012, 12:23 AM   #3 (permalink)
pwesseler's Avatar
My Photos: (5)
Yeah, I wonder if that would have decreased the crank time. After being disassembled for a few days the truck took a minute to fire up and I was in the cab getting nervous. I’m sure everyone can relate.
Old 12-07-2012, 08:49 AM   #4 (permalink)
Grewells's Avatar
It's called "pucker time"!!!
It took way too long for my truck to restart after I replaced the HPOP. I just kept the faith and was glad I charged the batteries during the work.
2005 F-250 Lariat CC FX4 4WD, 5th Wheel hitch, 5 inch Turbo back Cat/ Muffler delete, FICM Rebuild from FICMRepair.com w/ Atlas 40 from PHP, 220 amp Alt from DC Power, IPR EGR Delete, IPR Up=pipe, '08 banjo bolt mod, Blue Spring Fuel Pressure Regulator mod, AMSOIL oil bypass filter, Dieselsite Coolant bypass filter, Zoodad mod, High idle mod, CCV mod routed to left rear, Rotella T6 5w-40 Synthetic Oil, Recon Blacked out third brake light/ side mirror turn signals, 7in Screen Double Din AM/FM/CD/DVD/ iPod ctrl/ NTSC TV eBay special, Rear 56" 5 way light bar...
Grewells is offline   Reply With Quote
