Can't find my install sheet.... who knows it? Just back from dealer,..... 3rd time HG's gone with ARPs after first time and ARPs and fire ringed heads 3rd time. Unbelievable.....
2005 F350 CC 6.0 PSD 4x4 CC LB Lariat White on Tan Leather Captain Chairs
All options except PTO, sun roof, power slider
Goodies Below:
6" FABTECH 4 Link Lift; FABTECH Dirt Logic 4.0 Coilover front; FABTECH Dirt Logic 2.5 w/reservoir rear; FABTECH traction bars; FABTECH dual steering stabilizer dl 2.25; American Racing 20x10 Chrome Trax 8; BFG AT 37x12.5x20; Line-X; Mag-Hytec Rear Cover; AIC Engauged; Bypass Coolant Filter; Banks Monster Exhaust Turbo Back; Issipro 05 SD 3 Gauge set on A-pillar wood grain; Coolant temp gauge, Washed Badges; Billet Gas Cap Cover; WeatherTech Window Vents; Precision 6 piece grill; Lund Stainless Interceptor hood guard; Line of Fire LED tail lights/turn signals; Rhino Chrome step bars wheel to wheel; Retrax tonneau cover; X-treme Rack; Bushwacker OE Flares; ARP Head Studs; ZOODAD Mod, Fire Ringed Heads by Elite, XCal3 by Innovative, Spearco IC, .456 gears, Fabtech Hydraulic bump stops, Mag-Hytec front diff cover.
ARP tech support in Ventura, CA has some really helpful engineers. I've called them twice on other cars and they were always good for an answer. Does Ford call for Loctite in the block like some aluminum blocks. Is there is a set height above the deck for the 6.0? On my P-car blocks sometimes they can turn when torqued throwing off the torque value if not set in Loctite.
What's the point of having ARP studs if your still blowing head gaskets? I was under the impression that was the one stop fix all for the problem. I wonder if your heads are warped?
I've asked myself the same question.....how is it possible a third time with with ARPs and fire ringed heads? The 2nd time was with ARPs alone that were added the first time after stock. It IS NOT A COOLER ISSUE....trust me. AS for warped heads, these were fire ringed heads from Elite..... would think they were flat when installed. I had an injector problem for about 18 months (installed with the fire ringed heads) and HG's held but was very inefficient and very hot not making power correctly. Finally had to go back to stock injectors..... first long tow of 10Klbs up 6% grade making efficient power on stock programming I blew coolant. Now, if towing and I go above 20lbs boost it will blow. My hope at this point is the heads weren't torqued correctly. ARP says 265 is good with the fire ringed heads. Going to try that first one bolt at a time without removing heads and see. Ford won't touch it at this point because it is all aftermarket.......even though there first stock repair under warranty failed the first time I towed afterwards. Only other thing I can think of is that it is a bad block or just plain lemon motor with some undiagnosable reason it keeps doing it. 3 times just doesn't make sense.......with ARPs and Fire Ringed Heads and no cooler issues.
Im in the prosses in replacing head gaskets for the fourth time on customers truck,blown 2 times on warrenty and once now with arp studs,block is straight,heads are warped badly at #4 cyl and #5 cyl ,replacing heads with complete new heads from ford this time hope its cured now, only made it 44,000km
You NEED to get the heads and block checked for flatness. If not, you might as well go out in the middle of the street and light off 500 $1 bills. The best head gaskets and studs can not cure flatness problems.
