Torque specs for CAC tube/boot clamps - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 12-08-2011, 08:26 PM Thread Starter
I plan on taking on the new fuel regulator parts swap here soon. There is an incredible writeup on here for this with pics. I decided to "sack up" and do it myself. The only thing I have reservations with is the torque-to-spec instruction on the clamps for the CAC pipe-to-silicone sleeve connections. I've heard so many cases of the dreaded POP and no power when the boot comes off and want to do all I can to avoid this.
I am of the "Chevy school" of tightening bolts, etc. where you crank it until you hear a crack, and then back it off a half-turn.
Can someone put me some knowledge as to how much I need to tighten these clamps? A disconnect on the bottom connection sure would be a PITA while on the road...
Thanks in advance for your help.
GG
2003 6.0 PS XLT CrewCab, SB, FX4, bedliner, bug deflector, Bilsteins, Blue spring kit, new turbo (stock, upgraded Garrett) in December
GFisherman is offline
post #2 of 3 (permalink) Old 12-08-2011, 09:12 PM
usmarshls's Avatar
I THINK IS LIKE 10FT-LB. BUT THERES NO NEED TO TORQ IT JUST PUT IT ON AND MAKE IT TIGHT IT WILL BE FINE.
Torque SpecificationsDescriptionNmlb-ftlb-—Charge air cooler inlet/outlet ducts retaining clamps1310
2014 FORD F-250 CC SB FX4 6.2L 3.73 E-locker, black on Black inside, Blue Jean, NAV, SYNC, window tint, spray in bed liner
Added-
LED projector reverse lights
Factory upfitter switches
rear seat cover "kids are a mess"
LED floor lighting front and rear.
LED lights in bed under rails.
MORE LEDs coming soon.
SOLD
Goodbye my love
2005 F-350 King Ranch FX-4 CC long bed
2in level kit.airade intake with 4micron sock.superchips.sinister coolant filter.blue spring update.ranch hand wrench ready front bumperreplacement. installing glowshift gauges EGT,BOOST,TRANS TEMP,FUEL PSI. with quad gauge pod A-PILLAR.4IN turbo back cat delete
2004 F-250 V-10 -SOLD
1986 F-150 V-8 302CID first year of EFI -SOLD
1984 F-250 V-8 351CID Carb SOLD
In the Garage
1995 F-150, 460CID
2004 Expolrer 4.0L
usmarshls is offline
post #3 of 3 (permalink) Old 12-08-2011, 11:53 PM
Feedback Score: 2 reviews
A few months back i installed a new set from Dieselsite the stock boots have an added hump inside that fits inside a slot and the clamp goes over this witch will keep it in place just clean real good i used Dawn dish soap then just get the clamps tight, now the Dieselsite boots have a steel ring that goes in the slot and the boot goes over the ring and you put the clamp on the boot where the ring is kind of hard to do the ring goes into the boot to hold it from the torque of the clamp but it is a one time deal the oil will not kill these boots. You can see the rings here, they go on both ends of the pipe http://www.dieselsite.com/typical2003-200460l.aspx
Mine is an 06 and the back side of the boot at the turbo had a 3" split and you could not see it with only 31k.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline
