Touble Codes P2285 and P2263 - Diesel Forum - TheDieselStop.com
Old 11-20-2009, 03:00 PM   #1 (permalink)
First of all, Thank You for allowing me to register. I have been a long time fan of this website. You have helped me several times. Researching these trouble codes have not given me any clues that they could be related, so here I am. I have already ordered a new ICP sensor & harness. Will pick up on my way to work. Could the 2263 be related? Which problem would attack first? I have noticed some surging and engine noise going from the 6.0 clack to a quieting, as discribed in several other posts about the 2263. The ICP code was first MIL. I preformed the oil & filter change due. Then got thee 2263 code the next day. Thinking it may have been the oil change that set the code I cleared them and the came back.
Texas Fling is offline
Old 11-20-2009, 04:13 PM   #2 (permalink)
teamroper60's Avatar
P2263 is related to the turbo and primarily to a lack of boost. The places you should start looking are:
MAP sensor hose/electrical connection
Intercooler hoses (look for holes/cracks)
Exhaust system leaks
Intake system leaks
MAF sensor connection
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 11-20-2009, 04:17 PM   #3 (permalink)
2285 is icp sensor leaking oil
outlawpony is offline
Old 11-20-2009, 04:20 PM   #4 (permalink)
Actually it just means the ICP sensor is out of range but you are correct in that it's usually due to oil intrusion....
I didn't mention it because the OP already stated he has a new ICP sensor ordered, so I figured he already had that one diagnosed....
pics
#43
Old 11-20-2009, 05:04 PM   #5 (permalink)
MelloMike's Avatar
My Photos: (13)
Wow, what a coincidence. I just took my 2003 Excursion in for the same exact codes/problems on Monday. The tech replaced my ICP sensor and harness and the other problem was due to a cracked exhaust Y-pipe.
My X bucked, surged, stalled, and lacked power in general. I got my old truck back now and I'm a happy camper--runs like a raped ape.
2003 Eddie Bauer Excursion (born 8 Apr 03), 6.0L PSD (Oxford White & Arizona Beige), 117k miles and going strong, C95 Fuel Injectors, 4x4, 5-spd Torqshift, 3.73 Rear, Heated two-tone leather seats, Hellwig Rear Sway Bar, Bilstein Shocks, PSD Badges, Tekonsha Prodigy Brake Controller. Engine Repairs: 2009-ICP and ICP Harness & Exhaust Y-Pipe. 1972 Airstream Sovereign Travel Trailer.
US Navy Retired
MelloMike is offline
Old 11-20-2009, 09:16 PM   #6 (permalink)
OK so here is a new bump in the road. I went to the dealer for the ICP sensor. He was being vary helpful. He went back to talk to a tech. Tech told him that replacing the ICP sensor would not solve the problem, that I had an internal oil leak. I do not know what gives the tech that ideal. He only knows that I had a P2285 code.
Old 11-21-2009, 01:30 AM   #7 (permalink)
Find another dealership. It gets expensive QUICK when you get someone that will not troubleshoot and, instead, just replace EXPENSIVE parts.
Mark
bismic is offline
Old 11-21-2009, 05:44 PM   #8 (permalink)
I agree 110%.
While I don't think the ICP is going to fix the P2263 code, that IS the fix for the P2285. If that tech doesn't even know that, I would not want him working on my truck.......
pics
#43
Old 11-23-2009, 02:53 PM   #9 (permalink)
I replaced the ICP Sensor and wiring harness that connects to it. Cleared the codes. Drove through a cycle. No more codes as of yet. Cross my fingers and knock on wood. I think it is a done Deal. Thank You all for your comments It is great to have this tool to help. I mean this website as being a tool. Thank You.
Old 03-05-2010, 01:42 PM   #10 (permalink)
Anyone have a good source for ICP sensors; I've got a 2285 code.
Also, I haven't looked into it yet but are they easy to replace?
Chili Palmer is offline
Old 03-05-2010, 02:28 PM   #11 (permalink)
Ford dealership or ebay.
Depends on the year.. On a late 04 or later, they are a snap. It's on the passenger side valve cover, below the alternator. Unplug the connector, put a socket on it and take it out just like a spark plug. On the 03's and 04's prior to 09/29/03, it is a bit more involved.
pics
#43
Old 03-10-2010, 07:01 PM   #12 (permalink)
Thanks, found one at the dealer for $140 and will be replacing it tomorrow.
Also, what's so special about the Craftsman socket people are talking about? Wouldn't any deep 1 1/16" socket work as long as it's cut down? Sears is clear on the other side of town and if I can pick one up within a mile I'd rather do that.
Thanks.
EDIT: I have an early '04...
