Tow/ Haul Problem - Diesel Forum - TheDieselStop.com
Old 08-26-2007, 12:06 AM   #1 (permalink)
PSV8TD's Avatar
Tow/ Haul Problem
I was pulling my camper the other day about 65 mph on flat ground and the tow/haul mode just disengaged out of no where. I stopped, checked everything out and seemed to be no problems. I didnt have very far to go so it didnt act up again. Any ideas? Thanks, AJ
Ps. Banks six gun was not on and the camper weighs about 9000lbs.
2003 F250, 6.0L, Fx4, CC, SB, Lariat, Arizona Beige, MBRP Turbo Back Straight Pipe 4inch, Bilstein shocks, Isspro pyro and boost gauges, Banks Six Gun & Speedloader, Auxillary idle, XM radio, CB, Backup lights, Recon Smoke cab & mirror lights, Timbrens
PSV8TD is offline
Old 08-26-2007, 10:24 AM   #2 (permalink)
Mark Kovalsky's Avatar
Re: Tow/ Haul Problem
You might have a wire wearing through in the steering column. The wires tend to wear and break where they enter the shifter handle. Remove the plastic cover on the column by removing the screws from underneath. Chances are you'll find a damaged wire that shorts out once in a while.
Mark
Mark Kovalsky is offline
Old 08-26-2007, 11:02 AM   #3 (permalink)
just a question? why did you not have the 6 gun turned on, and what setting do you usually tow with?
thanks
2005 f350 4wd drw 6.0 - banks 6 gun tuner and intercooler - air raid air box - mbrp exhaust
2003 cobra convert!
2005 jeep wrangler
gostanggo is offline
Old 08-26-2007, 06:46 PM   #4 (permalink)
PSV8TD's Avatar
Thanks for the replies. Honestly, I usually never run the six gun. I have never had any power issues pulling that camper. During normal driving I found myself getting on it too much so I just keep it off. With me, I found I get way better fuel milage with it off. Thanks again. AJ
PSV8TD is offline
