Tow/Haul switch
Ive noticed a few tow/haul threads recently. My question doesn't fall into any of the previously asked questions.
I think the momentary switch on the end of the gear selector shaft is failing, or there is an open in the somewhere else in the circuit that isn't constant.
The reason I think this is, sometimes I select "tow/haul" mode, by pressing the switch, and the trans does not go into tow/haul mode, and the tow/haul lamp doesn't illuminate. In other instances, I hit the switch and the lamp lights, and the trans behaves as it should.
Is the switch easily replaceable?
Should I look for faults anywhere else?
If I bring the truck to the dealer will they be able to find this fault using the scanner, or actually will I be able to find the fault using a scanner? I have access to a shop where we buil racecars, and have OBDll scanners , etc available..
2003 Ford F250 Powerstroke (tow vehicle)
1975 Porsche 914 GT3 (racecar)
1969 Porsche 911 GT5 (racecar)
1965 Porsche 356SC (driver)
