TOW / HAUL USE - Diesel Forum - TheDieselStop.com
Old 08-08-2006, 02:07 AM   #1 (permalink)
TOW / HAUL USE
I have a 06 F-250 6.0l Powerstroke i was wondering if using the tow / haul button increases the boost during full acceleration? Thank You.
2006 F-250 FX4 CC LARIAT BLACK ON BLACK
jaeice420 is offline
Old 08-08-2006, 06:02 AM   #2 (permalink)
Re: TOW / HAUL USE
I don't think it increases boost. It just delays upshifts so that you stay in the lower gears longer so that you have more usable power to get up to speed. T/H also does not completely eliminate OD like some have suggested in the past. On mine, when in T/H mode the trans will not shift into OD until about 62 mph. So I guess for all towing at less than about 62 mph, OD is effectively eliminated.
I like the T/H mode, but I've found there are certain situations where I prefer to put it in regular mode. You'll just need to try it both ways and figure out what works best for you.
2005 Arizona Beige F350 XLT FX4 6.0 CC shortbed, 3.73 ls rear, 18" wheels, Tow Command. Additions: Vent Visors, bug guard, Fumoto Valve, Timbrens. Traded for...
Current Truck -- 2008 Black F350 XLT 4x4, 6.8 V10, CC Long Bed, 4.10 rear, 18" wheels, IBC. Additions: Chrome Step Bars, Chrome door handles, Silver barbed-wire pin stripe, B&W Turnover GN ball
barrelhorses is offline
Old 08-08-2006, 12:31 PM   #3 (permalink)
pajuis's Avatar
My Photos: (6)
Re: TOW / HAUL USE
I know it maintains your speed going downhill also which is a nice feature if you have a heavy load.
My Ride
2005 F250 XLT CrewCab FX4 Silver Metallic
Reverse Aid Sensors, 10.5" DVD Monitor
6" Fabtech Lift, 1.5" spacer 37" NITTOS on Pro-Comp Wheels,
Airaid Intake, Hypertech 41045 3 Stage in-line PTC,
4" turbo back Diamond Eye exhaust with cat delete,
Crimestopper alarm, perimeter sensor,
remote starter ,turbo timer,
tinted windows ,billet antenna,
billet fuel door and Carbon Fiber taillights.
pajuis is offline
Old 08-08-2006, 02:54 PM   #4 (permalink)
Re: TOW / HAUL USE
hey thanks for answering a ???? i was going to post about it not eliminate the od... but heres one ???? you might answer how many gears does it have 4 with od or 5 with od...i could of swore i counted my truck shifting 5 times from a dead stop last night towing the trailer...
2005 SUPERDUTY XLT SPORT 5" DONAHOE LIFT W/35X12.5X20 TOYO TIRES..20" DRIVE BLITZ RIMS...MBRP TURBO BACK 4" EXHAUST...PILLAR POD WITH GAUGES...BUSHWACKER OEM FENDER FLARES PAINTED TO MATCH...TRAIN HORN...
trx416ex2nv is offline
Old 08-08-2006, 03:03 PM   #5 (permalink)
Re: TOW / HAUL USE
It does not change boost.
It changes (delays) the shift pattern - still all 5 gears (which by default includes OD).
It is a 5 speed tranny - the fact it is OD is not relevant, there is still the diff to go through.
IMHO, Tow/Haul is good for pulling the heavy stuff, like above 10,000 or 11,000 lbs........It is not needed for 8,500 or less, which is what I pull (big boat). Then again, I drive in Texas, if I was in really big hills or mountains, then I would use it.......especially for the additional breaking it provides going down steep mountains.
The shift patterns (programs) is something Ford actually got correct; both with and without tow/haul mode. Both work great for the intended purpose.
2006 F250 4x4 Lariat CrewCab SB, FX4, 20" w/GoodYears
HoustonPerson is offline
Old 08-08-2006, 03:09 PM   #6 (permalink)
Re: TOW / HAUL USE
With Tow/Haul you can check your 6th gear. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Jim
2009 F250 PSD 4x4 CC LB KR
2007 Suburban LT3
2007 Yukon XL Denali
2005 F250 PSD 4x4 CC LB KR
pictures
JimJoe is offline
Old 08-08-2006, 04:32 PM   #7 (permalink)
Black05's Avatar
Re: TOW / HAUL USE
I have gotten 5 shifts out of the transmission both with and without tow/haul engaged.
Black/05/F350/XLT/CC/LWB/FX4/SRW/3.73/6.0L PSD/ TorqShift/Updated TBC/Upfitter Switches/SEIC Mod/Diesel Site Coolant Filter/Fumoto Valve/ITEC HFCM Drain Plug/Bilstein Shocks/BFG A/T 28565R18/Built September of 2004
Texas Proud.
God Bless our Armed Forces.
Black05 is offline
Old 08-08-2006, 05:32 PM   #8 (permalink)
Re: TOW / HAUL USE
Five shifts from a dead stop. So six gears including OD. Everytime I actually pay attention to my truck shifting, regardless of whether its in T/H or regular mode, it seems to always have 5 shifts.
Old 08-08-2006, 07:17 PM   #9 (permalink)
Re: TOW / HAUL USE
ok just making sure i wasnt loosing my mind not like i already havent [img]/ubbthreads/images/graemlins/tongue.gif[/img] [img]/ubbthreads/images/graemlins/tongue.gif[/img]
Old 08-08-2006, 09:06 PM   #10 (permalink)
Re: TOW / HAUL USE
No, five gears.
It shifts 1-2, 2-3, 3-4, 4-5, and then the torque converter locks, which feels like another shift.
Casey_1 is offline
Old 08-08-2006, 09:48 PM   #11 (permalink)
Re: TOW / HAUL USE
I gotta disagree Casey. My RPMs also go down with all five shifts 1-2, 2-3, 3-4, 4-5, 5-6. The 5 to 6 shift takes the RPMs from around 2200 or so (depending on how hard I'm pushing it) down to about 1800, again depending on how fast I'm moving. I don't think this can be explained as the converter locking up.
Old 08-09-2006, 12:42 AM   #12 (permalink)
Re: TOW / HAUL USE
Barrel,
I can't say for sure since I'm not in your pickup with you, but I think you're describing the torque converter locking. Does it happen between 60-65 mph? I'm pretty sure the last "shift" is the torque converter locking.
Nubbs
07 CC LB FX4 TS 6.0 Oxford White, 4.5" DR lift, 315/70/17 BFG on 17x8 American Racing Mojave
Nubbs is offline
Old 08-09-2006, 01:57 AM   #13 (permalink)
Re: TOW / HAUL USE
Oops, it seems I started a debate. To clarify you have 6 gears but in normal operations only 5 are used. In tow/haul 5 gears are used also but different ones.
Here are the numbers (I copied it from your post, Casey):
1 3.11:1
2 2.21:1
3 1.54:1
4 1:1
5 0.71:1 (OD)
The tow/haul gear is 1.09:1 so very close to 1:1. Reverse is 2.88:1
Jim
2007 Suburban LT3
pictures
JimJoe is offline
Old 08-09-2006, 06:10 AM   #14 (permalink)
Re: TOW / HAUL USE
So the torque converter locking up will cause the engine RPMs to decrease by several hundred RPMs???? I'm picking the truck up from the dealer this morning. I'll try to take some notes regarding RPMs/MPH/Shift points etc at some point today so I can better describe what I think I'm experiencing.
Old 08-09-2006, 07:40 AM   #15 (permalink)
Re: TOW / HAUL USE
Yes it will. That's what it was designed to do.
Casey_1 is offline
