This is the third time this truck has been in for a transmission problem (slamming into reverse 2x, now it shredded the planetary because of some roller or something), I wonder if I can get it boaught back, the problem is that I do truly love the truck. I have a warranty with "Ultimate Warranty Corporation" that is supposed to be bumper to bumper up to 125000 and they just told me they are going to deny the warranty coverage because 1) I have a hitch (5th wheel) in the back and that is a "modification", and 2) that it was a preexisting condition... grrr
37600 miles on it... go figure
2008 F-350 Lariat CC LWB 6.4 PSD, DRW, FX-4 4x4, 4:10 born 06/07 K&N FIPK
and
2004 F-350 Lariat CC LWB 6.0 PSD, DRW, FX-4 4x4, 4:10 Born 06/04 bought BRAND NEW on 10/26/04 Woo HOOOO This truck ROCKS!!! No mods yet,and it seems none NEEDED!! Replaced transmission @ 37k miles and EGR valve @ 58k miles : 92,000 miles as of Nov 2009
and
1996 F-250 SC 7.3 PSD, SRW, 4x4, 4:10 gears, bought new in May 96, TyMar Intake(on@150,000),Updated Turbo inlet hoses and breather assy,TrueCool 24,000 Tranny Cooler, Diamond Eye DP/Exhaust,Eviscerated Kitty,FPR Shimmed w/BB,Autometer z-series guages (boost, Tranny Temp, post turbo Pyrometer).Replaced Water pump @ 100,000.Rebuilt Tranny @ 140,000.Replaced GPR and Glowplugs at 159,000.Replaced brake vacuum pump 162,500.StanCor Heavy Duty GPR,4R100 tranny pan.Replaced starter @ 185000 miles : 225,000 miles as of Jan 2012
WOW, so these warranty places are really a scam! Shouldn't this be covered by the ford warranty? The way the lemon law usally works is 3x to a dealer for a warranty repair, and the thing still isn't fixed, you have to file with Ford to have a buy back. Then you have to go to arbrtration and IDK what after that. I am sure someone who has had a buy back will come in here soon. But yea 2004 truck with less than 100,000 def under Ford Warranty for the tranny.
2005 F-350 XLT PowerStroke Diesel FX4
SCT Xcalibrator2 with Tunes from Innovative Diesel
37 X 12.5 BFG Mud Terrains
5% 3M Tinting
Viper 791XV with Remote Start
152dB Kleinn 3-Trumpet Horn System
Dakota Digital Gauges
T409 MBRP Straight Pipe
AFE Stage II Intake
HARPOONED Fuel Tank
2003 10 Vane Turbocharger
Blacked Out Harley-Davidson Edition Headlamps
ARP Head Studs
AVIC-Z2 In-Dash Navigation System
205cc Elite Sticks
Coolant Filter
Elite Regulated Return Fuel System
FS2500 Oil Filter
HPOP STC Replaced
why would it still be under warranty for the tranny??? unless he has the extended warranty or something, the 100k mile (that i got w/ my truck) is engine only, and limited parts at that. my tranny is only covered under my [soon to expire] 36k mile warranty.
am i wrong?? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Travis
'03 F350 Dually, 6.0, Supercab, longbed, 4.10 LS, sport pkg, extremely RED, STRAIGHT PIPED, SCT Xcalibrator, full guages
- Job1 programming, Harpooned, Skweeker Mod, Zoodad Mod
- Did that thing that you're not supposed to talk about
'79 Bronco, 468cid Ford 460 marine motor, C6/NP205
Previous -'99 F250, Rg Cab XLT, 7.3/6spd, 3.73
Project truck
- '96 Cummins, 215hp/5spd, Diprocol guages, Plate & AFC full fwd, hi-capacity external lubrication system
To add: 2 1/2T axles, 46" goodyears, etc.
I'm PO'd that the tranny is not under the extended warranty I purchased to take the slack when the 36k mileage came (and went). I figured that since I had had issues with the tranny in the past that it was the weak link and that warranty coverage was a good idea. Now thinking to go with ATS or a local rebuild.
The 3/36 from Ford means probably the same problems popping up, plus it will cost $4100 vs an upgraded tranny interior for $3500. Just not sure which to get.
and
and
The harsh reverse engagement most likely was due to the planetary failure. As the pin starts walking out in the planet assembly, it rubs on the ring gear hub, contaminating the fluid with metal debris. The solenoids in the torqueshift are extremely sensitive to contamination. If it was in 2 times prior for harsh reverse engagement, chances are they overlooked what was the actual cause. Planetary pin rubbing, contaminated fluid with metal, metal found its way to solenoid and stuck solenoid, causing harsh reverse engagement. These transmissions don't have many problems. The planetary was fixed under a recall, although there have been some that failed outside of recall dates. I wouldn't be overly worried about transmission after it is properly repaired.
Agreed.... the TorqShift is a pretty skookum transmission. The only real concerns I have seen have been the ones "built in" - snap ring placement, planetary pins....
I wonder if one of the transmission recalls wasn't done on this unit or if the owner wasn't a victim of "flat rate" diagnostics...
Modification my left eye. Your extended warranty sucks and it's none of their business that it was a pre-existing condition, Ford really should be covering this for you but if they don't this extended warranty company should.
If they don't, sue them.
This is one of those cut-rate extended warranties that Auto-Jim was warning about.
LOL, bet they would have said the same thing if you had a 2 5/8's ball in the reciever. [img]/ubbthreads/images/graemlins/tongue.gif[/img]
As I come out of the shock of this, I am beginning to believe that the tranny has been bad since the beginning. I am going to get my "warranty" money back because it is a serious rip-off. Ultimate Warranty is the name of the business. Stay away! I suppose that any aftermarket warranty, excluding probably the Ford one, are just rip-offs. The catch is that if they do payout and you decide to cancel the "warranty", probably because they try to back out of a claim, you have to pay anything they paid and then get a pro-rated refund. I read the contract, but it didnt hit me til now what WHY that was in there.
This is my 3rd new Ford in a row. Started with a 91 after I got back from Desert Storm, got this after Iraq. I really like it, but I dont have a clue how to get Ford to stand behind me and help. I was told that because I had bought an aftermarket warranty that Ford wouldnt do anything.
and
and
I am unsure of the specified coverage on any of the trans recalls. Looking at it from one angle, the customer would have been notified of the program.... If the customer decided to ignore the field service action and, instead, drove the transmission to destruction, who should pay the added expense?
You guys are right about the aftermarket warranties..they are a rip off. I work at a Lincoln Mercury/ Mercedes dealer and I see customers come in with all kinds of warranties. They hardly cover anything when it comes time for a claim although they appear to cover a lot when you buy them. Then they have the balls to tell us that they only pay $40.00 an hour labor! They actually think that we will cut our labor in half just for them. My adviser tells them they can pay whatever they want because he bills the customer and lets him fight it out with the warranty company. The weird part is you can buy a Ford warranty for any kind of used car and they cover a lot of stuff compared to the other companies. They work great for Mercedes customers because if one module goes bad it pretty much paid for itself. Ironic isn't it?
mudguppy is correct. however if your transmission assembly is replaced with a ford reman unit, you get 3/36 from the time of install.
Whoa Whoa Whoa Hold the phone here. My trans was just replaced at 27k miles with a Ford Remanufactured on top of that 4 days after the new install I get a check guages warning and a flashing tow/haul light. They ended up replacing my temp sending unit. I was told its only covered to the end of my 36k warranty. IF this is not the case then I will be going back on tuesday with a not so smiley face as they are used to seeing me with.
05 F350 CC LB 4X4 DRW Lariat 6.0 Torqshift, Black Clearcoat, tow command system, upfitter switches, and almost every option except sunroof HERE
