Tranny skipping 1st? - Diesel Forum - TheDieselStop.com
Old 05-10-2005, 04:53 PM   #1 (permalink)
ridintall's Avatar
My van is a pretty heavy beast. On occasion, in my hilly neighborhood, I drop the tranny down form D to 3rd so I don't have to ride the brakes on the down hills. What I've noticed is that when in 3rd and from a stop, I'm pretty sure my van is not starting in first gear. Feels more like second gear as I can see the RPM's change once as the tranny is shifting up. It's definately more sluggish from a stop when the gear lever is in 3rd instead of D(drive). Is this a sign of trouble?
04 E350 6.0, Torqueshift, 12K miles, no engine or tranny mods besides the Quigley conversion.
Thanks much
2004 6.0 E350 Quigley 4x4 w/ Sportsmobile Conversion.
285/75R16 BFG AT/KO. 3.73 Gears.
Dieselsite Coolant Filter.
Aluminess Front/Rear Bumpers.
125W Solar Panel.
Sportsmobile Trailer on 285/75R16 BFG AT/KO tires w/ dual deep cycle marine batteries, water pump, 10 gal water storage, air compressor, storage box & 15W Solar Panel.
Wiring Harness Recall - 15K miles
EGR Valve replaced @ 30K miles
Oil & EGR Coolers replaced @ 62K miles
Tank delamination - Reconditioned by Gas Tank Renu @ 62K miles
Vacuum Pump replaced 69K
SnowMan Mod / Door Seal Mod
ridintall is offline
Old 05-10-2005, 07:11 PM   #2 (permalink)
Re: Tranny skipping 1st?
It's normal. You start out in 3rd gear when the lever is in the 3rd gear range. Same for 1st and second. Drive will start out in 1st and shift through the sequence.
djshum is offline
Old 05-11-2005, 08:04 AM   #3 (permalink)
When you select 1/2/3, you're locking the transmission into that gear. Sounds like it's operating as intended!
tvsjr is offline
