Trans removal. - Diesel Forum - TheDieselStop.com
Old 09-12-2009, 09:32 PM   #1 (permalink)
Trans removal.
I am gonna start pulling my transfer case and 5r110 tomorrow. I have the shop manuals so that info has been read. I was looking for pointers on doing it backyard style. The truck has a 6" lift and 35's. On cars I normally just use a jack and balance the trans one man style. But this thing is too much to do like that.
Thanks in advance,
Darrell
CRISPYSQRL is offline
Old 09-12-2009, 10:47 PM   #2 (permalink)
Use a motorcycle lift.
Ljutic SS is offline
Old 09-12-2009, 11:39 PM   #3 (permalink)
very good idea i think I even have a friend with one. Keep em coming thanks.
Old 09-12-2009, 11:40 PM   #4 (permalink)
Ranger_713's Avatar
Eat your Wheaties Darrell.
Values are typical and may vary by 10% depending upon current altitude, accessory operation, engine load, operating time, temperature, and vehicle speed.
Ranger_713 is offline
Old 09-13-2009, 04:27 PM   #5 (permalink)
lol
I build a cradle for the transfer case and transmission. So far everything is going well for doing it solo. The transfer case was a little stuck to the trans but nothing bad. Getting ready to pull converter bolts and bell housing bolts and lower this baby down.
But I have a question already looked at it and did not see an easy way to rotate the motor manually to get to all the bolts. Anyone have an answer?
Old 09-13-2009, 04:29 PM   #6 (permalink)
Oh here are a few pics too.
Old 09-13-2009, 07:17 PM   #7 (permalink)
Mark Kovalsky's Avatar
Originally Posted by CRISPYSQRL View Post
lol But I have a question already looked at it and did not see an easy way to rotate the motor manually to get to all the bolts. Anyone have an answer?
I use a large ratchet on the front of the crank. It's not that hard to turn the engine over that way while watching for the torque converter nuts.
Mark
Mark Kovalsky is online now
Old 09-13-2009, 07:19 PM   #8 (permalink)
that is what is would normally do but the crank is blocked by other things. I ended up just reconnecting the battery and bumping it over then getting under to check it.. got one left but it started pouring.
