Trans temp gauge - Diesel Forum - TheDieselStop.com
Old 05-03-2005, 04:18 PM   #1 (permalink)
Trans temp gauge
Having just got my motorhome back after a catastrophic transmission failure (not catastrophic enough however for Ford to replace it under warrantee: they told the dealer to repair it) I would like to add a transmission temperature gauge as on my new F250 SD. How complicated is the installation? Where in the ATF stream does the sensor go?
Mack
2004 Isata Motorhome E450 - 6.0L PSTD/Torqueshift
2005 F250 SD XLT 4X4 6.0L PSTD/Torqueshift
mack109 is offline
Old 05-03-2005, 05:08 PM   #2 (permalink)
Re: Trans temp gauge
The Isspro trans temp gauge on my '04 connects to a test port on the drivers side of the trans. A few wires to connect under the dash. Very easy. Mine runs about 160, not towing.
~2004 F-250 Quad cab long bed, 6.0L PSD,4x4 ~Torqshift Trans
~Arizona beige,tan interior
~Running boards w/custom Piranha LED lights
~ARE bedcap, Bedrug
~Foglight/high beam mod,BriteBox,HD light harness
~Zoodad mod, High idle mod
~Coolant filter, Oilguard bypass filter, Fumoto
~Isspro pyro,trans temp,boost in A-pillar
~Marinco Block Heater Receptacle
~Bodiak front hitch
~Mag-Hytec rear diff cover w/6qts syn fluid
~250 watt oilpan heater
~Scanguage
barnbridge is offline
