Transfer case will not go into 4 low - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 01-23-2006, 01:37 AM Thread Starter
I took the new truck hunting today and went to locked it in 4 high for awhile and everything seemed to work fine. I got to a pretty hairy spot so i thaught maybe I will put her in 4 low and see what she has. The transfer case would not enage into 4 low at all. I even had trouble getting it back into 4high and 2 wheel drive again.
Has anyone ever had this happen to them before ? I will be taking it to the dealership to see whats going on but thaught I would ask a few of you first
2008 6.4L F-250 King Ranch, Crew Cab, short Box, 4X4/ 373 gears
2006 f-250 4x4 supercab 6.0. never had a single issue. 41,000 miles.. SOLD
1995 f-250 4x4 regular cab 7.3 5 speed manual. 123,000 miles.. SOLD
larrylandgren is offline
post #2 of 9 (permalink) Old 01-23-2006, 01:45 AM
Banned
Re: Transfer case will not go into 4 low
Assuming that you have ESOF, did you ensure that the trans was in neutral (or the clutch pushed in), that the brake was applied and you were travelling less than 3 mph?
GrampyJim is offline
post #3 of 9 (permalink) Old 01-23-2006, 01:48 AM Thread Starter
What is ESOF ? I had the trans in park with my foot on the break like how i used to put it in 4 low with my older 7.3
post #4 of 9 (permalink) Old 01-23-2006, 03:27 AM
What is ESOF ?
Electronic Shift on the Fly, whereas you shift the T-case with a knob on the dash.
From the Owner's manual:
ESOF
Electronic shift on the fly (ESOF) 4x4 system (if equipped)
If equipped with the Electronic Shift 4WD System, and 4WD Low is selected while the vehicle is moving, the 4WD system will not engage. This is normal and should be no reason for concern. Before 4WD Low can be engaged, the vehicle must be brought to a complete stop, the brake pedal depressed <font color="red"> and the transmission placed in N (Neutral )</font> (on automatic transmissions or the clutch pedal depressed on manual transmissions).
MANUAL 4WD SYSTEM (T-Case stick on floor)
Shifting from 4H (4WD High) to 4L (4WD Low)
1. Bring the vehicle to a complete stop.
2. Depress the brake.
<font color="red"> 3. Place the gearshift lever in N (Neutral)</font> (automatic transmission) or
depress the clutch (manual transmission).
4. Move the transfer case shift lever
through N (Neutral) directly to 4L
(4WD Low).
5. If the transfer case will not
engage into 4L (4WD Low), drive
the vehicle above 8 km/h (5 mph),
then repeat steps 1 through 4.
Shifting from 4L (4WD Low) to 4H (4WD High) or 2H (2WD High)
3. Place the gearshift lever in N (Neutral) (automatic transmission) or
through N (Neutral) directly to 4H
(4WD High) or 2H (2WD High).
disengage from 4L (4WD Low), drive
6. If shifting to 2H (2WD High) with
the vehicle at a complete stop, disengage the locking hubs (optional) by
rotating the hub lock control from LOCK to FREE.
2013 F350 CC Lariat 4x4 6.7L
2003 F250 SC Lariat FX4 6L sold
AK6LPSD is offline
post #5 of 9 (permalink) Old 01-23-2006, 11:21 AM
rtfm
'06 F350 CC Red 4X4 Lariat auto
rickeg is offline
post #6 of 9 (permalink) Old 01-23-2006, 11:55 AM
PARK is your problem. Needs to be in neutral.
I have the lever on my '97 and while I *can* get it in and out of 4LO in Park if I really really wail on it, it slides in and out so much easier if I'm in Neutral. The new electronic control simply enforces that fact, to make it easier on itself.
Duncan
The 1997 F250HD Crewcab:
The 2000 XLT Excursion <font color="red">(SOLD)</font>:
The 2003 F250 Crewcab 6.0L:
The 6.0L Bible:
The 6.4L Bible:
frobozz is offline
post #7 of 9 (permalink) Old 01-23-2006, 05:11 PM
Duncan
Yep, gotta be in neutral with a foot on the brake pedal regardless of whether it is ESOF or manual.
2009 F150 Lariat, Crew, 4x4
Previous - 2004 F350, Crew, 4x4, 6.0l
newtodieseling is offline
post #8 of 9 (permalink) Old 01-23-2006, 08:25 PM
lincster's Avatar
My Photos: (29)
Yep, gotta have foot on the break and in neutral.
Owners manual says less than 3mph. I just stop and do the above.
I haven't had any issues.
I use 4WD Low at least 2 times a month.
2012 F350 4X4 Dually, FX4, Crew Cab, Ultimate Lariat Package, Oxford White, Black Leather towing a 2006 LE3905 Weekend Warrior
2002 F250 CC, 4X4 - Sold
2004 F350 CC, FX4, loaded - Sold
2006 F350 CC, DRW, FX4 - Sold
lincster is offline
post #9 of 9 (permalink) Old 01-23-2006, 09:44 PM Thread Starter
Still would not work with it in nuetral so I took it to the dealership and had a tech look at it and he said it seems like it needed some attention. Said that there is a external adjustment that should correct the problem. I will post it if thats the issue.
