Transmission Fluid - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 03-06-2008, 02:53 PM Thread Starter
Transmission Fluid
2007 F250 6.0
Time to change the transmission fluid. Does anyone know how many quarts I will need to refill????
bobbyc is offline
post #2 of 7 (permalink) Old 03-07-2008, 10:15 AM
bobsherrie's Avatar
It may be me but the link doesn't work.
'06 F350 Lariat SRW X-cab,4X4,Torqshift 5-speed Auto,w/23000lb GCVWR and many other options, Vandal Alert Cyclops, Pressure Pro TPMS, Extang Tuff TonnoIII, Duraflap mud flaps and Roadwing mud flap system, towing a Hitchhiker 33' Discover America 5'er and a Lund boat. Stock and doing fine. Coolant filter, Fuel regulator upgrade.
bobsherrie is offline
post #3 of 7 (permalink) Old 03-07-2008, 10:32 AM
jhamlin164's Avatar
These Strokers Take a Heap of Fluid....
Originally Posted by bobbyc View Post
2007 F250 6.0
If I'm not mistaken, I believe the complete flush will take 19 quarts! I think the Ford brand (Mercon SP) is what you need, but it doesn't come cheap!
2006 F-350, King Ranch, 6.0L PSD CC, DRW, 4X4
Kenwood Head Unit / Navigation system
Clarion LCD DVD player
Rancho RSX 9000 shocks
Line-X Bedliner
JL Audio ZR-570CSi speaker system
JL Audio StealthBox Sub
2 JL Audio Amps
2 Odyssey PC 1500DT batteries
DC Power 275-SP High-Output Alternator
Amsoil By-Pass system
Ford OEM Head gaskets
ARP Head Studs
Sinister Diesel Coolant Filtration system
Bullet-proof EGR Cooler
Blue Spring upgrade
Updated STC Fitting
Edge Insight CTS (monitoring only)
Big Three Wiring Upgrade
jhamlin164 is offline
post #4 of 7 (permalink) Old 03-07-2008, 12:09 PM
If you are just doing the drain, refill, and external filter recommended in the manual it takes about 8 quarts.
2003 Excursion Limited 6.0 PSD, Mineral Grey Metalic, 3.73 Ltd Slip, 2nd Row Buckets, Tele PWR TT Mirrors, DVD
dgreen1069 is offline
post #5 of 7 (permalink) Old 03-07-2008, 12:10 PM
JIM_C's Avatar
My Photos: (5)
It's not you - the link had an extra 'http' in it.
Try this one:
Truckblog - How-To Flush Ford's Torqueshift Transmission
2014 F250 Platinum CC Short Bed 4x4, 6.2 (I Got Gas Now!)
2003 F250 XLT CC Long Bed 4x4, 6.0 w/Auto (SOLD)
JIM_C is offline
post #6 of 7 (permalink) Old 03-07-2008, 01:29 PM
AllOutFirefighter13's Avatar
I'd just drop the pan, change both filters, and fill 'er back up. The norm is 8 quarts, but mine takes almost 10 when I do it, and my mom's took almost 11 when I did hers. If you're just changing the fluid, I'd pick up 12...whatever is left over can be kept for the next tranny fluid change. I'm not fully sure about the flush, so I can't give any advice there.
Later,
Joey
* '04 F250 XCab LWB 4X4 w/ FX4 *
* TorqShift *
* Manual 4WD *
* Carpet Delete *
* No. 2 ONLY *
* High-Idle Mod *
* Fumoto Valve *
AllOutFirefighter13 is offline
post #7 of 7 (permalink) Old 03-07-2008, 05:08 PM
ritschner's Avatar
Send a message via AIM to ritschner
Did mine last week at 30K miles. It took 8 1/2 quarts to refill. That was dropping and cleaning the pan and changing the external filter and the internal screen assembly. The next one will be an external filter change and flush.
White 06 F350 Lariet CC 2WD DRW Tow Boss, Timbren SES, Bilsteins, Smiths Ultimate Bedliner, RK Tool Box, CondensorGuard, IntakeMod, S&B Intake, SEIC, Banks 4"TB, Accufab elbow, Edge Attitude CS, Blue Spring Mod, DCPower 185a alternator, Rebuilt FICM, STC and Standpipe update, Harpoon Mod, Coolant Filter, Glove Box Light, Hood Insulator, Rewired Mirror Heat, Seat Heater Indicator.
ritschner is offline
