Transmission Fluid Temperature (TFT) sensor - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 01-28-2008, 08:03 PM Thread Starter
2003 F-250 6.0L need to replace the TFT sensor as it is bad. Can anyone provide a procedure for doing this. I know I have to drop the transmission pan but then what? Need a procedure. Please help.
Brian
hondakubota is offline
post #2 of 2 (permalink) Old 01-28-2008, 08:31 PM
POWERHORSE's Avatar
Just did mine a few weeks ago. Once you remove the pan locate the sensor in the valve body and remove the electrical connector very carefully. The sensor is about the size of a pen cap. To remove the sensor carefully unlock the stop tab and twist it, pull down to remove it. It comes out before a full quarter turn is made. Put it back in the reverse order. When you get the sensor to come out be prepared to catch the trans fluid that follows behind it, you will get less than a quart out of it.
{WRECKED} 2002 F350 7.3L
2003 F350 Lariat S/C 4x4 LB 6.0L, ATS Stage-V Trans, Amsoil Torque Drive ATF Fluid, Livewire SCT Flash, Stage II Injectors, VGT-SS Turbo, Fire Ring Heads W/Studs, Stage I Fuel System, All By Elite-Diesel Engineering, Air Dog FP-100, AFE Stage II Intake, FX4, Camper Package, Dual Alternators, XM-Radio, Cab Lights, C-Betr Mirrors, Rancho 5406 Stabilizer, Diamond Plate Side-Rails, Back Rack, Knaack 127 Saddle Box, Husky Floor Liners, Hadley Air Horns With Dual Tanks, 4 55 Watt Halogen Lights 2 Under Rear Bumper 2 Mounted On Back Rack, Galaxy DX 48T 10 Meter Radio, MBRP 4" Turbo Back to 4" Turn Out Stacks, No Muffler X-Springs, Rickson Haul-Rite's W/Michelin XDE MS 245/70/R19.5H, ART Brakes & Rotors, Led Sequential Turn Arrows And S\T\T Lights On Back Rack.
In the works, FS-2500(Just Ordered)
03 Honda Foreman Rubicion 500 atv, Warn A2000 Winch, Cycle Country 60" Snow Plow
POWERHORSE is offline
Similar Threads
Transmission Temperature Sensor Daren75 6.0L Power Stroke Engine and Drivetrain 8 09-24-2014 01:29 PM
transmission temperature sensor farmerx 7.3L IDI Diesels (Not Power Strokes) 5 07-23-2007 06:25 PM
Outside Air Temperature Sensor hypoxia 1999-2007 General Questions 1 07-03-2007 10:31 AM
Best location for transmission temperature sensor wooner '99 & up Upgrades and Aftermarket - 7.3L Engine 5 05-18-2007 09:48 AM
Transmission Fluid Temperature (TFT) Sensor bookem 6.0L Power Stroke Engine and Drivetrain 0 03-15-2007 09:47 AM
