Transmission maintenance question - Diesel Forum - TheDieselStop.com
Old 11-30-2006, 06:48 PM   #1 (permalink)
Hi everyone here is my question. First off I have 45000 miles on my 6.0 and I do some hauling not alot. So do I have my tranny flushed by my local mechanic or just change fluid? He is planning on flushing it and changing the external filter. Does this sound ok to you guys or would you recommend something different? Now would I be safe to buy the tranny filters off of E-Bay or not. My mechanic is going to price the fluid and filter from FORD tomorrow. Also if you could give me a basic idea on how you guys do this step by step Thank you for the input!
2004 F250 CREW CAB 156 WHEELBASE MOONROOF SPORT PACKAGE 6 DISC CD PLAYER CAMPER PACKAGE ROOF CLEARANCE LIGHTS ADJUSTABLE PEDALS 4X4 ESOF 3.73 limited slip rear advanced security group telescopic power mirrors DELUXE ALU WHEELS 6.0 AUTO DIESEL BLACK
UAW LOCAL 677 MEMBER
GARY2303 is offline
Old 11-30-2006, 06:59 PM   #2 (permalink)
Re: Transmission maintenance question
I paid $3.80 a qt for Mercon SP, I bought 10 qts and a MC filter on e-bay (got 2 for $25.00) I drained about 8.5 out of the pan and changed the external filter and re-filled, I have 45K on my truck also, the fluid was changed at 12K when my tranny was rebuilt under the recall, local dealers around here wanted $250ish for a flush. The internal filter is good for 100k miles.
2004 F-250 Crew Cab XLT, Auto, Short Bed, Arizona Beige, Fx4/Camper Pkg., 265's, Built 4/23/04, Delivered 4/27/04
Retrax Bed Cover,Crimestopper Alarm/ Keyless Entry/ Remote Start/ Skweeker Idle Up Mod/ Marinco Built in Heater Plug/ Dieselsite coolant filter
My Truck
2004/1997 Powerstroke Pics, Ford 9N Tractor,6.0 Bible
dwelch1 is offline
Old 11-30-2006, 07:15 PM   #3 (permalink)
I did the same as dwelch1 at 36K drain and filter. Got my stuff from Kman:
http://k-mansparts.com/Browse_dept_i...ilters__Fluids
KingVinnie is offline
Old 11-30-2006, 07:45 PM   #4 (permalink)
Hey guys, I'm getting close to replacing fluid/filters as well. Thanks for the link King, great prices on motorcraft stuff! I also want to change the fluid in the TC also, how much of a booger is that to do, what type fluid and do I have to take the tranny down to do this? I noticed a small rubber plug in the front of the tranny, is that access to perform such an operation? This is my first Powerstroke with an auto so I'm new to this part of the game.
New Truck: 2003 6.0L Dark Red F-350 Crew Cab Lariat FX4 Dually. Innovative Diesel Tuned SCT Xcal 2, Installed red lights inside cab and amber lights inside wheel wells (cool look). 5" Stacks Blowin' Black and the good ol' Train Horns!! More to add.
OLD TRUCK: 2000 F-350 DRW, 6-Speed tranny, 4 pos DP tuner, 10k mod, K&N FIPK system ---TOTALED by a snowbird motorhome!
http://community.webshots.com/user/ammo22100
curdog is offline
Old 11-30-2006, 09:27 PM   #5 (permalink)
i had mine to the Ford garage for a BG Flush and filter(external, internal) changed.. $138 for everything..
2003 F-350 6.0L CC/SRW/SB 3.73 Auto..
Edge Juice Platinum w/ Attitude just to monitor
Xcal2 w/ID tow w/JAKE,Street,Extreme Street
K&N FIPK kit
NO TURBO or ELECTRIC PROBLEMS
3 injectors, 1 set of head gaskets @ 95,000 miles
rebuilt tranny, plates and soleniods
built 03/27/03
craigwe is offline
Old 11-30-2006, 09:53 PM   #6 (permalink)
There is no drain for the TC in a TorqueShift. If you want to change all the fluid, you will either have to take it to a trans shop with a fluid exchange machine or do as some recommend and pump the fluid into a bucket from the heat exchanger hose while someone pours fluid in to replace what is pumped out. A rather inexact process. There is a thermostat involved in the heat exchange system so you will probably have to heat the new fluid to 175 degrees or so and be sure your tranny is hot.
Just be sure to use Mercon sp fluid. Nothing else is acceptable in a TorqueShift.
2003 F250 XLT Sport Ext Cab ESOF FX4 6.0L TorqShift, Sonic Blue/Black Leather.
BrakeSmart Trailer Brake controller.
Leer Cab high Browning Edition Cap.
2004 SunnyBrook Solanta 28' TT small slide 7800#
35 Years in the trenches!
Retired Machinist & Manufacturing Engineer for fuel control systems for very large Diesel Engines. Locomotives to Super Tankers.
Designed and trouble shot manufacturing processes for stuff from Design Engineers. Sometimes had to wrestle for design changes.
Designed and built tools and equipment to machine, assemble, disassemble, repair and test.
Wisdom comes with age, but sometimes age comes alone.
"Nothing is FOOLPROOF because fools are too ingenious"-Mark Twain
johnmart is offline
Old 11-30-2006, 10:13 PM   #7 (permalink)
I took mine to a local quick lube place yesterday, and they flushed the fluid and replaced both filters for $115. I asked them why the big price difference between them and the dealer which was $230 and the lady shrugged and said that they do alot of torqshifts and they buy the filters and Mercon SP from the same dealership that quoted me the $230. I was real pleased with their work.
fastmike926 is offline
Old 11-30-2006, 10:14 PM   #8 (permalink)
correct, ONLY Mercon SP fluid.. the torqshift is meant to build an maintain an operating temp.. the GM/allison trannys are meant to stay as cool as possible.. a much differnt oil is needed.
K&N FIPK kit
built 03/27/03
craigwe is offline
Old 11-30-2006, 11:38 PM   #9 (permalink)
i do not use mercon... but that may be due tot the fact i have different clutches in the tranny from suncoast.
2003 f250 crew...afe intake, gauges, 4 inch turbo back, sct tuner by Tadd , suncoast tranny.. Elite diesel studs and fire ring, stage one fuel kit, stage 2 injectors, Spearco intercooler.. ....aka HOT PURSUIT HAULER...
2006 badlands built moon buggy rock crawler rear engine turbo charged eco-tech.... aka HOTPURSUIT...FOR SALE pm for details
all vehicles running MAXXIS TIRES
hotpursuit is offline
Old 12-01-2006, 11:39 PM   #10 (permalink)
I don't mean to highjack the thread, but if there is no drain for the TC in our tranny's, does that mean there is no user maintinace I can perform for the TC? How strong are these TC's? Would it be smart to replace it with an upgraged TC if I'm using a SCT Extreme Race tune.
curdog is offline
Old 12-01-2006, 11:42 PM   #11 (permalink)
either have a place to the flush, or drain what you can from the pan, replace filters and call it a day....keep an eye on the fluid, you can tell if its burnt, and if you dont have one get a real temp gauge for the tranny and keep an eye on your temps... tranny may hold up to the sct depending on your driving habits.
Old 12-02-2006, 05:00 PM   #12 (permalink)
Hi everyone well I made some progress on this tranny maintenance issue. My mechanics friend works at a FORD dealership and he just recently did a 6.0. When asked he said to just drain the tranny fluid and replace the external filter only and thats it. He said that FORD does not recommend flushing this transmission. My mechanic was going to use a mechine and flush the tranny however I told him lets do what is recommended. Hope this helps some others out oh positively only use Mercon SP fluid.
GARY2303 is offline
