I know this subject has been beat to death. However; I just don't know what to do. I can not seem to find any guideance from Ford. The manuel says "service the transmission at 30000 miles" What is the recommended method for serviceing the transmission. One ford dealership stated just change the external filter and flush the entire system. Another dealership stated to change the external filter then drain and re fill. Both stated no need to change the internal filter.
I have been thinking of changing the external and internal filter myself then re filling driving a few hundred miles then draining and re filling again. What does everyone think.
21999 F 350 super duty 7.3 Lariet 2wd srw white 78000 miles when sold. Very minor warrenty work. Used mainly for heavy towing
2003 F 350 Crew cab 6.0 Lariet. 2wd srw Arizon beige,Clearence lights,Adj Pedals,Heated Mirrors
Ordered 10/01/2002
Build date 1/20/2003
Dilvered date 2/14/2003
Dead and to the graveyard 4/15/2003 with 2700 miles
2003 F 350 crew cab 6.0 lariet 2wd srw Arizona beige,clearence lights,adj pedals,heated mirrors
Ordered April 22
Build date may 5
Delivered may 24
Towing 2001 36 foot coachmen 5th wheel prospera
Sold
Now towing a 36 foot carrige Carri lite 16k
5,2003. Towing 36 foot Carri-lite with 3 slides
I'm not at that point yet but when I do get there I would change both filters and fluid. Dosen't it seem if you don't that the service is only half done??? When it came from the factory it had new fluid and fiters.
It sure does. But why doen't ford just recommend it. Most dealerships just want to change the external filters. The tech i have used with over good sucess says it is not necessary to do the internal filter. He says it really is not a filter more of a screen that never plug up.. Just a wast of time and money.
Ordered 10/01/2002
Ordered April 22
Build date may 5
Delivered may 24
Sold
[/ QUOTE ]If a tech give you his honest opinion,how come you don't take his advice.I just sold a truck with over 155,000 miles and NEVER changed the internal filter.I changed the fluid at 30,000 miles and the external filter every 10,000.I hope this helps you make a decision!Good Luck! [img]/ubbthreads/images/graemlins/grin.gif[/img]
I've got 51K on my trans. Dealer has never recommended a trans fluid nor filter change. I need to do this myself. Where's the external filter and do I need to drop the pan?
2003 F250 6.0 4x4 King Ranch Crew
96K So Far
Sinister EGR delete with up pipe
Sinister coolant filter
Pure Diesel CAT delete
Mile Marker manual hubs
Procoat liner
Husky mats
Fumoto valve
International HFCM plug
Dieselkleen additive
I just had the dealer flush my trans. But they didn't recommend changing the external filter yet. I thought that was B.S. since the manual clearly says to change it. I have a filter here and will try to change it in a couple of weeks when I do the fuel filters.
The external filter on mine is located toward the front passenger side of the engine. I believe the best access for it will be to crawl under the front of the truck, near the passenger side tire.
2005 Arizona Beige F350 XLT FX4 6.0 CC shortbed, 3.73 ls rear, 18" wheels, Tow Command. Additions: Vent Visors, bug guard, Fumoto Valve, Timbrens. Traded for...
Current Truck -- 2008 Black F350 XLT 4x4, 6.8 V10, CC Long Bed, 4.10 rear, 18" wheels, IBC. Additions: Chrome Step Bars, Chrome door handles, Silver barbed-wire pin stripe, B&W Turnover GN ball
had a torqueshift, I'd do a pan drop (8qts), and external filter at 30, and a full fluid replacement at 60k (20 qts). The internal filter is a metal screen, and needs to be inspected & possibly cleaned, bu not replaced.
I don't tow heavy or drive in severe conditions, like heavy stop/go, dust, etc, so I figure the fluid should be in good shape to 60k.
If you drag race, sled pull, have a chip or tuner, all bets are off, and service should be done on a much sooner basis.
if I decide to have the dealer do it. What should I get ready to put out for the service?
I checked out my invoice from a couple weeks ago. It was $188 [img]/ubbthreads/images/graemlins/eek.gif[/img], not counting the external filter. I'm going to change the external filter myself. From this point on, I'm going to drain/refill and change external filters at 20K intervals.
Think mine was about $150 for the dealer to to the flush.
__________________ 2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
consider that Mercon SP is about $5 a quart, and it takes about 20 qts to do a good flush, plus another $20 for the external filter if you do it at home...
Dealer quoted me $199 for the flush and and addional $101 for the remote filter change. Asked twice about the remote filter and yes it was $101!! I think that I will have the dealer flush and I'll change the remote filter for $14.
96K So Far
Procoat liner
Husky mats
Fumoto valve
