Travel trailer- charging my trailer by keeping it plugged into my truck - Diesel Forum - TheDieselStop.com
Old 12-16-2008, 10:34 PM   #1 (permalink)
How do I go about utilizing keeping my trailer plugged in to charge my trailer batteries when the trailer is plugged in it doesnt charge my trailer used to on my chevy
TADEO159 is offline   Reply With Quote
Old 12-16-2008, 10:44 PM   #2 (permalink)
chuckster57's Avatar
I used to be able to leave my trailer plugged into my old '86 gasser and get juice. When I bought my '94 (sig) I thought the same thing until I found that there is a relay that shuts off the power feed to the trailer plug unless the key is in the "run" postition. It may be a safety feature IDK
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now   Reply With Quote
Old 12-16-2008, 10:50 PM   #3 (permalink)
Thanks for the input
Old 12-17-2008, 06:41 AM   #4 (permalink)
The power plug is only "hot" with key on as mentioned. If the plug on truck is "hot" all the time then you have a huge risk of having a dead truck if something on trailer is drawing current when truck is off and it killls the battery in trailer and both on truck.
What year GM truck had a continuous power feed?
Also, your trucks power feed to trailer plug is fused and uses an underhood relay. If it is not "hot" with key on then check those items.
2006 F450 CC Hauler bed 4x2 6.0 L Pstroke/Torqshift, Lariat, 4.30 r/a.
2006 F350 Lariat CC Dually 4X2, 6.0 TQShift 4.10 LS, STOCK.
36 foot double tandem axle flatbed trailer.
36 foot Sooner 6 horse large dressing/ mid tack.
15 horses with good balance from being hauled behind a P'stroke.
jimmy is offline   Reply With Quote
Old 12-17-2008, 07:54 AM   #5 (permalink)
Scot06's Avatar
Our 2000 silverado has the constant trailer feed.
06 F-350 4X4 XLT CREWCAB 6.0 w/ 205K
Odyssey batteries, FS-2500 oil filter, Dieselsite coolant filter, Line-X all over.
Original HG, oil cooler, egr cooler & still going strong.
Scot06 is offline   Reply With Quote
Old 12-17-2008, 09:29 AM   #6 (permalink)
This is a bad idea in general, and I wouldn't recommend it unless its a total emergency. Its true you can feed power to your trailer with the truck running, but its not a good practice, unless you have a dual alternator system. The standard truck alternator is not designed to handle that kind of loading. You need to be at high, sustained rpms for the alternator to do a good job of charging. Just running at idle the truck's electrical needs are taking most of the alternators capacity with little reserve to charge the truck's batteries let alone the added draw of a trailer.
I'd highly recommend either a solar system, or a small Honda generator for maintaining your trailer's electrical systems if your in storage mode or boon-docking it. If you are in storage mode, look into a good battery tender, or upgrade your trailer's converter to one that has a charger/tender feature & hook into shore power. Whenever you are in storage, remember to check your battery(ies) on a regular basis to avoid running out of electrolyte.
This is also a good idea if you are not using your truck for more than a month or two. Its a good idea with a 6.0 to exercise it on a regular basis ( like every week or two), to keep the turbo in shape.
OMC
OMCUSNR is offline   Reply With Quote
Old 12-17-2008, 12:05 PM   #7 (permalink)
MikeL46's Avatar
My Photos: (14)
Our 2000 Silverado has a relay and a 2nd battery for the trailer feed. Only the aux. battery will go flat if the trailer has a problem.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
106345 miles. 16.65 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
MikeL46 is offline   Reply With Quote
