Trip Computer MPG reading - possible correction - Diesel Forum - TheDieselStop.com
Old 03-14-2005, 10:34 PM   #1 (permalink)
Just something fun ... tired of reading about all the broken stuff. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Not saying this will work on all trucks, but it appears to have worked on mine...
Since new, I have calculated fuel mileage by hand and have compared it to the MPG reading stated on the overhead computer. On average, the overhead would be off by about 1.0 - 1.5 MPG in comparison to my hand calculations (overhead stating higher MPG then actual hand calc).
During our last trip this past weekend, I decide to try something ... I reset the MPG computer while we were driving - I did this several times during the trip. This would cause the computer to reset to 0 MPG and then climb to say 25 MPG and then finally adjust to the current MPG or cruising MPG. This was done on our way to our destination.
During our return home, I filled up, reset the computer and set the cruise control at 70 MPH. When we got home and refilled the tank, I hand calculated 20.6 MPG and the overhead computer stated 20 MPG. This was the first time my hand calculation was more then the overhead. Of course I am skeptical that the "correction" will hold, but it was interesting to see that the reset while driving may have made a difference ... Time will tell.
- J
04 Excursion Limited 6.0 PSD 4x2, Hellwig rear sway bar and Firestone bags.
08 VW R32
Cheetah DSR
Jaysom is offline
Old 03-14-2005, 10:38 PM   #2 (permalink)
FamilyRide's Avatar
Re: Trip Computer MPG reading - possible correction
It was pure luck. Only way to get it right is to reset when you fill up so your hand calc and the overhead are measuring/calculating the exact same thing.
FWIW, mine's always almost right dead on. I guess I got lucky. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
FamilyRide is offline
Old 03-15-2005, 02:59 PM   #3 (permalink)
hottip's Avatar
I noticed that the trip computer will register correctly if you hit the reset button while driving. It will search up and down and finally get the number right. Then I do the hand calculation and its within a 1/2 gallon. My Lincoln Town car worked the same way.
2005 Lariat 6.0 LWB fourx4 3:73 Silver Metalic, Heated Captains chairs, Tow Command, Reverse Sensor, Intergrated Brake Control, Power Rear Window
MBRP Turbo back exhaust, Glasstite Canopy, billet grill, 145K+
Scan Gauge 2
Lucy - Wife
Bear - Flat Coated Retriever
2000 HD Road King
1998 Campion 542 Explorer fishing machine
I started out with nothing and still have most of it left....
hottip is offline
