Troubleshooting a "no Start" condition - Diesel Forum - TheDieselStop.com
Old 03-19-2010, 08:17 PM   #1 (permalink)
Troubleshooting a NO-START:
1. Pull diagnostic trouble codes (DTC's) if you can (you can have codes without a Check Engine Light).
2. Automatic transmission shift lever fully in PARK or NEUTRAL? Try restarting while slightly moving the gearshift lever.
3. If manual, clutch pedal fully pressed?
4. Battery connections (all including grounds) - all good? Alternator cable connections good?
5. Starter relay connections - all good?
6. Glow plug connectors making good connection?
7. Is the starter engaging? Verify starter and ignition switch are working properly.
8. Load test BOTH batteries individually and check the charging system (alternator). PCM needs to see 100 rpm minimum to start IIRC.
9. Fusible links and fuses OK? The FICM relay is labled IDM Relay #304. Check it specifically.
10. Could a factory or aftermarket anti-theft device be causing the problem (Passive Active Theft System - PATS)? Disconnect it if possible. Same w/ a remote start system.
11. Push the reset on the emergency fuel cut-off switch.
12. Any oil pressure registering on the dash pressure gauge (low pressure system)? If not, it could be a bad oil pump (LPOP), a oil filter drain valve stuck open, or a bad oil pressure regulator. You should register oil pressure on the dash gauge in a long crank/ no start condition when the complete oil system is known to be sealed.
13. Check PCM and FICM connections - any wire chaffing? Any Injector harness chaffing? Any ICP or IPR harness chaffing? More detail below.
14. Verify that the oil level is correct and the proper oil and filter have been installed. Oil foaming and loss of viscosity (too thick or fuel diluted) can be an issue. Check oil level for fuel dilution, inspect oil condition, maybe even change oil and filter. Definitely make sure you filled w/ the proper oil.
15. Verify that the air filter is not plugged - Check the filter minder and you may even want to pull the air filter and inspect.
16. Inspect the ICP sensor and harness. Is it oil soaked? Disconnect
the ICP and try again. The PCM will establish a default control scheme that would allow the truck to start if the problem were the ICP sensor. Afterwards, make sure the harness is re-installed securely. Also, check ICP circuit fuse.
17. Change both fuel filters, inspect appearance of the fuel when draining the water separator (you could just have bad fuel).
Make sure that the air is purged on start-up. By following the proper (KOEO) cycling procedure before cranking."
18. If you can, verify the fuel pressure (test port is at the base of the secondary fuel filter). Must be over 45 psig.
19. If you have no fuel flow or low pressure, it could be a bad pump (HFCM), OR it could be a plugged fuel filter or plugged lines. You can blow air through the lines to check for plugging. If there is no pluggage, test the pump. First, pull fuse 302 (PCM) and relay 304 (FICM) and then pull the secondary (upper) fuel filter, remove any fuel, and then verify that it is being filled by cranking the engine. As it is being filled, make sure there are no air bubbles. If there are, you have a leak in some connections, the HFCM suction line, or the HFCM o-ring (most likely). Be sure to lube the o-ring w/ oil before re-installing.
TO CHECK FOR SUCTION LINE PLUGGING:
The pump vacuum test is refered to as an ""inlet restriction test"". This will test from the pump to the tank for a restriction. A reading that of more than 6"" H2O vacuum is very bad. 6"" is the max limit. The normal reading is between 2"" and 0"" of H2O.
To do this test you would need to ""T"" a vacuum gauge in between the back of the pump and the line coming into it. If you have a high reading there, then move the T to the tank at the outlet line. If the restriction is still present at the tank, then the problem is in the tank. If there is no restriction at this point, then the issue would be with the supply line to the pump."
20. Pull the oil filter top and have someone crank it while you watch to see if any oil is flowing into the filter housing. If not then it is a LPO problem. Take a long extension and hold down the check valve (round black thing held up by a spring). Have someone crank the engine. The housing should fill within about 10 seconds of cranking.
21. If possible, verify high pressure oil pressure (ICP sensor) - must be over 500 psig to fire the injectors. See link below.
22. Pull the EGR valve and inspect. Clean if dirty. Check the strength of the spring. Consider replacing it - just because. Also clean the MAP sensor hose and the EBP tube. These may cause surging and hard start, but a long shot for a no-start.
23. Troubleshoot the glow plug system (you need a clamp on inductive ammeter). Test each glow plug module wire bundle separately, then test each glow plug. Look for any amperages lower on one side or lower to an individual glow plug. From each module you should see 200 A at first dropping quickly to 35-37 A if the GPCM is OK. Both modules should read apprx. the same. Each glow plug will draw 8-10 A. Or you could check the resistance in each glow plug - should be less than 1 ohm.
24. Carry out the KOEO Injector Electrical Self-Test (Click Test) and the bubble test.
25. Check the Crank (CKP) and Cam (CMP) sensor wiring harnesses.
26. Check the FICM voltage - see post #2 of this thread (below).
Wire Chaffing Locations:
http://www.*********.com/forums/showthread.php?t=58336
(insert as one word "the diesel garage" where the asterisks are)
FICM and ICP harness recall
http://www.forddoctorsdts.com/photographs/index1.php
http://www.forddoctorsdts.com/articl...icle-05-13.php
http://www.forddoctorsdts.com/articl...icle-05-11.php
Search for a thread entitled "Just recieved a recall letter. Anybody else" in the form: The Diesel Garage (all one word).
mms://multimedia.ford.com/seopts/Tech12_250k.wmv
(in the link above you may have to copy and past the address in your web browser to access the video from Ford.
h t t p://turbodieselforums.com/downloads/6.0L%20wire%20chafing.pdf
(copy and paste the URL above in your browser - without the spaces in http)
h t t p://turbodieselforums.com/downloads/Econoline%20Wire%20Chafe.pdf
TROUBLESHOOT THE HPO PRESSURE SYSTEM:
http://www.itpdiesel.com/store.php?s...fault&x=61&y=8
In the ITP search page enter "high pressure oil" and click on the drop down "Look For" and select "exact phrase". Go to page 2.
Determinimg if the ICP sensor is seeing 500 psig minimum:
http://www.ford-trucks.com/forums/86...not-start.html
scroll down to post #23 in the thread linked above.
If possible, you can pull the ICP and install a pressure gauge to check the pressure in the “high pressure oil system”. Crank the engine and watch the pressure. You need 500 psig to start. The fitting needed for this is the same as that for the fuel pressure test port.
Here is a way of checking to see if you have sufficient high pressure oil without having a gauge or adapter. Strip back the wires about an inch away from the icp sensor connector. Obtain a digital multimeter and set it for voltage (DC). The bn-wh wire is a five volt reference, leave that alone. Strip back the db-lg signal wire and the gy-rd ground wire. Put positive lead on a dark blue-light green wire and negative lead on gray-red wire. Have an assistant crank truck, you need a minimum of 0.80 volts (500 psi) for the truck to start, if you are getting greater than that then you have sufficient high pressure oil.
To check your ipr and hp oil system:
1. Get an ipr connector from Ford and put 2 long wires on the end, plug it into the ipr. Later you will attach the 2 long leads to b+ and negative ...... this will close the ipr.
2. Then remove your icp sensor (04.25 and up truck??) from the passenger side valve cover and thread a fitting in with an air fitting on the end (so you can apply compressed air to the hp oil system).
3. Remove your oil fill cap, your intake up to the turbo (get the ccv out of the valve cover at least), and the hot side cac tube.
4. Then, command the IPR closed for only 30 seconds, apply 100psi air to the hp oil system and listed to where the leak is coming from.
When you hear it you've found your problem....that is assuming you have a hp oil problem.
If your building low and high oil pressure fine, then you've just wasted your time.
Generally on no-start conditions that are related to "high pressure oil" leaks, the vehicle will still develop low pressure system pressures. However, the plug on the H.P. oil feed can occasionally blow out, the H.P. pump seal can blow out, and on the '03-04 trucks the ball on the side of the H.P. pump blow out - causing loss of base oil pressure.
Hard start - no start conditions related to the HPOP could be attributed to the following components in the high pressure oil system (air test while hot will determine the root cause):
http://www.fordtruckfanatics.com/for...ad.php?t=11583
Faulty IPR valve
Leaking snap-to-connect (STC) fitting (05 and up model years)
Leaky or cracked branch tube
Leak with the stand pipe
Leaky or cracked oil rail (including oil rail end caps/plugs)
Leak in the d-rings of the oil rail front port plugs (or dummy plugs)
Leaky o-ring on an injector; or leak at the top of the injector where the ball tube from the high pressure oil rail connects to the injector.
Weak or failed HPOP itself
Low base oil pressure (failed oil pressure regulator).
Low base oil pressure (bad low pressure oil pump - LPOP).
Post #3 below has a low pressure oil test procedure
Post #4 below has another reference to a no-start checklist
One easy check for injector problems: SEE POST #5 below
"When injectors fail, it is possible for combustion gasses to flow into the fuel system and displace the fuel. The gasses come through the pintle seat and into the fuel galley in the head and up into the fuel filter.
Crank Shaft Position Sensor (CKP)
http://www.ford-trucks.com/forums/al...ictureid=15905
http://www.ford-trucks.com/forums/al...ictureid=15906
http://dan.prxy.org/Truck/6L_bible_h.../Page_052.html
Cam Shaft Position Sensor (CMP)
http://dan.prxy.org/Truck/6L_bible_h.../Page_010.html
http://dan.prxy.org/Truck/6L_bible_h.../Page_053.html
Mark
bismic is offline
Old 03-19-2010, 08:18 PM   #2 (permalink)
Link to the FICM test procedure:
http://www.ford-trucks.com/forums/89...procedure.html
and the FICM repair thread:
http://www.ford-trucks.com/forums/90...procedure.html
Also:
http://www.thedieselstop.com/forums/...cedure-244155/
FICM Soldered / Cold Start issue resolved
Mark
bismic is offline
Old 03-19-2010, 08:20 PM   #3 (permalink)
Low pressure oil test procedure.
Using a suitable adapter (such as Aeroquip® 2022-4-4S), install it in the engine oil pressure sensor hole to carry out the base oil pressure test.
Install gauge to check the base oil pressure. The minimum engine oil pressure specifications are 82.7 kPa (12 psi) at 700 rpm, 165.5 kPa (24 psi) at 1,200 rpm and 310.3 kPa (45 psi) at 1,800 rpm with the engine at operating temperature.
Mark
bismic is offline
Old 03-19-2010, 08:21 PM   #4 (permalink)
Here is a good checklist for "Hard Start - No Start"
h t t p://turbodieselforums.com/downloads/05%20Diag%20Sheet.pdf
Mark
bismic is offline
Old 03-19-2010, 08:22 PM   #5 (permalink)
Injector o-ring (or other failures) can cause a no-start condition. One easy check for injector problems:
Pull the fuse cover under steering wheel with a flat blade screw driver turn the screws 1/4 of a turn. Pull fuses 20 FICM, 40 Fuel pump, and 103 PCM. You might need a fuse puller or needle nose pliers. Be sure there is fuel above the standpipe. If you want pull fuse 40 last and use the fuel pump momentarily to fill the fuel filter housing. Then have someone crank while you watch for bubbles. Do not crank on it for more than 10 seconds max. This is the easiest way to determine mechanical condition of injectors. What happens is combustion gas will come through the pintle seat and into the fuel gallery in the head and up into the filter.
http://www.ford-trucks.com/forums/81...in-a-6-0l.html
See post #18 in the thread linked above.
Mark
bismic is offline
Old 03-19-2010, 08:36 PM   #6 (permalink)
teamroper60's Avatar
Thanks Mark!
I made this a "sticky".. Eventually, I will move it to the FAQ, but for now it will remain here..
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 03-19-2010, 10:54 PM   #7 (permalink)
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
Thanks teamroper and bismic this is a very common question and it is very informative.
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
Old 03-20-2010, 04:12 PM   #8 (permalink)
fordnatic68's Avatar
This is the info I was after as well. Im having a no start problem as well, sounds like it wants to catch but wont. FICM is 48.5, filters are clean, new ICP(not harness) no evidence of an oil leak. Im gonna work thru the info you all posted n eliminate them til I find it. But if my problem sounds familiar Im all ears. Thanks guys!
03 F350 6.0 XLT Lariat Born 12/21/02 Crew cab short box loaded to the nuts
Autometer Guages - Pyro, Boost, Tranny, Oil Temp, Oil pressure,F & R Diff Temp,Voltage, Fuel & HPOP
Custom dash mods to clear up clutter ontop and eliminate blind spot at A pillar
Edge juice w/ attitude ( unlocked)
Banks Intercooler, Hi ram intake n tubes
Twin Optima yellow tops
BD 5" exhaust
Snow Performance Water/Methanol injection w 7 gallon tank (water only)
EGR Delete Kit
Silverline twin 8" slash cut stacks
New stock Ford Hpop
New stock Ford oil cooler (waiting for BD's version of remote cooler filter kit)
Garrett Powermax GT3788VA Turbo
Airaid cold air intake
Zoodad mod
10.5 " Procomp lift (really 8.5 w some mods)
42" good year wranglers w Kevlar sidewalls
5" Bushwacker cut out Flares
Goodhood Dual ram air fiberglass hood from US body
90 F250 Extended cab long box 460 auto
57 Mercury stepside
fordnatic68 is offline
Old 03-25-2010, 04:10 PM   #9 (permalink)
6.0 Excursion
Having a wierd one here myself. My wife got in our Excursion to run to the store and did the normal wait til plugs warmed up and turned the switch and nothing she came and got me and I did the same. All the gauges peg out first and then it almost starts and then just clicks. Any ideas???? You can reply here or send straight to email as I am out in the garage trying to get this started.
doggleggup is offline
Old 04-21-2010, 08:23 PM   #10 (permalink)
I have a strange one also. Did headgaskets, egr cooler, oil cooler and egr. Took the cab off to do the job. Reassembled all and tried to start. Truck started momentarily but quit. Didnt start again. Verified voltage to batteries. They were old so replaced with two new Motorcraft batteries. Checked connections to IDM and they were all good. Scanned and had codes for every single glow plug, cam, crank sensors, and injection voltage high. Rechecked all the harness plugs and found I left the wire going to the passenger side positive post on the battery. Reconnected and still will not start, but codes are gone except the obglatory p1000. Any clues, help?
Thanks!
10secL is offline
Old 04-21-2010, 10:44 PM   #11 (permalink)
It takes awhile to get all the air out after an oil cooler replacement. Also, if you are not extra clean, you can damage the IPR (plug the screen).
Mark
bismic is offline
Old 04-22-2010, 12:51 PM   #12 (permalink)
Well, i may have found the problem. The screen that was below the oil cooler was left out. It was laying on the ground under the truck. This will not allow the truck to start will it?
10secL is offline
Old 06-19-2010, 04:30 PM   #13 (permalink)
neomist's Avatar
I would replace this with check fuses, simply because in my experience if you have a "no-start" issue you could have blown the 30 amp ignition fuse. 2 would become 3 and so forth...
Good post! Thanks for the work in putting this together!!
Justin
Edge Insight CTS
Mishimoto Intercooler
Powermax Turbo
ARP headstuds
Black onyx headgaskets
Black onyx exhaust gaskets
Sinister EGR Delete kit
Large mouth CFM kit
Banks Ram-Air intake
C2 gauges cluster (boost, fuel, trans, EGT) by the way i hate these gauges
Casserly 155cc injectors (best injectors ever!!)
4 inch turboback MBRP exhaust
DieselSite Coolant filtration system
SCTX3 programmer
Custom tunes from Innovative Diesel
ITP Regulated fuel return
AirDog II
35in Toyo Open Country tires
neomist is offline
Old 09-21-2010, 04:54 PM   #14 (permalink)
Im working on an 04 e 450 cube van keeps blowing a number 8 fuse causing it to not turn over and the glowplugs to not cycle. Any ideas where i should start looking here?
duthie is offline
Old 09-21-2010, 06:21 PM   #15 (permalink)
I would look for wire harness chaffing first - but I REALLY do not like to mess w/ electrical problems.
Maybe some other folks (more capable than I) will jump in.
What is serviced by #8 fuse?
(Oh BTW - you will surely get more responses if you start a new thread)
Mark
bismic is offline
