Truck Just Dies - Diesel Forum - TheDieselStop.com
Old 05-17-2010, 07:25 PM   #1 (permalink)
Truck Just Dies
I have a 2003 Ford F350 6.0 When the truck is idleing sometime it will just die as if you turned the key off. It will restart no problem. Some times in idle the RPM's Will go up and down 3 or 4 times than it my or may not die. I have change the filters with no luck. Any ideals??????
Thanks pkbell
pkbell is offline
Old 05-17-2010, 08:53 PM   #2 (permalink)
TousleyParts's Avatar
Any codes by chance?
Possibly could be a sticky EGR
We are Tousley Ford parts depot selling all OEM Ford and Ford Racing parts 10% over dealer cost. We sell heavy truck parts as well!
Please PM me for any price requests
Call us at 1-800-328-9552 ask for Gene or Mike R OR check out our website www.tousleyfordparts.com Be sure to mention this website for the good discount.
TousleyParts is offline
Old 05-17-2010, 09:12 PM   #3 (permalink)
Possibly wire chaffing.
Wire Chaffing Locations
Upper left valve cover or valve cover stud, near the FICM
Idler pulley under the thermostat (wiring routed around the power steering pump)
Left front valve cover hold-down bolts/studs
Exhaust Pressure (EP) sensor bracket at thermostat housing
Right valve cover at Glow Plug Control Module (GPCM)
Accelerator Pedal pivot point under dash
PCM harness at battery box
CKP wiring near A/C compressor and belt tensioner
Front left of intake manifold near breather tube and air inlet duct
Injector harnesses
Check injector harnesses and FICM harness for backed out or bent pins
FICM and ICP harness recall
http://www.forddoctorsdts.com/photographs/index1.php
http://www.forddoctorsdts.com/articl...icle-05-13.php
http://www.forddoctorsdts.com/articl...icle-05-11.php
mms://multimedia.ford.com/seopts/Tech12_250k.wmv
(in the link above you may have to copy and past the address in your web browser to access the video from Ford.
http://turbodieselforums.com/downloads/6.0L%20wire%20chafing.pdf
http://turbodieselforums.com/downloads/Econoline%20Wire%20Chafe.pdf
Mark
bismic is offline
Old 05-18-2010, 10:39 AM   #4 (permalink)
speedrcr78's Avatar
Does it seem to happen when you hit bumps? I had the same issue and what happened was the connector for the throttle body had worked itself loose and was grounding out against one of the fuel lines. I am sure this is just the same as having a wire chaffing issue.
speedrcr78 is offline
