Truck quits - Diesel Forum - TheDieselStop.com
 2Likes
  • 1 Post By Phil G.
  • 1 Post By Jimbo40
post #1 of 11 (permalink) Old 02-11-2017, 06:28 PM Thread Starter
Truck quits
Hi there everyone I don't understand what is happening. Every so often I loose all electrical power and the truck just shuts down just like that. The truck is a 2003 f250 with the 6.0L. Also I keep getting a battery light coming on. Would this indicate an alternator issue? It has 183,000 on her
Sent from my iPad using Tapatalk
ben.ramler2010 is offline
post #2 of 11 (permalink) Old 02-11-2017, 08:03 PM
Pull and bench test the alternator.
I would also charge and then individually load test the batteries.
Continuing down this path (with electrical issues) can kill your FICM.
Mark
bismic is offline
post #3 of 11 (permalink) Old 02-13-2017, 08:43 AM
Phil G.'s Avatar
I would suggest you check your wires and connections for cleanliness and possible breaks as well. Focus on the red wire coming off the drivers side battery and the fuse box next to it.
2007 F350 SRW 6.0L Auto, 3.73LS, 172"WB 4x4. Viper Alarm/RS, WD pillar Guages,AutoEnginuity, 100gal polished alum fuel tank.
All Sold: 99.5, early03 , 2004 - all were 172" wb 4x4 lariat's.
My Worklog:
Phil G. is online now
post #4 of 11 (permalink) Old 02-13-2017, 01:18 PM Thread Starter
Truck quits
So the alternator has been rebuilt, so now on the way to work the truck acts like it wants reset everything and I lose electrical power but it all comes back. The engine did not shut down.
post #5 of 11 (permalink) Old 02-13-2017, 02:29 PM Thread Starter
My mistake the truck has 138,000
post #6 of 11 (permalink) Old 02-14-2017, 09:42 AM
Did you check the wires as Phil G. suggested and load test the batteries as I suggested?
Mark
bismic is offline
post #7 of 11 (permalink) Old 02-18-2017, 10:20 AM Thread Starter
After having the truck towed back to the house I discovered something really odd....why is there 2 batteries for the 6.0? I pulled the cables off the drivers side battery and the truck starts and runs fine. Battery issues maybe?
post #8 of 11 (permalink) Old 02-18-2017, 01:09 PM
Phil G.'s Avatar
There are two batteries because of the heavy demand of the glow plugs and hi power starters required on a diesel. All diesel pickups use 2. The fact that you moved the red batt cable on the DS batt to disconnect it and the problem resolved brings me back to my hunch you have an issue with the heavy red wire connected to the "+" post on that battery. I'll bet if you wiggle that red wire just the right way, you can get the problem to repeat itself.
bismic likes this.
My Worklog:
post #9 of 11 (permalink) Old 02-18-2017, 01:35 PM
Good suggestion Phil G. And, he also needs to INDIVIDUALLY load check the batteries as well.
Mark
bismic is offline
post #10 of 11 (permalink) Old 02-18-2017, 02:38 PM
And both batteries good and the same or same cold cranking amps and size. Otherwise 1 can drag the other down. if 1 won't hold a charge then the other wont either because the bad 1 will drain the good one.
bismic likes this.
Jimbo40 is offline
post #11 of 11 (permalink) Old 02-19-2017, 04:29 PM
ALWAYS replace 6.0 batteries as a pair. If one load tests weak; replace them both. The batteries need to be a matched set of they are constantly fighting each other as they are connected (the weak one is discharging the strong one, the strong one is trying to charge the weak in an attempt to reach an equilibrium that is impossible).
'06 F250 4x4 - 5" Flo Pro exhaust, SB Filter intake, Accufab elbow, Edge Evolution (monitoring only), SCT w/ ID custom tune, FASS 195 pump, Gillette Diesel EGR cooler delete, Sinister Diesel coolant filter, ELC coolant, updated turbo drain tube/oil feed line/STC fitting/oil cooler, ARPs w/OEM HGs, Elite coolant lines, ITP RR fuel system, RCD 175/30 injectors, Powermax, BD CCV, FICM.com FICM w/ ID tune, Elite UP, BPD water pump - 13.069 @ 101.94
'02 WRX - Outback rear disc swap, EBC green pads, DBA pillar vane rotors, TXS UP/TBE/TMIC, Perrin LW crank pulley, PPG billet steel shift forks, ACT Streetlite flywheel & clutch, K&N filter, STi Group N motor/trans mounts, TiC/Kartboy rear diff mounts/subframe lock bolts/outrigger stiffeners, Kartboy SS & all shifter bushings, custom PDX tune for Cobb AP - went 14.1 on a terrible 60ft before most of these mods; shooting for 13.50s
TKOPerformance is online now
