truck reflashed - Diesel Forum - TheDieselStop.com
Old 08-25-2006, 03:53 PM   #1 (permalink)
truck reflashed
how can you tell if your truck has been reflashed
hunting247 is offline
Old 08-25-2006, 07:30 PM   #2 (permalink)
Re: truck reflashed
Stickers on the driver side radiator or cowl cover. Have a dealer run an Oasis report. It will show everything a Ford dealer has done.
On edit, I have to add that my last reflash was posted on the driver door post.
2003 KR F-250 4X4 CC SWB, 6.0, 5 Speed Auto, 3.73 Axle, no Limited slip. Rhino bedliner, Unicover bed cover.
Built on February 19, '03
#2 93 F-150 XLT, 5 Liter, Auto, 4X4, X Cab. 251,000 miles. Uses no oil between changes.
montanafan is offline
Old 08-25-2006, 08:34 PM   #3 (permalink)
Re: truck reflashed
[img]/ubbthreads/images/graemlins/cool.gif[/img]well put montanafan, but w/ the new upgrade of tester we use now, there are new enhancments & applications that have to be applied. we get new updates almost ever other day so when we reflash, they are up to date in case of a conflict w/ the running of all the veh's.i stick the stickers on the left inner portion of the hood right next to the hood latch bar. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
certified ford dealer 7.3L,6.0L & 6.4L diesel tech & foreman
dvtech is offline
Old 08-25-2006, 09:18 PM   #4 (permalink)
OT
OT's Avatar
Re: truck reflashed
Glad to hear your using sticker. Seems I recall a FMC tech. here said reflash # not listed on updates, just that it was latest pcm recal. Seems that tech. also said didnt use sticker (amd) Another (curent)thread says sticker used & shows recal. # for the 06E17 recal.
Q..Do you list on the sticker what was reflashed & actual #. If so, is that a hard/time consuming job to find that recal. #. TIA
Curious..did you ever see this notice from FMC?
AMD..Authorized Modification Decal. FMC/EPA & CARB - Is required to list date/dealer# & summary of modification performed. "Placed adjacent to VEC1 - (vechicle emission control info)" & cover with clear decal shield.
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
Old 08-25-2006, 09:53 PM   #5 (permalink)
Re: truck reflashed
I have had 2 or 3 reflashes (unsure), as I have never seen a sticker or anything on the paperwork. I have even requested notification of some kind on the paperwork I,ve given to the service advisor and still see nothing. But I do know the last was recall 05E15. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2004 F-350 Lariat, Supercab 4X4 FX4, DRW
Dark Toreador Red/Silver, 6.0L, Torqueshift Auto, ESOF, 4.10 LS, Camper Package, Dual Alternators. Build Date 6-8-04, Eng 5-28-04, Lance 9.5 Ft Camper.
Past 2002 F-350 Lariat, Supercab 4X4, Toreador
Red, 7.3L, Auto, DRW, Fully Loaded.
Past 94.5 F-250 Lariat, Supercab 4X4, 5 spd 7.3L PSD.
DRJ48 is offline
Old 08-25-2006, 10:59 PM   #6 (permalink)
FamilyRide's Avatar
Re: truck reflashed
Never had a sticker and only once on the ticket it said "reprogrammed" or somehting like that, and that was it.
I've seen something posted plus consistant comments for techs saying Ford required the dealer to be up to date and that they no longer have info on updates. Who knows, my deaelr has been good but never documents flashes it seems.
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
FamilyRide is offline
Old 08-26-2006, 02:36 AM   #7 (permalink)
My Photos: (12)
Re: truck reflashed
My '06 was updated and stickered on the core support, driver's side. Pic here, ran perfect before and after, etc.
Arch
2006 F-250 Lariat CC SWB 4x4 3.73 Auto
Archie is offline
Old 08-26-2006, 06:26 PM   #8 (permalink)
Re: truck reflashed
[img]/ubbthreads/images/graemlins/smile.gif[/img]ford has come to a conclusion that if there is no reflash availible on oasis, then don't reflash unless the customer wants it reflashed at there expense. have had a couple of kickbacks from ford for doing this. [img]/ubbthreads/images/graemlins/grin.gif[/img]
dvtech is offline
